Old Jul 09, 2015, 02:26 PM
beginner4life is offline
Find More Posts by beginner4life
beginner4life's Avatar
United States, MD, Ellicott City
Joined Mar 2008
Source of lack of power?
Hi guys, I'm running a Turnigy 28-36 NTM 3000kv w/ 6x4 prop on 3s 2200 on a 60a esc. Everything is pretty good but when I get into the 90% throttle range theres a kind of whine that comes out, similar to when you're near the end of a pack and are using too much throttle, sounds kind of intermitent but constant if that makes sense. Its a relatively new pack rated at 35c discharge, do you think the battery is having trouble supplying the amps?
beginner4life is offline Find More Posts by beginner4life
Old Jul 09, 2015, 04:06 PM
172AMD is offline
Find More Posts by 172AMD
Richmond B.C. Canada
Joined Aug 2006
6x4 prop is too big for 3000Kv. You are probably exceeding motor, ESC, and the real battery limits. ESC lvc or overamp? ESC settings? What is the system drawing at wot? If you do not have one, get a watt meter. It will help you understand what is happening.
172AMD is offline Find More Posts by 172AMD
Old Jul 09, 2015, 06:48 PM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
PCalc shows 25 amps.
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Jul 09, 2015, 06:54 PM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Originally Posted by beginner4life View Post
... I'm running a Turnigy 28-36 NTM 3000kv w/ 6x4 prop on 3s 2200 on a 60a esc. Everything is pretty good but when I get into the 90% throttle range theres a kind of whine that comes out ...
What current did you measure at 90% throttle, i.e. just before the whine starts, and what current at WOT?
Was everything been okay before all this?
Vriendelijke groeten Ron
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Jul 09, 2015, 07:47 PM
Joined Mar 2008
Unfortunately I don't have a watt meter. I think it must be the battery because for the first minute of flight, WOT has no whine and tons of power, as flight goes on the "whine" occurs earlier in the throttle range.
Great power from this setup as well if anyone was curious. Has my 50" wing flapping if i rip the elevator too hard at high throttle
Old Jul 10, 2015, 12:44 AM
172AMD is offline
Joined Aug 2006
mw
What motor? Did not see the Turnigy 28-36 NTM 3000kv on there. 25amps, Something wrong there.
Old Jul 10, 2015, 12:46 AM
172AMD is offline
Joined Aug 2006
Buy a watt meter. helps with setting up power systems.
Old Jul 10, 2015, 08:04 AM
Joined Feb 2001
A watt meter will pay for itself, will save you at least one burnt controller, motor and one ruined battery. You need a watt meter for troubleshoothing and best set-up.
Prettig weekend Ron
Discussion Lack of engine powered helis JohnFM Fuel Heli Talk 17 Jul 13, 2015 08:55 AM
Discussion F5B - my Leo is lacking power ... Erwitt High Performance 26 May 25, 2015 04:27 AM
Discussion Novus 200 lack of power... about to loose it :O kenmtb Electric Heli Talk 11 May 12, 2014 07:59 PM
Discussion Lack of power Robbo66 Electric Plane Talk 6 Mar 05, 2014 03:45 AM
Discussion Saito Fa-91 lack of power victorfriessen Engines 20 Dec 11, 2013 04:52 PM
