Old Jan 20, 2015, 03:26 PM
grn_bstrd's Avatar
United States, MO, KCMO
Joined Feb 2012
NTM PROPDRIVE 2836 1400kv need some numbers.
I have a propdrive 2836 1400kv that I have been feeding with a Hobbywing platinum pro 50a V3 on 3s 2200s.
My question is how big of a prop can I run? Can't find any calculators that have this motor in them.
I have been running an APC 8X6 E prop. On a 55deg f day I ran 2 packs at almost full time WOT and measured a motor temp of 103f and an esc temp of 70f. The battery measured 80f. These figures make me think that I'm not getting the most out of my motor.
Specs from HK.
Spec.
Model: NTM Prop Drive Series 2836 1400kv
Kv: 1400rpm/v
Poles: 6
Motor Wind: 10T
Max current: 45A
Max Power: 470W @ 11.1V (3S) / 560W @ 15V (4S)
Shaft: 4mm
Weight: 86g
ESC: 45~55A
Cell count: 3s~4s Lipoly
Bolt holes: 16mm & 19mm
Bolt thread: M3
Connection: 3.5mm Bullet-connector
Prop Test Data:
8x4 - 11.1V / 266W / 24A/ 1.02kg thrust
8x4 - 14.8V / 560W / 38A / 1.48kg thrust
What would be my amp draw on the following props?
1. APC 9X6 E
2. APC 8X6 E
3. APC 8X8 E
4. Master Airscrew 9X6
Thanks in advance.
grn_bstrd is offline Find More Posts by grn_bstrd
Old Jan 21, 2015, 01:23 PM
grn_bstrd's Avatar
Joined Feb 2012
Anyone?
Old Jan 21, 2015, 04:59 PM
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hi
You could estimate your performances when using Scorpion Calc (freeware)
http://www.rcgroups.com/forums/showthread.php?t=736782
Start with the HK2520-1360 and re-edit the Kv (custom motor)
For a 86 g motor, try the prop to get around 260W (ratio 3g/W)
Louis
SC is open to any motor but you have to input Kv, weight, Io no load, Rm(ohm)
Without Io or-and Rm you can try with "typical values" from the closest Scorpion
But an error on the Kv could lead to wrong performances.
Fourdan is offline Find More Posts by Fourdan
Old Jan 21, 2015, 05:22 PM
Y=C+I+G
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
i assume you don't have a wattmeter?
buy one and measure your amp draw.
cmdl is offline Find More Posts by cmdl
Old Jan 21, 2015, 10:57 PM
Joined Dec 2012
This guy says 31 amps/1100 grams, with 8x6. I've been looking at that motor also. Sounds like probably the best bet if you want any run time.
http://fpvlab.com/forums/printthread...9&pp=10&page=2
Dave180 is offline Find More Posts by Dave180
Found NTM 5050 propdrive garrettt04s Aircraft - Electric - Power Systems (FS/W) 1 Dec 17, 2014 12:18 PM
Wanted NTM 2836/2700kv joe559 Aircraft - Electric - Power Systems (FS/W) 0 Nov 21, 2014 01:33 AM
Help! NTM PropDrive 28-36 overheating GLC_Flyer Sailplane Talk 12 Nov 15, 2014 04:11 PM
Sold NTM 2836 1800 kv motors w/ access. NIP plasmaman Aircraft - Electric - Power Systems (FS/W) 0 Nov 12, 2014 12:26 PM
Wanted NTM Propdrive 35-36A 1400kv 550W WANTED!!!!! Kahuna717 Aircraft - Electric - Power Systems (FS/W) 4 Sep 06, 2012 01:24 PM
