Old Aug 14, 2015, 10:35 AM
PontiusPilate is offline
Find More Posts by PontiusPilate
Sicut volare
PontiusPilate's Avatar
United States, VA, Chantilly
Joined Oct 2010
I have given this kit the benefit of the doubt, and though it's a great design, the execution and manufacturing were on the sloppy side. Some of the parts are low quality, there is no doubt about that. I love my 10cc engine, but the Saratoga made for a much more exciting pairing with it. I wouldn't go so far as to call the 10cc underpowered for the Meridian, but I can see where having a bit more power on tap would be fun, also, it would probably balance the plane better. I don't think anyone expects to do 3d with this plane. That said, it is a fun plane, but there is definitely room for improvement.
Originally Posted by teckbot View Post
I sort of chuckle while reading and seeing where this thread is going. I get kit bashing and people's curiosity about what if, but this plane and engine were made for / with each other in mind. And in this case, they work great as a set. Does not always work out this way, but here it does. The Evo10cc is a good little engine, the airframe is a great and robust flyer!
To be real, they are both meant to be progression items and neither is expected to have a LONG life expectancy. The EVO is not DA quality and the Meridian is not going to be a 3D superstar.
Enjoy them for what they are and just your flying time!
PontiusPilate is offline Find More Posts by PontiusPilate
Old Aug 14, 2015, 11:13 AM
teckbot is offline
Find More Posts by teckbot
Build to fly, fly to fix
Canada, QC, Pointe-Claire
Joined Jun 2011
Originally Posted by PontiusPilate View Post
No need for condescension. .
None implied, just my thougts
teckbot is offline Find More Posts by teckbot
Old Aug 14, 2015, 11:21 AM
victoras_h is offline
Find More Posts by victoras_h
United States, TX, Irving
Joined Jun 2010
...but this plane and engine were made for / with each other in mind. And in this case, they work great as a set....
This may have been induced by the manufacturers as a good little marketing move. Most likely they wanted a bump start in selling the 10cc gas engine and went together with Hangar 9. This is not necessarily a bad thing but from what I keep finding around here, they didn't really do much pre-release testing. To be honest, I'm just glad they don't 'force' everyone in buying the engine with a RTF only release.
victoras_h is offline Find More Posts by victoras_h
Old Aug 14, 2015, 11:35 AM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Regarding leaving planes "stock" - what's the fun in that?? Better overall performance can usually be achieved with most any BNF/RTF plane by experimenting with props, engines, servos, etc. After all, factory recommendations are intended to cover middle-of-the-road applications. Optimizing your aircraft to better-suit your specific flight-conditions (such as elevation) and flying-style is simply part of the hobby.
Regarding engine choice - if a plane needs nose-weight to balance properly, I'd MUCH rather add useful weight in the form of a more powerful propulsion system, rather than adding performance-robbing dead-weight.
Joel
turboparker is offline Find More Posts by turboparker
Old Aug 14, 2015, 04:59 PM
wdog is online now
Find More Posts by wdog
What goes up... must crash!
wdog's Avatar
United States, AR, Fort Smith
Joined Jan 2012
Originally Posted by flyinwalenda View Post
Fits, but it doesn't need it.
Only reason I ask is because I have been reading about the meridian being tail heavy and if I can, I'd like my nose weight to be engine not lead
wdog is online now Find More Posts by wdog
Old Aug 14, 2015, 05:29 PM
seldredge is online now
Find More Posts by seldredge
United States, CA, La Honda
Joined May 2014
A few thoughts on an electric Meridian
I build my Meridian as an electric, and since talk was of having to add weight to the nose, I did so with a bigger motor and larger battery--an Eflite Power 60 and Glacier 5300 mAh lipos.
I started with a 14x7 prop, which was OK, but like 14x8.5 better when I tried it. A little more speed, which I liked for entering loops etc. Flies vertical as far as I need it to. No noticeable change in flight time. I set my timer at 12:00 and have flown more up to 16 with lots left. I tried some 14x8 wood props (Falcon, Xoar, Fiala). They are quieter, lighter, and more efficient (not at a level that matters much for me and this plane); but overall the APC 14x8.5 was better because the slight different in pitch just feels better. I think the extra noise is nice too because I key on it somehow.
Last prop I tried was a 14x9 Vess, and it's definitely the one for power, but not the best choice for running off a narrow runway in a crosswind (that would be the APC). I ordered more, but will use APC on some days.
I have a sensor that allows me to get real-time data on mAh consumed, and the data says I could fly as long as 14.5 minutes in mixed flying (some cruising, some practicing IMAC manuevers).
I just started flying my second ARF, a Great Planes Revolver 70. Very different, much more athletic, but I still like the Meridian as much as before. I picked up an inexpensive tail-dragger version on ebay (Seagull iSport 10cc) as a backup in case I lost the Meridian, but think if that happened I would build another Meridian.
seldredge is online now Find More Posts by seldredge
Old Aug 14, 2015, 06:03 PM
flyinwalenda is offline
Find More Posts by flyinwalenda
EIEIEIO Classic is dway ta go!
flyinwalenda's Avatar
Northeast Pa. .Heyna or No?
Joined Aug 2009
So I take it you didn't read these posts ?
http://www.rcgroups.com/forums/showp...&postcount=372
http://www.rcgroups.com/forums/showp...&postcount=375
hhttp://www.rcgroups.com/forums/showp...&postcount=377
http://www.rcgroups.com/forums/showp...&postcount=378
flyinwalenda is offline Find More Posts by flyinwalenda
Old Aug 23, 2015, 06:01 PM
wdog is online now
wdog's Avatar
Joined Jan 2012
I did not read the entire thread no as I was just trying to decide on what plane to get and what motor to get and I was making a list of my options.
Discussion Hangar 9 P51 Sport 40 ARF SimAndy Fuel Warbirds 46 Sep 25, 2013 10:25 PM
For Sale Evolution 58cc gas engine with new KS header parts and new Evolution tuned canister Daveyboycfs Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jul 11, 2012 11:33 PM
For Sale Evolution 58cc gas engine with new KS header parts and new Evolution tuned canister Daveyboycfs Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jun 17, 2012 01:02 PM
For Sale Evolution 58cc gas engine with new KS header parts and new Evolution tuned canister Daveyboycfs Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jun 11, 2012 11:07 PM
Sold Hangar-9 Twist 60 with JBA-15 Gas Engine - $200 waynemia Aircraft - Fuel - Airplanes (FS/W) 4 Apr 29, 2012 06:05 PM
