Old Yesterday, 02:49 PM
Sunbiz1 is offline
Find More Posts by Sunbiz1
United States, IL, Elgin
Joined Apr 2015
Replacing Inadequate Landing Gears?.
Hi everyone,
I have a Corsair that has outgrown the stock set-up due to added weight. Today I flew twice, and nosed over twice upon landing. I am almost certain this is due to too much flex in the wires serving as gears/struts.
http://www.horizonhobby.com/landing-...sair-s-hbz8206
This is the original, which when snapped into the wing assembly makes them permanent. They will have to be cut out of the wing. This is not a problem, I'm good working with expanded polystyrene(foam).
What I'm not sure of is which type of assembly would be best as the replacement?.
Using common logic, if I have added 40% weight to the plane, would using a wire assembly at a 40% thicker diameter resolve my issue?.
Also, I chased a hawk today
They do not like RC planes messing around in their territory.
TY in advance for any assistance.
Sunbiz1 is offline Find More Posts by Sunbiz1
Old Yesterday, 04:02 PM
failboat is offline
Find More Posts by failboat
yank and bank!!
Joined May 2013
Prepare for endless browbeating from some forum types about how you shouldn't do that....
failboat is offline Find More Posts by failboat
Old Yesterday, 04:32 PM
Sunbiz1 is offline
Joined Apr 2015
The hawk started it.
Old Yesterday, 07:29 PM
Sunbiz1 is offline
Joined Apr 2015
Edited
Old Yesterday, 09:45 PM
yorkiepap is offline
Find More Posts by yorkiepap
yorkiepap's Avatar
SW PA
Joined Aug 2010
Hey Sb1,
Here are a few pics of my modified LG on my 1000mm F4U. The stock wire was crappy, not long enough, & not enough forward rake could be obtained. I removed the plastic LG inserts, opened the LG plastic mount area, epoxied in a piece of 1/2" thick laminated wood in each wing. I then cut (2) lengths of .148" steel rod & bent to the proper angles for welding to the steel plates that were screwed to the laminated inserts. I used larger tires for our grass field & bent the wire for a slight outward & forward rake. The wheel axel is flush with the leading edge & grass t/o's & landings are no issue anymore. Maybe this can give you some ideas for your own mods.
Denny
yorkiepap is offline Find More Posts by yorkiepap
Old Today, 07:30 AM
Leo L is offline
Find More Posts by Leo L
United States, NY, Queens
Joined Oct 2005
First, the landing gear on your Corsair are not permanently installed. You can remove then my doing the opposite of what you did to install them. Hold the wing and wing plate firmly in one hand. Take the strut in the other hand and rotate it away from the latch. Give it a firm tug and it will release, Rotate it completely free of the plate's catch and then pull the strut's stub out of the plate.
I don't think that you need heavier gauge struts. What you need is to do a rough field modification to your existing landing gear. First, replace the stock wheels with larger diameter but thinner wheels. I use DuBro 2.5" Micro Sport Wheels, but 3" would be even better. Then bend the struts forward so that when you stand directly over the plane and look straight down, the entire wheel is visible in front of the wing's leading edge. Basically, you need to move the wheels about 1 1/2" forward of their current location.
Leo L is offline Find More Posts by Leo L
Old Today, 09:29 AM
Sunbiz1 is offline
Joined Apr 2015
Originally Posted by yorkiepap View Post
Hey Sb1,
Denny
My foot tastes bad with respect to my posting lack of knowledge on this site.
What an awesome modification you performed!, wish I had the welding skills/equipment. Larger wheels and bending wires were tried. And I just noticed another problem. One of the plastic inserts holding the assembly is cracked, couldn't see it until I started moving things around.
How much does your plane weigh?.
And thank you for the ideas, as finding pre-made gear assemblies for this plane is proving to be more of a challenge than I had originally thought.
Old Today, 09:42 AM
Sunbiz1 is offline
Joined Apr 2015
More good info, thank you.
The stock strut is not long enough to bend that far forward, won't have enough ground clearance for the larger prop I'm using.
Sold NIP Blade 350QX replacement body with NIP Tall Landing gear. phoneguy Aircraft - Electric - Multirotor (FS/W) 0 Jul 11, 2014 08:52 PM
Sold NIB Blade 350QX replacement body with NIP Tall landing gear phoneguy Aircraft - Electric - Multirotor (FS/W) 0 Jul 09, 2014 09:31 PM
Sold DJI Phantom 2 Vision Replacement Stock Landing Gear helifreak592 Aircraft - Electric - Multirotor (FS/W) 0 Feb 27, 2014 08:43 PM
Discussion Need a replacement landing gear for GP SUPER DECATHLON 40 JBG7676 Fuel Plane Talk 1 Jan 03, 2014 05:55 PM
For Sale Brand new QAV500 replacement arm/Landing gear marluzkat Aircraft - Electric - Multirotor (FS/W) 0 Dec 09, 2013 06:12 PM
