Old Sep 21, 2015, 05:15 PM
DamonH is online now
Find More Posts by DamonH
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
Do these RCB kits include the canopies?
DamonH is online now Find More Posts by DamonH
Old Sep 21, 2015, 08:28 PM
juanjulian is online now
Find More Posts by juanjulian
juanjulian's Avatar
Guatemala, Guate
Joined Jul 2007
Yes
juanjulian is online now Find More Posts by juanjulian
Old Sep 21, 2015, 11:53 PM
sikky is offline
Find More Posts by sikky
speedin n da weeds :)
sikky's Avatar
USA, AZ, Glendale
Joined Feb 2008
Link?
sikky is offline Find More Posts by sikky
Old Sep 22, 2015, 08:04 AM
juanjulian's Avatar
Guatemala, Guate
Joined Jul 2007
Kits in USA
http://shop.rc-electric-jets.com/70-MM-EDF-JETS_c2.htm
Europe
Old Sep 22, 2015, 01:02 PM
sikky is offline
sikky's Avatar
USA, AZ, Glendale
Joined Feb 2008
Thanks !
Old Oct 02, 2015, 09:41 AM
Hadatom is offline
Find More Posts by Hadatom
Joined Jul 2014
I'm new to this thread and have a question. The early CS 10 fan units had 4 stator blades, I purchased a new one and there are many more stator blades. Why is that ? Does it provide more thrust, efficiency , less turbulence ?? I did a simple static thrust test inside an EDF airframe using a 6S battery and a L2855-2100 HK motor and found the early 4 stator blade fan housing provided a bit more thrust. Any answer will be helpful.
Hadatom is offline Find More Posts by Hadatom
Old Jan 28, 2016, 07:29 AM
Yak52Driver is online now
Find More Posts by Yak52Driver
Yak52Driver's Avatar
Australia, VIC, Kyneton
Joined Aug 2015
I recently changed out a Freewing 6 blade fan for the CS10B V3 in my 70mm Starmax Mig-15 using a Leopard 3400Kv inrunner. With the FW 6 Blade I was pulling 67A and 1030W, with the CSV3 I am getting 85A and 1275W, I am able to fit one heatsink to the Leopard (I had 2 on it in the FW housing but the CSV3 housing is much longer and there is not enough can left to fit 2) but worried these power levels may kill it as it is rated max 80A and 1300W. Has anyone else tried this combination and had it last? The Mig was marginal with the 6B as it is a big model for a 70mm unit so I am really hoping the extra thrust of the 10B will give it a bit more performance.
Yak52Driver is online now Find More Posts by Yak52Driver
Old Jan 28, 2016, 07:35 AM
4stripes is offline
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
Can you not cut back some of the housing to make room for the heat sinks? I routinely shorten the 90mm CS shrouds which leaves more room to add heat sinks.
4stripes is offline Find More Posts by 4stripes
Old Jan 28, 2016, 03:40 PM
Joined Aug 2015
Possibly, hadn't thought of doing that but I will look at it. The fan sounds great and after balancing (incidentally using the method you described on another thread) runs very smooth, I am looking forward to flying it and seeing how the Mig performs compared to the FW6B.
Old Jan 28, 2016, 05:27 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
That is a lot of Power (and Amps) for that size of motor! So don't do long WOT runs! hehe
You only need a fraction of that power to fly around 'normal' anyway, so you would fly on more like 500W to 600 W range (700W or so?). So it will do that fine for long term.
It will also be very inefficient at that top end power level. Probably burning 30% (or more) of it as heat!
PeterVRC is offline Find More Posts by PeterVRC
Old Jan 28, 2016, 08:39 PM
Joined Aug 2015
Understood, I am using a YEP100A ESC so it should survive the increased heat of partial throttle flying OK. The Mig flies OK once it is cleaned up and getting some ram air, so hopefully the 10B will get it off a bit quicker and help it get on the step, then as you say I can throttle back and let it cruise.
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7194 Dec 14, 2015 04:03 PM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 08:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 07:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 02:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 10:36 AM
