Old Apr 29, 2013, 10:04 AM
Master of Micro Modding
valiantGLX's Avatar
Australia, SA, Burra
Joined Sep 2011
New Product
Hobby King Relentless & Aquaholic Brushless 740mm
Here are two exciting new products from Hobby King.
HobbyKing Product Video - Relentless & Aquaholic Race Boats (1 min 32 sec)
HobbyKing Daily - Aquaholic Relentless Race Boats (3 min 44 sec)
Quanum Aquaholic Brushless Deep V
The Quanum Aquaholic is the ultimate Deep V Racing Boat offering high speed, excellent handling and killer good looks. The vibrant race inspired paint scheme and expertly applied decals are sure to turn heads wherever you go!
Quanum Relentless Brushless Catamaran
The Quanum Relentless is the ultimate Catamaran Racing Boat offering high speed, excellent handling and killer good looks. The vibrant red paint scheme and expertly applied racing decals are sure to turn heads wherever you go!
valiantGLX is offline Find More Posts by valiantGLX
Old Apr 29, 2013, 10:05 AM
valiantGLX's Avatar
Joined Sep 2011
Quanum Aquaholic Brushless Deep V Racing Boat 740mm (ARR)
Aquaholic
Features:
High performance watercooled brushless power system
Vibrant race inspired paint scheme
Lightweight ABS hull
High torque steering servo
3mm direct drive flex shaft
Powered by a 3S 2200mAh lipoly battery pack (sold separately)
Almost Ready to Run - simply add your own radio system and battery
Specs:
Overall Length: 740mm
Hull Length: 650mm
Beam: 180mm
Weight: 1140g (w/out battery)
Motor: Watercooled 2815 brushless outrunner (included)
ESC: 50A watercooled brushless (included)
Servo: High torque standard size (included)
Hull Material: ABS
valiantGLX's Avatar
Joined Sep 2011
Quanum Relentless Brushless Catamaran Racing Boat 740mm (ARR)
Relentless
Features:
• High performance watercooled brushless power system
• Vibrant race inspired paint scheme
• Lightweight ABS hull
• High torque steering servo
• 3mm direct drive flex shaft
• Powered by a 3S 2200mAh lipoly battery pack (sold separately)
• Almost Ready to Run - simply add your own radio system and battery
Specs:
Hull Length: 650mm
Beam: 210mm
Weight: 1200g (w/out battery)
Hull Material: ABS
Old Apr 29, 2013, 10:24 AM
valiantGLX's Avatar
Joined Sep 2011
I'm definitely going to buy one of these beauties, but I haven't decided on which one yet
Which one would you guys 'n' gals buy and why?
Old Apr 29, 2013, 12:35 PM
Vancouver, BC
Joined Aug 2009
Nice boats! I would go for the v hull, but that's just because I think they look better. Rough water handling is supposed to be better as well.
Firehawk989 is offline Find More Posts by Firehawk989
Old Apr 29, 2013, 12:42 PM
valiantGLX's Avatar
Joined Sep 2011
They sure are Personally I like the look of the cat better, there's more room in the hull and supposedly they run faster. However I already have a cat and I flip the darn thing over all the time (it is a monster though, half the size of these new boats with twice the motor ).
So in hindsight I think I would go the deep v too, I definitely want to treat myself to a good handling boat for a change ...And nothing beats the look of a v-hull banking in the turns
EDIT: actually my little boat has 4x the motor of the relentless and aquaholic, it runs a 2858
My modified Sea Rider running video.avi (1 min 59 sec)
Old Apr 29, 2013, 12:59 PM
Vancouver, BC
Joined Aug 2009
https://www.youtube.com/watch?v=-Ma7yJHUa6A
Quick little boat!
Try moving the battery forward a bit and it should bounce less and be more stable. If you can't move the battery forward, put a bit of lead in the nose until it calms down. It shouldn't be bouncing around that much, especially in the turns.
Old Apr 29, 2013, 01:35 PM
valiantGLX's Avatar
Joined Sep 2011
Quick little boat!
It runs better now than it did in the vid. I added trim tabs and halved the battery size, now the extreme torque is the only thing I am fighting, but I have a set of 4 2-blade props on the way, ranging from 28mm to 35mm (which should be better than a great big 3 blade prop).
However even if I get it running perfectly, I still want something a little bigger and something that handles better.... Thats where the Aquaholic comes into play
Old Apr 30, 2013, 09:23 AM
Expecting Failure
Canada, ON, Greater Sudbury
Joined Mar 2013
The cat looks to be a direct copy/ oem as the LiteHawk Challenger. (Litehawk is a small canadian rc hobby brand)
http://www.litehawk.ca/CHALLENGER.asp
St3alth_Frenzy is offline Find More Posts by St3alth_Frenzy
Old Apr 30, 2013, 12:21 PM
wparsons's Avatar
Canada, ON, Markham
Joined Aug 2008
If anything the Litehawk one is from the same supplier, but I doubt HK copied Litehawk since they're such small company.
wparsons is offline Find More Posts by wparsons
Old Apr 30, 2013, 12:43 PM
valiantGLX's Avatar
Joined Sep 2011
While they sure look the same the relentless is supposedly 6cm longer.
The challenger sure looks like it handles well in that vid, which is making me sway towards the Relentless again, but despite the before the mentioned I think I'll still get the the Aquaholic
Old Apr 30, 2013, 12:46 PM
valiantGLX's Avatar
Joined Sep 2011
Has anyone noticed the difference in the motor mounts? It looks to be easier to add a longer motor (2858 for example) to the Aquaholic. Also the Aquaholic looks to have a mount for the battery while the relentless uses velcro.
Old Jun 02, 2013, 02:53 AM
miketre's Avatar
Joined Dec 2010
I received my Aquaholic last week and maidened it this weekend. I like it
I'm thinking about the relentless now.
Quanum Aquaholic Brushless Deep V Racing Boat 740mm (3 min 56 sec)
miketre is offline Find More Posts by miketre
Old Jun 02, 2013, 04:31 AM
valiantGLX's Avatar
Joined Sep 2011
http://www.youtube.com/watch?v=Q1aTd73-E3I
Sweet vid Is it stock?
I was just about to pull the trigger on one, but I did the math and after the postage and 19% tax (in Germany) it's a bit too expensive for me So I'm eagerly waiting for it to land in the EU warehouse
Old Jun 02, 2013, 05:36 AM
miketre's Avatar
Joined Dec 2010
Yes, it is totally stock. I just pulled the trigger on the relentless.
Will have videos of that when I received it, hopefully in 2 weeks.
Discussion Terrible Customer Service from Hobby King jtown HobbyKing 11 May 02, 2013 01:10 PM
Wanted Hobby King 40A Blue series Brushless Esc akatfpv Aircraft - Electric - Multirotor (FS/W) 0 Apr 21, 2013 08:46 AM
For Sale Hobby King Brushless motor salrica Aircraft - Electric - Power Systems (FS/W) 0 Apr 20, 2013 09:26 PM
Discussion Hobby king esc's ?? mskeyspirate Power Systems 29 Apr 01, 2013 06:46 AM
Help! Need Manual for Hobby King 60A ESC ddemu HobbyKing 7 Mar 30, 2013 04:31 PM
