Old Jul 26, 2014, 06:36 PM
DeXX's Avatar
Croatia
Joined Nov 2009
Help!
Help me to decide about a small Hex FPV size
please help me to decide about the dimensions of the new model !!!
I would like to make a true FPV model, a small hex...
I have a certain design in mind but I would not want to start working on it before I'm completely sure about the size...
because as always, it is a closed model type and I need to know in advance the size of all electronics
So, my question for those who fly a small hex FPV model is:
what is your preferred prop size? max 5-6'' or 7-8''
the size of the batteries and the number of cells?
and anything else that comes to your mind
I would like to make a very small model, but again I do not want it too be too small for all electronics
Thank you in advance!!!
Denis
DeXX is offline Find More Posts by DeXX
Old Jul 26, 2014, 08:31 PM
United States, PA, Doylestown
Joined Jan 2014
Start with an estimated weight. That will then determine the Prop size and then Motor size and then #cells.
You can get go ideas of these specs from reading through the various threads on mini-Hex copters.
waltr is offline Find More Posts by waltr
Old Jul 26, 2014, 11:44 PM
DeXX's Avatar
Croatia
Joined Nov 2009
thanks for the advice waltr
but I think I've asked the question a bit wrong....
I have an idea in my head about FPV mini hex design
My idea so far includes this basic electronics:
-max 6'' props
-22xx motors size arms
-4S 2200mAh size compartment
-place for gopro and similar cameras
and all other necessary electronics....
but once when I made all the molds I can not change the size of the model unless I make a new molds....
so I wanted some info about best "mini" hex prop size
and common battery size since this is the most important data because the battery will be inside the hull
If I make a place for 4S 2200mAh anything larger than that will not fit inside
and if I make too much room inside the model it will affect the hull weight....
so the idea was to get some information about preferred electronics
and maybe some preferred option for electronic layout....
But yes, I agree.... I should have browse through the other similar topics
Poll Help me choose a small beginner 4x4. Dromida, ECX, or HK nopistn Car Talk 24 Nov 28, 2013 10:58 PM
Question Building ultra-light plane from scratch: help me decide what components UWME Foamies (Scratchbuilt) 17 Nov 19, 2013 09:49 AM
Question Help me decide bhoov128 Micro Ready-to-Fly 13 Oct 30, 2013 12:02 AM
Discussion Help me decide on what boat Gez877 Racing Boats - Electric 8 Oct 10, 2013 09:19 AM
Discussion Help me decide on a small P-47 cloudbuster Electric Warbirds 8 Jun 18, 2011 11:38 PM
