Old Apr 18, 2014, 08:43 AM
...missing the PE Slope Rebels
Flying Beagle's Avatar
United States, MI, Manchester
Joined May 2004
could you post a velcro pic please ? thx
Flying Beagle is offline Find More Posts by Flying Beagle
Old Apr 18, 2014, 06:16 PM
Gwalch's Avatar
Australia, VIC, Inverleigh
Joined Mar 2004
My old Speedo didn't come with the velcro.. I just taped the wings together with clear packing tape.
Apart from replacing 1 piece of tape as it got a bit of dirt under it.. I have never had a problem with the wings coming apart.
I've had this Speedo for 4 years now and no problems.
I used the same tape method on a DLG glider I bought from the same manufacturer and it was great. It handled the stress of a DLG launch quite well.
The only thing with the tape is to make sure you check it once in a while for splits if you have a less than perfect arrival and replace it.
But.. the velcro is a great idea if your landings are not as smooth as you would like.
Gwalch is online now Find More Posts by Gwalch
Old Apr 19, 2014, 02:21 PM
The original Flying Pigs Sqd.
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
I used the Velcro for the Rx and battery.
Up&Away is offline Find More Posts by Up&Away
Old Jun 12, 2014, 02:42 PM
United States, AZ, Lake Havasu City
Joined Feb 2010
Hi All,
I attended the Katie Tribute at Torrey Pines last weekend and got re-turned on to slope flying. I flew a Katie II and a V-Tail without the prop, and I also have a Coyote which I have not flown yet. I was really impressed with the smaller aerobatic slopers and after watching a Mini Blade fly, I thought I might get one of those even though somewhat pricey. Then I stumbled upon the Speedo, and at 1/4 the price, I thought I might give it a try.
How does the Speedo compare? I don't expect the same level of performance, but I think it would fit what I want to do.
Now I will start reading the rest of this thread.
Thank You,
SpadCat
SpadCat2000 is offline Find More Posts by SpadCat2000
Old Jun 12, 2014, 05:52 PM
Gwalch's Avatar
Joined Mar 2004
Once you by a speedo you'll never go back. They are small, cheap, and the best bang for buck out there.
I've not flown those other models you mentioned but I really don't think you'll be disappointed.
Old Jun 12, 2014, 07:24 PM
Joined Feb 2010
Thanks Gwalch, I told my brother about the Speedo (he also was really interested in the Mini Blade after seeing it fly) and after a quick look he placed an order. I will order mine shortly.
SpadCat
Old Jun 13, 2014, 10:35 PM
Joined Feb 2010
Servo Question
I have a pair of Airtronics 94800 5 gram digital servos. I am planning on adding rudder and I read somewhere on a Speedo thread that a HXT 500 was being used for elevator and the 94800 has same specs. Since I need two servos in a very small space, I thought I would use the 94800s for elevator and rudder or, if that is not a good idea I could use a 94800 for rudder and a Tower Pro 9 gram for elevator. I will use the spring system.
SpadCat
OK after some reading in the other thread, I found several references to 5 gram servos being used
Old Jun 14, 2014, 12:49 AM
Rusty
Rusty Nail's Avatar
Auckland, New Zealand
Joined Feb 2006
Use the highest resolution and best centering on arm inner hole for the elevator, very sensitive control needed.
Rusty Nail is offline Find More Posts by Rusty Nail
Old Jun 14, 2014, 01:38 AM
Joined Feb 2010
Ok, thank you.
Help! instruction manual kiter32 Radios 1 May 14, 2011 08:00 PM
pz p51 instruction manual EDFPILOT Non R/C Items (FS/W) 2 Apr 04, 2011 02:44 PM
Wanted: Instruction Manual for SR Cutie Rudderman98 Aircraft - Electric - Airplanes (FS/W) 2 Jul 23, 2002 10:39 AM
needed: Instruction manual for FMS Supernova 250S Keitha Aircraft - Electric - Airplanes (FS/W) 3 Jun 18, 2002 08:11 PM
bandit instruction manual tqpham Electric Sailplanes 3 Mar 27, 2002 07:24 PM
