Old Nov 09, 2014, 03:33 PM
magrinsi's Avatar
Florence Italy
Joined Dec 2009
Originally Posted by ehelibuff View Post
Here's from a test in my front yard.
Jolt 2 test
Run Time: 12.8 seconds
Prop:4.75x5.5 APC
Motor: Neu 1115/1Y
Battery: TP 5S 2700mah 70C
Voltage: Max 21.2/Avg 18.1
Ripple: Max .27/Avg .06
Current: Max 136.9A/Avg 113.8A
Watts: Max 2,428/Avg 1,350
Temp: Max 111.3F/Avg 97.0F
RPM: Max 93,654/Avg 75,840
Throttle In: Max 2.107ms/Avg 1.443ms
Power Out: Max 100.0%/Avg 40.6%
A Hours: Max 0.32Ah/Avg 0.14Ah
93.000 rpm?
magrinsi is online now Find More Posts by magrinsi
Old Nov 09, 2014, 03:35 PM
2012 NZ Speedcup - 231 MPH
DownUnderPilot's Avatar
New Zealand, Tasman, Richmond
Joined Mar 2006
Someone forgot to set the number of poles ;-)
DownUnderPilot is online now Find More Posts by DownUnderPilot
Old Nov 09, 2014, 03:38 PM
ehelibuff
ehelibuff's Avatar
United States, CA, Santa Clarita
Joined Aug 2014
That's what the data logger reported in my Castle 130 Edge from my flight yesterday.
ehelibuff is offline Find More Posts by ehelibuff
Old Nov 09, 2014, 03:40 PM
ehelibuff
ehelibuff's Avatar
Joined Aug 2014
It's set at 4 pole
Old Nov 09, 2014, 03:41 PM
ehelibuff
ehelibuff's Avatar
Joined Aug 2014
Steve and Jeff at Neutronics told me to set the timing at 0. I set it up with Jeff, step by step.
Old Nov 09, 2014, 03:42 PM
ehelibuff
ehelibuff's Avatar
Joined Aug 2014
Obviously, these numbers aren't adding up.. I'm a bit confused.
Old Nov 09, 2014, 07:04 PM
ehelibuff
ehelibuff's Avatar
Joined Aug 2014
Flight log
Here's the reading.
Old Nov 29, 2014, 03:06 PM
magrinsi's Avatar
Florence Italy
Joined Dec 2009
..46mm is correct CG?
Old Nov 29, 2014, 07:21 PM
ehelibuff
ehelibuff's Avatar
Joined Aug 2014
That's where mine is at. Flies well. I was told 43-48
Old Nov 29, 2014, 08:20 PM
ehelibuff
ehelibuff's Avatar
Joined Aug 2014
I'm picking up a new Swist on Monday. Going with a geared system. Flew my Jolt 2 today. Had a great flight. Had a nice headwind as well to take off and land in. Was able to float it in and land right at my feet.
Old Nov 29, 2014, 11:58 PM
The Prop is Where its At!
blitzu's Avatar
New Zealand, Bay Of Plenty, Omokoroa
Joined Dec 2012
Is that a Swist or Swist Pro?
blitzu is online now Find More Posts by blitzu
Old Nov 30, 2014, 12:07 AM
ehelibuff
ehelibuff's Avatar
Joined Aug 2014
Just Swist w/flaps. Not the pro.
Old Nov 30, 2014, 01:12 AM
United States, CA, Redondo Beach
Joined Oct 2013
Superbly slippery airframe
hubcapsteve is offline Find More Posts by hubcapsteve
Old Nov 30, 2014, 03:35 AM
blitzu's Avatar
Joined Dec 2012
Yup thats the one to go for if you're not doing hard out F5D-more room for batterys etc...
Old Dec 03, 2014, 03:43 PM
ehelibuff
ehelibuff's Avatar
Joined Aug 2014
Swist
Here's my new Swist W/Flaps. I have the motor on order. When it's ready, i'll pick up the prop matched to it as well. Going to run a 1115 with gearbox and 10x22 on a 5S. Have a YGE 150 FAI ESC for it. Picked up the kit today in person at SUSA with 4 Hyperion DS09-AMD's 1 MKS DS6100 & 1 Eneloop 4.8V 750mah. I think i'll get the Thunder Power 5S 1800mah 70C for it; unless I can get one slightly bigger.
Looking forward to building it. My Jolt 2 is flying perfect. Hopefully it won't rain this Saturday so I can fly it... We'll see.
Discussion Swist F5D build and fly 250mph+?! henke High Performance 420 Dec 06, 2014 05:58 AM
Discussion Micro Shrike Build Thread (was Mystery Build Thread) AndyKunz Electric Plane Talk 101 Dec 05, 2013 10:50 AM
Build Log Build thread for my F5D fuselage used at the WC Troy High Performance 3 Sep 09, 2010 04:39 PM
New Product New Build thread for Viper F5D Model Rob AR High Performance 20 Sep 08, 2009 04:06 AM
Build Log Build Thread or not to Build Thread? - Redback malachite Slope 35 Feb 28, 2006 01:12 AM
