Old Feb 09, 2016, 11:32 AM
planecrazysam is offline
Find More Posts by planecrazysam
Joined Oct 2014
cc3d
I am wondering, would this gimbal design work with a cc3d controller board. A quadcopter I am looking at uses a cc3d board and I was wondering if it could do the stabilization and mixing the servos at the same time.
planecrazysam is offline Find More Posts by planecrazysam
Old Feb 09, 2016, 11:34 AM
Joined Oct 2014
Does this gimbal setup work with a cc3d board running openpilot?
Old Feb 11, 2016, 11:52 AM
eMoon is offline
Find More Posts by eMoon
I meant to do that
eMoon's Avatar
United States, NY, Albany
Joined Sep 2011
Sorry to not answer the question ^ and just add another question...
With the development of micro copters I'm currently building a 170mm quad with possibly the KK2 mini. Same firmware and Steveis programming as the original. How realistic would it be to try and minimize this sucker to a 170mm scale? Or would you need to?
I guess it depends on weight I know, so I'm just starting to think this through. Most likely using a micro FPV cam and gear for the video or try and see if stripping the case of a mobius would also work to save weight.
eMoon is offline Find More Posts by eMoon
Old Feb 11, 2016, 02:13 PM
raw89 is offline
Find More Posts by raw89
Rapidly aging user
raw89's Avatar
United States, PA, Lancaster
Joined May 2012
Did you read the posts on the previous page?
raw89 is offline Find More Posts by raw89
Old Feb 17, 2016, 01:15 PM
Joined Oct 2014
I just did. So it seems like it kinda works. I think the mixing thing is hard for the cc-3d board? I have never done gimbals or quadcopters so I am kinda new to this.
Old Mar 03, 2016, 08:05 AM
RCBoy21 is offline
Find More Posts by RCBoy21
Joined May 2013
What alternative parts can we use?
Instead of using nylon screws can i use metal screws? i cant seem to find nylon countersunk locally.
Also is it ok to integrate the bottom plate on the frame itself? Like on the front of a rcexplorer tricopter? would the vibes be too much?
I am planning for a rcexplorer tricopter with the integrated bottom plate, would this be a good idea?
RCBoy21 is offline Find More Posts by RCBoy21
Discussion Lets build a DIY direct drive gimbal for the poor man hexa Multirotor Talk 155 May 14, 2013 08:01 AM
Discussion A simple poor mans vector thrust unit alfstan RC Paragliders and Kites 5 Oct 21, 2012 09:18 AM
Discussion Poor Man`s OSD problem GPS cabecinhas FPV Talk 4 Oct 12, 2012 12:00 AM
Discussion A poor man's Gimbal 450 /500/550 heli pirzol FPV Talk 5 Dec 26, 2011 04:58 AM
Poor man's Super Slow Stick fun flyer? uglyplane Parkflyers 1 Jul 03, 2003 11:54 AM
