Old Jun 06, 2015, 10:10 AM
TheGrt14Real is offline
Find More Posts by TheGrt14Real
Joined Jun 2015
Camera compatibility on Syma
I have not been able to find an answer to a question that I have about my Syma x5sw. Will the Camera off of an x5sc work on the the x5sw? The X5sw as you may or may not know. Uses the iOS or android app for recording the video feed being sent via wifi to your device. And since the wifi range is less than half that of you 2.4ghz control range. You actually lose your video recording way before you lose the ability to control the copter. I have about ten acres and I would like to get an Ariel view of my entire property. The camera on the x5sc doesn't have wifi. It stores its feed on an SD card until it's memory on the card runs out. I can buy just the camera off of amazon. That way I could remove my wifi camera and pop the SD camera on instead, take off and record no matter the distance. They appear to mount the same but I'm worried about the plug and voltage being compatable from model to model. Any feedback would be great!
TheGrt14Real is offline Find More Posts by TheGrt14Real
Discussion Using Syma X5C-1 camera on a 180QX. Is it possible? Thangle Mini Multirotors 2 Jul 20, 2015 11:54 AM
Discussion connector type on SYMA X5C Camera Murefu Multirotor Talk 4 Jul 06, 2015 01:12 AM
Discussion "Toy" Quadcopters and compatibility with "Toy" Cameras like Multirotor Go Mini Multirotors 6 May 22, 2015 10:28 PM
Discussion Main Blades compatible with Syma S36 ulterios Coaxial Helicopters 1 Jan 20, 2015 11:38 PM
Discussion Syma parts cross compatibility list djdavies83 Coaxial Helicopters 36 May 01, 2013 10:35 AM
