Old Aug 02, 2015, 06:51 AM
eligri is offline
Find More Posts by eligri
Joined Sep 2012
Help!
KK-mini flying wing
I'm trying to setup a KK-mini to work with my flying wing. Im using a spektrum transmitter and receiver.
The firmware im using is: OpenAero2 beta 10 for KK-mini.
Here is the problem: KK-board looks to be setup and ready for use. Receiver input responds to transmitter, and no error messages are displayed. However, the plane does nothing when using transmitter.
It seems like it isn't armed, or something like that.
What am i doing wrong?
Wiring as such:
Left side of board; Lower 3 pins --> throttle channel receiver, 3 above it --> aileron, rudder (not being used) and elevator on receiver.
Right side of board: Esc --> slot 1, Aileron --> slot 2, Elevator (aileron 2) --> slot 3.
eligri is offline Find More Posts by eligri
Old Aug 02, 2015, 08:29 AM
Azarr is offline
Find More Posts by Azarr
Old age is not for sissies
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
I don't have the mini, but the larger board requires arming. Throttle stick down & right to arm, down and left to disarm. YMMV.
Azarr
Azarr is offline Find More Posts by Azarr
Old Aug 02, 2015, 09:04 AM
eligri is offline
Joined Sep 2012
Got it working already thanks to some help from a good hobbyking rep
Now i have a new problem though. The plane is treating each elevon as a seperate channel. They are plugged into ch 6 and 7.
With aileron only 1 moves, and with elevator the other one moves. They are not mixing at all.
Got it set as "flying wing" in mode, done no custom mixing.
Old Aug 04, 2015, 03:27 AM
eligri is offline
Joined Sep 2012
Bump.
Anybody know what is causing each elevon to move on separate channels (not mixed)? Elevator moves one, aileron moves other.
Old Aug 05, 2015, 09:02 PM
Grantham Kid is online now
Find More Posts by Grantham Kid
Chasin' that Neon Rainbow
Grantham Kid's Avatar
Australia, QLD, Grantham
Joined Oct 2012
Not sure why you used a KK board. A P1 gyro is a far better option for a wing and more compact. (and cheaper) also cleaner wiring and made for the purpose.
Grantham Kid is online now Find More Posts by Grantham Kid
Old Aug 06, 2015, 04:08 AM
eligri is offline
Joined Sep 2012
I used it because it costed 10 dollars, and I was making a hobbyking order anyways. Nobody knows why it is doing this?
Old Aug 06, 2015, 08:25 AM
andreiv is online now
Find More Posts by andreiv
Joined Sep 2014
Hi eligri,
I had KK2.1.5 with OpenAero2, and it worked just fine. I don't remember exactly, but i think i did mixing in the radio. After you've done that, just switch stabilize profile on, and see if KK is moving elevons in the right direction when you shake the plane. If not, you can reverse gyro direction in some menu, if I remember correctly.
andreiv is online now Find More Posts by andreiv
Old Aug 06, 2015, 02:00 PM
eligri is offline
Joined Sep 2012
Thanks!
Kinda got it working now. Everything moves right via controller, but only EITHER elevator or aileron will move right with gyro's (which one depends on servo reversing). Is there any way to reverse the gyro only, so that both will work?
Help! Micro Mini Wing 1s power barely flying balthazar420 Flying Wings 14 Jun 30, 2015 08:53 PM
News HobbyKing Mini Sonic Flying Wing Jason Cole Flying Wings 4 Jul 10, 2014 07:23 AM
Discussion Mini Wing aerobatic slope flying Phuket, Thailand Nimbus Dave Flying Wings 0 Feb 15, 2014 06:13 AM
Help! KK 2.0 Set Up For Flying Wing HughesBrothers FPV Talk 4 Aug 31, 2012 03:14 AM
Yippee! EDO Delta-Wing MINI FLYING WING nice flying Allen1023 Flying Wings 32 Nov 11, 2008 12:21 PM
