Old Jan 26, 2016, 08:05 AM
Cap_n_Dave is offline
Find More Posts by Cap_n_Dave
Joined Mar 2008
Originally Posted by vincent123 View Post
Now, I defined the carbon rods as infinite stiff, is about fair compared to the wood spars.
Now I see that the spar-webbing construction is most stressed, perhaps I should think about reinforcing this connection.. ?
The ribs are surprisingly less important in this approach!
Vincent:
What stress levels do the colors equate to?
It's common in FEA to be distracted by the red color ... which simply depicts the highest stress (but not necessarily a failure-inducing stress).
Also, the stress level in the shear web is exactly as one would expect ... low at the neutral axis, and high at the spar caps. You may want to glue pre-cured unidirectional CF to the spar caps. Alternatively you may want to change the spar geometry ... wider at the root and narrower at the tip.
It shouldn't be much of a surprise that the ribs don't carry much load. The spars carry the load.
Be careful with your FEA ... it's very easy to get distracted by the toolset, and then get sucked into "overanalysis paralysis." At some point you'll need to move forward with the build. (also known as "shoot the engineer and build the airplne")
-Dave
Cap_n_Dave is offline Find More Posts by Cap_n_Dave
Old Jan 26, 2016, 12:18 PM
vincent123 is offline
Find More Posts by vincent123
InceCreations
vincent123's Avatar
Joined Jul 2009
Hi Dave,
The colors are just colors, I could not select wood as material.
I was interested how rib1 and rib2 behave, as they need to translate the spar forces to the carbon former fuselage connectors.
Evantually, I kept my original design: first 2 ribs thick to translate the forces, and classic spar webbing design.
vincent123 is offline Find More Posts by vincent123
Old Feb 07, 2016, 05:56 AM
InceCreations
vincent123's Avatar
Joined Jul 2009
Webbing
Webbing ... boring job .... nevertheless ... has to be done !
Wing is pretty stiff, torsional stiffness will end up fine after sheeting.
Test mounted the wing .. so far so good.
Old Feb 07, 2016, 11:41 AM
iron eagle is offline
Find More Posts by iron eagle
iron eagle's Avatar
United States, MA, Middleboro
Joined Jul 2007
Wow Vincent that looks so sharp, and built like a battleship to boot.
iron eagle is offline Find More Posts by iron eagle
Old Feb 07, 2016, 12:19 PM
InceCreations
vincent123's Avatar
Joined Jul 2009
Hi there, thanks !
Building is progressing slow nowadays ...
Old Feb 07, 2016, 10:39 PM
EdSoars is offline
Find More Posts by EdSoars
EdSoars's Avatar
Salida, Colorado
Joined Sep 2002
Beautiful workmanship. I'm getting nervous jitters thinking about the maiden. Take your time. The suspense is wonderful.
EdSoars is offline Find More Posts by EdSoars
Old Feb 08, 2016, 12:31 AM
InceCreations
vincent123's Avatar
Joined Jul 2009
To be honest, I'm dying on the airfield during a maiden !
Heart pounding like hell in my throat, sweaty hands ....
And this one, with the EDF drawing high currents, i'm planning to take off, and land after a short flight, being afraid my battery depletes before being able to settle for a nice landing approach.
Trying not to think about it, yet .. ;-)
Old Feb 08, 2016, 03:12 AM
Artful Owl is offline
Find More Posts by Artful Owl
Artful Owl's Avatar
New Zealand, Canterbury, Christchurch
Joined Dec 2011
Stunning. Beautiful lines.
Artful Owl is offline Find More Posts by Artful Owl
Old Feb 09, 2016, 04:55 AM
InceCreations
vincent123's Avatar
Joined Jul 2009
It s gonna be huge wing surface...
Old Feb 09, 2016, 07:31 AM
EdSoars is offline
EdSoars's Avatar
Salida, Colorado
Joined Sep 2002
Huge wing is good with high wing loading and clean, swept lines!
Old Feb 09, 2016, 11:16 AM
InceCreations
vincent123's Avatar
Joined Jul 2009
I chose a relative small wingspan and as a result pretty large root and tip, so that the drag at speed would be lower aswell as the landing speed.
Old Feb 10, 2016, 02:18 PM
Artful Owl's Avatar
Joined Dec 2011
How do you work out the placement of the components in relation to cg. That's one thing iv always struggled with when scratch building.
Old Feb 11, 2016, 11:34 AM
InceCreations
vincent123's Avatar
Joined Jul 2009
Good question.
For all the components of the airframe, including reciever, servos, spars, webbing, sheeting, formers, planking and so on, I calculate the individual contributions to the CG location.
For the past designs, my estimate was pretty good (FZ2, FZ3, Zdelta): meaning i never needed to correct the CG with lead, but only by shifting the battery.
The battery is my only degree of freedom in a finished scratchbuild. I allow myself a +20mm and +20mm degree of error. meaning the battery compartment allows me to shift the battery with 20mm forward or backwards.
The relative contribution of a component is calculated as:
mass x lever
The lever is the distance of the component's center of mass to the desired CG of the airframe. Make the lever distance for components in front of the CG ariframe positive, and the rear of the CG negative.
The sum of all these contributions needs to be zero
mass1xlever1 + mass2xlever2 + ....=0
In office excel, you can then play with these distances while you are designing.
Hope my explantion was good enough?
Vincent
Old Feb 11, 2016, 12:14 PM
EdSoars is offline
EdSoars's Avatar
Salida, Colorado
Joined Sep 2002
It probably beats my method of taping all the power components on a stick after the wing is finished, rubber-banding the stick to the wing, and moving the stick back and forth until it all balances.
My fuselages are close to being sticks anyway, nothing like your sleek beauty.
Old Feb 12, 2016, 09:39 PM
Artful Owl's Avatar
Joined Dec 2011
That's impressive. For me one of the hardest parts of building CG sensitive planes is getting component position right.
Id be keen to see what these calculations and excel spreed look like do you use pen and paper or do it on your computer. any changes you could get a screen shot of photo?
Sounds fun and useful to learn.
Discussion How well would this canardish jet perform? (just design phase right now) GreenAce92 Foamies (Scratchbuilt) 5 Jan 16, 2009 07:14 AM
More shots with the Depron Dragon and Panasonic DMC-FZ5 CactusJackSlade Aerial Photography 7 Jun 12, 2005 12:46 PM
Yippee! Depron Dragon w/Panasonic DMC-FZ5 - maiden photos CactusJackSlade Aerial Photography 11 Jun 11, 2005 09:37 PM
Depron Dragon's new Panasonic DMC-FZ5 camera set-up - maiden this evening?! CactusJackSlade Aerial Photography 1 Jun 11, 2005 12:30 AM
New A/P Plane - Initial Design Phase Buzz_Man Aerial Photography 4 Apr 21, 2005 12:33 AM
