Old Sep 04, 2016, 03:46 AM
bogbeagle is online now
Find More Posts by bogbeagle
Joined Mar 2007
Bag o' junk
I was handed a grocery' bag of "junk", the other day.
OS max 40H
Enya 19
Enya 35
Fox 40
Profi 40
Merco 61
Merco is missing the needle valve... and I'm short a coupla prop nuts.
Other than that, the haul seems to be quite complete and functional.
Am sitting here, wallowing in nostalgia. 'Specially for the Merco, and the Enya 35.
bogbeagle is online now Find More Posts by bogbeagle
Old Sep 04, 2016, 04:01 AM
CryHavoc is online now
Find More Posts by CryHavoc
UAS Pilot - FAA# *******HRK
CryHavoc's Avatar
United States, TX, Copperas Cove
Joined Apr 2000
How does the Profi .40 run. That's probably the gem in the bunch.
CryHavoc is online now Find More Posts by CryHavoc
Old Sep 04, 2016, 04:06 AM
Joined Mar 2007
Dunno ... haven't run any of 'em. Seems OK, though.
I had a .60, years ago. Bit of a beast.
Old Sep 04, 2016, 04:21 AM
Brutus1967 is online now
Find More Posts by Brutus1967
life without risk isn't living
The Netherlands
Joined Nov 2009
Is that the Hornlein Profi, or the Ukrainian Profi?
Brutus1967 is online now Find More Posts by Brutus1967
Old Sep 04, 2016, 04:26 AM
Joined Mar 2007
Hornlein, afaik.
Gold-coloured crankcase.
Moulded plastic fore-part, which carries the carb.
Didn't know that there was another manufacturer, called Profi. Looks like this one ...
Old Sep 04, 2016, 04:29 AM
BrumBob is offline
Find More Posts by BrumBob
Birmingham, UK
Joined Apr 2007
The Enya 19 takes me back, it was my first 'big' glow engine before moving up to the heady heights of Merco 35s and the like. What would that be, early 70s?
Bob
BrumBob is offline Find More Posts by BrumBob
Old Sep 04, 2016, 04:49 AM
Joined Mar 2007
Could be 70s.
There's a few old servos in the bag ... amongst them, MRC servos and 27 Mhz receivers.
One of the servos has a price on it ... 19.50. So, it's post-decimalisation. But, quite a costly item, for its day.
Another servo has a label on it, stating that the owner had replaced the gearing in 1983.
There's also an old OS marketing leaflet, about A2 -sized. Amongst the items for sale, are the old open-rocker FS-60 and a bunch of live-steam locomotives. ... and those dreadful Wankel engines.
I didn't know that OS apparently had their own-brand of RC equipment. There's a range of outfits, called Cougar and Arrow.
Old Sep 04, 2016, 04:54 AM
The Netherlands
Joined Nov 2009
Originally Posted by bogbeagle View Post
Hornlein, afaik.
Ukrainian profis are very exquisite fourstrokes, so it would be a real find if it was one of those....
I have a Hornlein Profi (also found in a box of trash) but unfortunately mine is REALLY trashed by its previous owner, and will never run again...
Old Sep 04, 2016, 10:28 AM
706jim is offline
Find More Posts by 706jim
Canada, ON, Thunder Bay
I ran Enya 35's and 45's and found that they ran really hot. Otherwise, great engines.
706jim is offline Find More Posts by 706jim
Old Sep 04, 2016, 01:20 PM
flyboy2610 is online now
Find More Posts by flyboy2610
Mumbling in the corner.
flyboy2610's Avatar
Lincoln Municipal, Nebraska, United States
Joined May 2004
Might have been too lean.
flyboy2610 is online now Find More Posts by flyboy2610
Old Sep 04, 2016, 02:54 PM
CryHavoc's Avatar
Joined Apr 2000
Or not fully broken in yet.
Old Sep 04, 2016, 09:55 PM
Pylonracr is online now
Find More Posts by Pylonracr
Scott
Pylonracr's Avatar
Joined Mar 2011
Or too much nitro. Try them again on 5% and see what they do.
Pylonracr is online now Find More Posts by Pylonracr
Old Sep 04, 2016, 10:22 PM
hughsey is offline
Find More Posts by hughsey
Stand by here come banana
Singapore, Singapore
Joined Sep 2016
Enya's were a great little engine so my old teacher would tell me.
hughsey is offline Find More Posts by hughsey
Old Sep 04, 2016, 11:32 PM
jeffie8696 is online now
Find More Posts by jeffie8696
TEAM BOCA
jeffie8696's Avatar
United States, IA, Muscatine
Joined Oct 2009
I understand the OS40 H was a good reliable engine, I have one new in box. Its so hard not to try it out.
jeffie8696 is online now Find More Posts by jeffie8696
Old Sep 05, 2016, 01:01 PM
Joined Mar 2007
I ran some of those engines, the other day.
OS 40 worked straight off.
Merco 61 was missing a needle valve ... but, there was a brand new carby in the bag. So, with that fitted, the engine ran great.
Fox .40 needed a bit fettling. Bit of damage to the piston crown. Not much, but enough to pinch the piston ring and prevent it from expanding properly. Sorted that. Engine runs great.
Enya 35 ... prolly the best of the bunch, once I got it running. Turns out that someone had fitted the incorrect needle valve. So, even with the needle screwed right in, fuel was still pouring into the engine. Luckily, I had a suitable needle in my spares box.
The Profi is a duffer. Absent its piston ring. Might try to source a replacement.
The Enya 19 needs some attention. It's held together with an assortment of screws ... every one different. Well, it's not really held together at all, since the front assembly rocks about, making a gas seal impossible. Hoping that a bit of TLC will bring that engine back to life.
Now thinking about retro airframes ... maybe something for the Enya 35 or OS 40.
AFAIK, they haven't been used since the 80s. It's remarkable that all the bearings seem to be perfectly serviceable. Castor oil? There's plenty of evidence of its use on these engines.
For Sale Bag O' Mobius! $23/Shipped! chillware Aircraft - Electric - Multirotor (FS/W) 2 Aug 24, 2016 06:37 PM
Discussion Arm switch, motor_stop, and Taranis - bags o' questions krachall Multirotor Beginner 24 Jul 13, 2016 03:29 PM
Found Bag o' Props NoiseBox Aircraft - General - Miscellaneous (FS/W) 0 Apr 05, 2016 12:49 PM
For Sale bag o wheels helizrnew2me Aircraft - General - Miscellaneous (FS/W) 0 Jan 18, 2016 09:44 AM
For Sale bag o wheels helizrnew2me Aircraft - General - Miscellaneous (FS/W) 2 Dec 24, 2015 05:16 PM
