Old Sep 08, 2014, 08:44 PM
Joined Sep 2014
Ft009 Battery
So I've decided that I want to get a Ft009 but I either want to get the upgrade 2700 mah 20c battery, or a LiPo 6s. It would really be great if I could stay under $150. Can I get some help?!.
Gmanrc17 is offline Find More Posts by Gmanrc17
Old Sep 08, 2014, 09:12 PM
Kid at heart..
United States, TX, Houston
Joined Apr 2014
I don't know of any 2700 mah battery that would fit the boat. Also, a 6s battery will burn your esc and motor in less than 1 second.
hangtheman is offline Find More Posts by hangtheman
Old Sep 09, 2014, 06:02 AM
onlyme2's Avatar
United Kingdom, London
Joined Aug 2014
Hello Gmanrc17,
Banggood started stocking a 2800 mAH battery for the FT009.
With their prices, I am sure you will stay within budget.
OM2
onlyme2 is offline Find More Posts by onlyme2
Old Jan 03, 2015, 06:02 PM
Joined Jan 2015
Hello everybody!
I have a ft009 and looking to add another battery in parallel or upgrade the battery.
Does anyone can tell me if there is any post about this?
Onlyme2:
I found this item at the Banggod.com. I have added it to my wishlist, but when I'm gonna place my order the item simply disappeared. Do you know any other place where I can find it?
Thanks!
Schaman is offline Find More Posts by Schaman
Old Jan 04, 2015, 04:54 PM
onlyme2's Avatar
Joined Aug 2014
Originally Posted by Schaman View Post
Onlyme2:
Thanks!
Hi Schaman,
First off, welcome to the forums.
It appears that this battery is currently out of stock at Banggood.
I have Googled the battery and found it available at a few places but for a lot more than what Banggood is charging for it.
You have two viable alternatives I could think of, the first alternative is to email Banggood and inquire when they will stock this battery again.
The other alternative is to get: Turnigy nano-tech 2200mah 2S 40~80C Lipo Pack
http://www.hobbyking.co.uk/hobbyking...6_models_.html
Be aware that the Turnigy battery (which I have used successfully on an FT009) is a very tight fit, and will require that you snap off the front lip of the battery holder, and also snap off a couple of plastic struts on the right hand side of the inside of the hull to allow it to fit. To secure the battery, use a Velcro strap or something similar.
Note that if you decide to go down the Turnigy route, make sure to order the battery from a local HobbyKing warehouse to save on shipping costs.
You will also need to order a plug for the battery and the ESC since the supplied plug with the battery is not compatible with the Tamiya mini plug used on the FT009.
Regards
OM2
Old Jan 13, 2015, 08:38 PM
Joined Jan 2015
Hello Onlyme2!
I found this battery at Banggood.com:
http://www.banggood.com/Giant-Power-...-p-943065.html
It's near the same size, wheight and power. But the price is very cheaper (due to freight, and not the product.)
I'll have to buy the Tamiya mini plug the same way for this battery. Banggood.com have it too.
So What do you think?
Another thing I want to ask you is if the weight balance is not compromised (Left and right I mean).
Thank you very much for the quick response!
Old Jan 14, 2015, 07:57 AM
onlyme2's Avatar
Joined Aug 2014
Hello Onlyme2!
Hello Schaman,
The battery you linked at Banggood would be great, do not worry about left/right battery balance (it would be insignificant with the layout of the FT09), what you need to work out is how far forward/backward you need to place the battery to cancel out porpoising (the front of the boat bobbing up and down), the only way to find the ideal position is by experimenting (remember water/wind conditions will also effect this).
Do not buy a Tamiya mini plug, they are too flimsy, and are prone to melting, since you are replacing the plug anyway go for an XT60 plug (you will also need to replace the plug on your ESC and existing battery and charger connectors).
You can find a 5 pack of XT60 at Banggood (they also do singles, and packs of ten):
http://www.banggood.com/5X-XT60-Male...-p-916559.html
Don't forget to order some shrink tube as well if you don't have some already lying around.
Regards
OM2
Mini-Review The Vitality FT009 review jameschen072 Micro and Sub-Micro Boats 1468 Jan 27, 2015 08:08 AM
Discussion Cheap RC Boating $60 Vitality FT009 Unboxing makuloco2000 Micro and Sub-Micro Boats 3 Jan 25, 2015 07:20 AM
Discussion Feilun FT009 2.4GHz Water Cooling RC Boat subpixel Hot Online Deals 4 Mar 28, 2014 09:34 PM
Mini-Review fei lun ft009 mods.. daus malaysia Micro and Sub-Micro Boats 2 Mar 24, 2014 11:34 AM
Discussion Vitality FT008 and FT009 with 18650 batteries jlogres Micro and Sub-Micro Boats 0 Mar 20, 2014 02:29 PM
