Old Aug 19, 2014, 10:01 PM
JakeL17's Avatar
Joined Mar 2014
Build Log
Guillows Stearman
I probably should have started this thread three days ago, when I started the plane, but whatever, that was just the boring part. I am thinking of making my own fuselage for a more scale look, but I might just want to make this a fast build, so whatever.
JakeL17 is offline Find More Posts by JakeL17
Old Aug 20, 2014, 11:25 AM
JakeL17's Avatar
Joined Mar 2014
I don't like the way the cockpit is set up, so I'll probably make a roomy box fuse around a cockpit if I can find enough sticks.
Old Aug 20, 2014, 11:46 AM
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
I have one of these in the box still. I've watched several other builds and recommend infilling between the stringers in the forward part of the fuselage and using heavier LG wire like this:
http://www.wattflyer.com/forums/showthread.php?t=71269
A ton of other conversions here:
http://www.rcgroups.com/forums/showthread.php?t=827861
^^ The last one by Skeletor is a beauty.
warhead_71 is offline Find More Posts by warhead_71
Old Aug 23, 2014, 10:46 AM
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
I built and converted this model many yar ago. Mine went through a rough maiden and series of trim flights. I adjusted top wing for less/zero incidence, flew with a little down elevator and right aileron trim and ended up with a GWS gearbox, brushless inrunner and 3S 800mah lipo just ahead of the landing gear. Nowadays I'd use a small low KV outrunner. The trick is to build light and use a light motor/prop/lipo combo that has adequate power for drag of two wings. Of course receiver and servos should be small and light weight. Mount everything as far forward as practicable to minimize need for nose weight. Setting the correct CG on short-nosed, pitch sensitive designs like this is critical and may require some repairs before you get it right. Use lightweight covering material. Set wheels for slight toe-in. Use your "expert tail-dragger rudder and elevator skills". Raise elevators during start of take off run and after touch down to aid steering and prevent nose-overs. Fly off of smooth surface to minimize flip-over and landing gear damage. Be ready for pitch-up tendency after take-offs. Watch some You Tube videos featuring this challenging model.
E-Challenged is offline Find More Posts by E-Challenged
Old Aug 24, 2014, 08:39 AM
We can rebuild it!
djdavies83's Avatar
United Kingdom, Wales, Swffryd
Joined Apr 2010
This looks interesting :-)
djdavies83 is offline Find More Posts by djdavies83
Old Aug 24, 2014, 06:48 PM
JakeL17's Avatar
Joined Mar 2014
Well, after getting everything together in my workshop, I found that I don't have a motor esc combo that'll work with my stearman, so unless I can come up with something short-term, I'm afraid she might just be a ceiling hanger.
Old Aug 24, 2014, 07:46 PM
JakeL17's Avatar
Joined Mar 2014
Well, I'll show the pictures I took before vacation (just got back). I started drawing up the box fuse, and since I probably can't make this puppy RC, there's really no need to lighten it up, so I'm gonna go with the original fuselage.
Old Aug 26, 2014, 09:41 AM
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Well worth the effort. Cockpit looks great.
Larry
Lnagel is offline Find More Posts by Lnagel
Old Aug 28, 2014, 11:11 AM
Joined Oct 2000
Detailing is nice but keep it light if the objective is nice controllable flight performance.
I need to follow this advice and have often violated it when my addiction to detail takes over.
Old Aug 30, 2014, 08:16 PM
JakeL17's Avatar
Joined Mar 2014
Hard at work with my second cockpit. I have looked, and I do not have the parts to make the Stearman RC, and don't have the money to, so I guess it's destined to spend its life hanging from the ceiling of my local airport.
Old Sep 04, 2014, 06:58 PM
JakeL17's Avatar
Joined Mar 2014
Here's some more pictures
Old Sep 14, 2014, 03:15 PM
JakeL17's Avatar
Joined Mar 2014
Allright, I forgot to do an update in awhile, I'm still grudging away at the second cockpit, I have the fuselage for the most part done, and I will start sheeting when the second cockpit is installed.
Old Sep 14, 2014, 03:40 PM
We can rebuild it!
djdavies83's Avatar
Joined Apr 2010
Looking good, wish I had the time for a wooden kit.
Old Sep 16, 2014, 04:27 PM
CH Spring
Canada, ON, Osgoode
Joined Mar 2008
Looking good.
I will be interested in the electronics fit, and how you rig flight controls.
Cheers!
Spring is offline Find More Posts by Spring
Herr Stearman vs. Guillow's Stearman Admiral Piett14 Scale Kit/Scratch Built 4 Feb 07, 2005 11:03 AM
Guillows Stearman PT-17 NIB JCastle Aircraft - Electric - Airplanes (FS/W) 1 Jan 27, 2003 10:28 AM
"Pearl Harbor " Guillows Stearman conversion finished Bengtson Scale Kit/Scratch Built 7 Apr 18, 2002 02:15 PM
Guillow's Stearman PT-17 NIB JCastle Aircraft - Electric - Airplanes (FS/W) 0 Dec 29, 2001 01:59 PM
Guillows Stearman - Anyone? max z Scale Kit/Scratch Built 4 Oct 08, 2001 02:06 PM
