Old Oct 19, 2005, 02:26 PM
Robots... robots everywhere
minifly's Avatar
Cape Town, South Africa
Joined Jan 2003
Help!
Main output transistor on TX burnt out -- C4735 equivalent?
It seems that I have burnt out the main output transistor on my JR-X378 TX, and was wondering if there is an equivalent, (preferably something that runs a bit cooler ) for the C4735.
I have looked around and cannot find it at any of my local dealers.
I would send it back to JR, but have passed my warrenty, so i have nothing to lose.
Please remember that I live in South Africa, this is a 35mHz tx
Minifly
minifly is offline Find More Posts by minifly
Old Oct 19, 2005, 03:19 PM
York Electronics
Gary Warner's Avatar
Dallas Tx USA
Joined Apr 1999
Here's the data sheet. No NTE.
Here for $1.99 ea..
Gary
Gary Warner is offline Find More Posts by Gary Warner
Old Oct 19, 2005, 06:51 PM
Switzerland
Joined Sep 2005
try 2N4012, 2N3866, 2N4427
But don't blame me if they get hot! to avoid this check out their datasheets and compare the currents and powers.
If you have a CB Radio you could also rob its transistor (or see what type it is), as the 2sc4735 is a standard CB PA transistor.
diego
dj2u is offline Find More Posts by dj2u
Old Oct 19, 2005, 07:34 PM
Switzerland
Joined Sep 2005
2SC2078 is such a cb transistor.
have you a cb repairshop near you? maybe they will sell you one?!!
Old Oct 20, 2005, 04:08 AM
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Be brutal - my first 27Mhz tranny that WORKED cranked out about 3.5 watts with a BFY51 - able, in its metal can, to do it without cooking...
Within limits any NPN silicon RF transitsor will WORK with a bit of a retune ...maybe more, or less, powerfully..and efficiently.
Old Oct 20, 2005, 07:13 AM
minifly's Avatar
Joined Jan 2003
decided to go with 2N3866, due to availability and another recommendation by email.
i will tell you how it goes, thanks for now
Old Oct 21, 2005, 06:05 AM
dieselburner
andrew b's Avatar
Wyke, Bradford, west yorks
Joined Mar 2005
The BFY series were great, I used them for RF power and for medium current switching (relays), I "rescued" my supply of BFY's from the CRT base of early color TV's where they served the purpose of color drives.
andrew b is offline Find More Posts by andrew b
Old Oct 21, 2005, 07:20 AM
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
Hi, Minifly
European Classics are ( output power order ) : 2N2219A , 2N 4427, 2N 3866 , 2N 3553 , 2N 3375
Note a BD 137 works great too ... ( yes, yes ... try it before laughing !!! )
Alain
Acetronics is offline Find More Posts by Acetronics
Old Oct 21, 2005, 12:50 PM
North East England UK
Joined Jan 2003
Minifly,
As you live in SA, have you tried Maplins...?
( I lived there some 20 yrs ago and they were just dipping their toes in the water...they have since established various branches...)
If Maplins fail you, where are you in SA...? I recall there were a few electronics suppliers in J'berg......
Ah Cape Town........
Chippie is offline Find More Posts by Chippie
Old Oct 21, 2005, 01:28 PM
minifly's Avatar
Joined Jan 2003
I got the 2n3688 from communica, installed, and everything is working fine now
The current limiting resistor is 3.2 ohm, if i put a heat sink in would it be safe to use a 2.2 ohmm one instead? I know that the range would be increased alot, but would this cause any problems with stuff like harmonics and interference for other people on adjacent channels?
Old Oct 21, 2005, 01:48 PM
Terry S's Avatar
Bridgwater, UK
Joined May 2003
I used a BD139 on mine.
Terry
Terry S is offline Find More Posts by Terry S
Old Oct 21, 2005, 02:39 PM
MAVA's Avatar
El Dorado Hills, California, U.S.A.
Joined Mar 2000
Minifly,
In my old Ace Radio had the similar problem, All I did is replaced the trasistor with the original got the RF deck re-tuned and added a heatsink with thermal (add very little so it looks transparent-more compond is worse)compond.
No problems since that happend..
Martin
MAVA is offline Find More Posts by MAVA
Old Oct 21, 2005, 04:35 PM
minifly's Avatar
Joined Jan 2003
chippie,
maplins has been bought out by yebo electronics ( http://www.fort777.co.za ) and they were the first people i checked. after that i checked communica, and they only had the 2n3866, so i went with that
Old Oct 21, 2005, 04:49 PM
Oxford Panic
AndyOne's Avatar
United Kingdom, Oxford
Joined Feb 2003
I used the 2N3866 as a final o/p on transmitters at 144mHz, it gave at least a Watt so it should be more than adequate for 35MHz RC.
Andy.
AndyOne is offline Find More Posts by AndyOne
Old Oct 22, 2005, 04:10 PM
minifly's Avatar
Joined Jan 2003
well, i tried the 2.2 ohm and suddenly things started going wrong: the 2n3688 started REALLY heating up, and my range went way down as well.
at first i thought that the circuit was just out of tune, so i fiddled with the pot and coil, but the range was still WAY worse than before (even worse than with the old 2sc4735 burnt out). I put the 3.2 ohm back, and everything is great again. Maybe the gate is drawing too much and distorting the signal? Or I'm out of the linear curve of the 2n3866 and peaked it out/got a bit too close the the peak, and into part of the non-linear curve?
anyway, everything is fine, and i'm up and running again.
Thanks to all who contributed.
Main output transistor on TX burnt out. Need replacement chileno DIY Electronics 2 Oct 27, 2005 05:33 AM
Need help with burnt transistor on prolux lipo charger ddekel Batteries and Chargers 7 Jun 24, 2005 05:13 PM
Burnt out again, any help on DIY speed controllers? Pete123 Power Systems 20 Jun 10, 2003 11:59 AM
Output signal on Tx RookieOne Radios 6 Mar 25, 2003 10:27 AM
4 Flights on the Motor in projeti kit and already burnt out kushal_22 Foamies (Kits) 0 Jun 25, 2002 04:39 PM
