Old Oct 18, 2014, 12:39 PM
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
Glues
I'm putting together my first sailboat, a Blackhawk 32. The instructions call for testors plastic glue. Question has anyone used goop on the plastic? It should do a better sealing job so I'm wondering if anyone else has used it instead of Testors?
davidjensen is online now Find More Posts by davidjensen
Old Oct 18, 2014, 01:43 PM
Dick L.'s Avatar
Minnesota, USA
Joined Aug 2002
"Goop" tends to stay a bit soft and flexible when I've used it. (glued sole on daughter's horse barn boots).
The boat is probably styrene and that is why they are recommending Testors. Styrene glue is designed to "melt" the plastics and allow then to stick to each other. Available in both tube or liquid.
Dick L. is online now Find More Posts by Dick L.
Old Oct 19, 2014, 02:09 AM
Blackpool, Lancs
Joined Feb 2006
...........and you don't get a better seal than a seam weld like that, especially if you don't leave gaps in the seam.
mfr02 is offline Find More Posts by mfr02
Old Oct 19, 2014, 10:56 AM
Boomer1
Boomer1's Avatar
United States, CA, Temecula
Joined Sep 2009
a little research goes a long way
It is very important to know the material your boat is made out of. There are many different types of adhesives /glues to choose from. It is not that difficult in most cases to find the type of plastic your boat(s) are made of. If the adhesive lable doesn't specify the materials it is compatible with you can contact the manufacturer to get that information.
ABS and Styrene are very common materials used for molding RC boats. Fiberglass is another popular material. Each require a different adhesive. CA and epoxy are often used but depending on the material they are being used on, may not be the best choice.
Just a little research can very helpful. Testing is another proven way to determine how well one adhesive works for you.
Boomer
Boomer1 is online now Find More Posts by Boomer1
Build Log To glue landiging gear or bolt it Taxus812 Balsa Builders 5 Oct 03, 2014 12:47 PM
Discussion Glue nickthegreek Car Talk 4 Sep 23, 2014 03:10 PM
Discussion Glue advise (to glue or not 2 ;-) ) Peter_Pan Composites Fabrication 1 Aug 13, 2014 08:30 AM
Discussion Gorilla Glue or Hot Glue for FT Viggen shambopyro Foamy EDFs 2 Apr 10, 2014 10:38 AM
Discussion Blitzworks RC Sky Surfer V5 Assembly question - Glue or no Glue? pgallett Foamies (Kits) 1 Jan 27, 2014 07:15 PM
