Old Nov 13, 2015, 09:41 AM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Spinners and Prop Adapters for Brushless Motors
I have a number of small brushless motors that have 3mm motor shafts and others that have prop adapters that bolt to the rotating can. I want to use plastic spinners for small warbirds . Most standard or collet type adapters are too short to accommodate a spinner back plate, a prop, a washer and a nut. For longer collet adapters I found a longer Hyperion HP-ADAP-30L adapter sold by RC Dude and AllE RC. For the bolt-on adapters, Innovative Designs sells a longer version for their Cobra motors. Dubro sells an integrated spinner/collet adapter in 3 different motor shaft sizes including 3mm (Tower Hobbies).
http://shop.dubro.com/p/1-1-4-32mm-e...red?pp=12.com/
Just thought I'd pass this along
E-Challenged is offline Find More Posts by E-Challenged
Old Nov 13, 2015, 07:06 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Dubro spinners are Heavy things. Sometimes a problem setup.
Gawd knows I've bought enough of them over the years :-)
One could? use a cone /spinner type nut instead of the Hex nut And washer.
Thereby allowing space for the usually 1/16 thick spinner backplates
Bare is offline Find More Posts by Bare
Old Nov 13, 2015, 07:48 PM
slow_flier is online now
Find More Posts by slow_flier
slow_flier's Avatar
United States, PA, Pottstown
Joined Dec 2009
You can also get longer adapters and spinners from Tru-Turn http://www.truturn.com/
slow_flier is online now Find More Posts by slow_flier
Old Nov 14, 2015, 10:44 AM
Joined Oct 2000
Thanks for the other source info. Too bad adapter makers don't make prop shafts just a little longer. Maxx Products also supplies a number of adapters for various motor shaft and prop shaft diameters and thread types.
Sold HCS Compact 380 brushless motor/spinner/CAM 6x3 folding prop EBerris Aircraft - Electric - Power Systems (FS/W) 2 Aug 22, 2015 11:32 AM
For Sale Aluminum Prop Adapter Set for Multirotor 4114 Sized Brushless Motors sotog Aircraft - Electric - Multirotor (FS/W) 1 Aug 05, 2014 06:38 PM
For Sale 2.0mm RC Aluminum Bullet Propeller Adapter Holder for Brushless Motor Prop ucusclub Aircraft - General - Miscellaneous (FS/W) 0 Mar 20, 2014 05:01 AM
Discussion Prop Adapter for 28-series Brushless Motor tk240381 Electric Plane Talk 5 Nov 26, 2013 10:40 PM
FS: Folding Props, Spinners, Motor Adapters, Zagi motor/prop PDX Slope Pilot Aircraft - Electric - Airplanes (FS/W) 6 Apr 30, 2004 09:04 PM
