Old Yesterday, 12:21 AM
lazy-b is offline
Find More Posts by lazy-b
Manila, Philippines
Joined Jul 2004
Flying with external Antenna install inside the Transmitter.....
Guys, I hate having the external 2.4GB antenna sticking out my Transmitter......its difficult to store in a small tool box .
So, what I do.....I open up my Radio and hide the antenna inside the transmitter.......I just put in the Top most of the transmitter, its just below the antenna root.
Been doing this for more than a year.....
But Now, I plan to do the same on my Transmitter Modules.......
Have some of you have tried this ?
lazy-b is offline Find More Posts by lazy-b
Old Yesterday, 05:20 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
For transmitter modules you could have issues with antenna size... bigger than the module case...
Maybe a GPS style ceramic patch will be a better approach, but you should follow the model with the radio, this solution is directional.
renatoa is online now Find More Posts by renatoa
Old Yesterday, 01:11 PM
KC is offline
KC
Find More Posts by KC
KC
Registered Loiterer.
KC's Avatar
United States, FL, Orlando
Joined Sep 2006
... Snip...
I have. Both the Spek and FlySky modules are used with the antenna in the module bay. The antenna can be pulled out, but it generally stays in the bay with the bay cover on.
I should mention that I only fly micro sized planes with these modules, close in, where I don't have to worry about range. The way I hold the Tx, which is parallel to the ground and slight downwards, the Tx blocks much of the signal. I wouldn't fly like this to full LOS/visual limit distances.
KC is offline Find More Posts by KC
Old Yesterday, 01:50 PM
Joined Sep 2007
The left image placement is a very bad example, is the case when the radio points to the model, along the antenna axis there is a black hole, literally, is no wonder this works for indoor only.
Old Yesterday, 02:56 PM
ivanc is offline
Find More Posts by ivanc
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
I did that on my Futaba 9C and flew it for several years until the 9C got retired. I flew up to 110" WS glow powered airplanes with it without any issues.
http://cankov.com/modelairplane/futaba/futspek013.jpg
http://cankov.com/modelairplane/futaba/futspek015.jpg
http://cankov.com/modelairplane/futaba/futspek016.jpg
Ivan
ivanc is offline Find More Posts by ivanc
Old Today, 03:14 AM
lazy-b is offline
Manila, Philippines
Joined Jul 2004
Thanks to all have respond...
I alway folded my 2.4 antenna Horizon tally.....this produce a Maximum radiation pattern in front of the Pilot.
Been thinking of making a T Supports on the Modules.....where you can mount the Antenna Horizontally........The Antenna is just about an Inch from the edge of the Modules.
An Ideal location is to Position the Antenna exact at the Transmitter Handle, Maybe we could replace the Metal Handle with a Plastic .
Sold DJI Phantom 3 Pro / Advanced Radio Transmitters modified for external antennas bankyf Aircraft - Electric - Multirotor (FS/W) 0 Nov 27, 2015 02:57 PM
Sold DJI Phantom 3 Pro / Advanced Radio Transmitters modified for external antennas bankyf Aircraft - Electric - Multirotor (FS/W) 0 Nov 24, 2015 07:33 PM
Sold DJI Phantom 3 Pro / Advanced Radio Transmitter modified for external antennas bankyf Aircraft - Electric - Multirotor (FS/W) 0 Nov 19, 2015 10:46 PM
Help! Installed external transmitter firmware on ezuhf plug in transmitter!!! Help beachflyer FPV Equipment 0 Aug 31, 2015 11:52 PM
Sold Spektrum DX6i DSM2 transmitter with added external antenna jack RaptorAP Aircraft - General - Radio Equipment (FS/W) 5 Nov 02, 2011 11:17 PM
