Old Oct 08, 2014, 09:08 PM
RC Newbie with lots of ideas
Chile, Santiago Metropolitan Region, Stgo
Joined Dec 2012
Question
RG65 swing rig plans
Hi all!
I am looking for swing-rig sail plans for my RG65, for smaller B and C rigs. I already got the one from Frank Russel/Goth 65, but I'm not sure about them, so I'm looking for options... Any plan is welcome!
Thanks!
tarmstro is offline Find More Posts by tarmstro
Old Oct 08, 2014, 11:27 PM
United States, FL, Indialantic
Joined Jul 2008
rg65 info
http://www.rg65usa.org/home.html
Eric rosenbaum has an article on the us Rg website
ktm500mx is offline Find More Posts by ktm500mx
Old Oct 09, 2014, 08:03 AM
Joined Dec 2012
Thanks Mike, he shows how to build them, but there are no plans there... I need measurements for different rig sizes...
Old Oct 09, 2014, 08:43 AM
huzway's Avatar
United States, MD, Silver Spring
Joined Feb 2009
I made the goth 65 B and C. did pretty good for me, till the cross broke on the C.
The Dallas R5 was blowing last year. got 7th, some of the best were there.
Craig
Originally Posted by tarmstro View Post
Hi all!
Thanks!
huzway is offline Find More Posts by huzway
Old Oct 09, 2014, 10:52 AM
Joined Dec 2012
Craig
Let's discuss....
I already built the A-rig from Frank Russel, with excellent results I must say. I was planning using his designs for B and C-rigs... but...
To mee, for higher winds what you need is less heel. This is done by lowering the CE, i.e. shortening the mast. But to keep same power, you actually need to increase sail area, by making the booms longer... but this again make the boat heel more... so you have do decrease sail area anyway.
Frank's B and C-rigs keep booms same length as A-rig, which for me is a too big decrease in sail area. Other folks around here use longer booms for their smaller rigs, with better results. That's why I was looking at alternatives...
As I am no expert, I do not want to create my own design and have to go to throught the complete development cycle...
Old Oct 09, 2014, 02:07 PM
Dick L.'s Avatar
Minnesota, USA
Joined Aug 2002
Go to RCSailing.net and look up Claudio's swing rig sail dimensions.
Sorry, can't get to the site for a link at the moment.
Dick L. is offline Find More Posts by Dick L.
Old Oct 09, 2014, 03:26 PM
huzway's Avatar
Joined Feb 2009
Here are franks goth sails stacked A-B-and C.
I think he did a really good job of keeping the CE the same front to back and you can see how they get lower on each.
I just don't get to use the B and C much.
Let's discuss....
Old Oct 09, 2014, 03:40 PM
Joined Dec 2012
I agree he did a good job. My A-rig is doing great! But if you add a little mode "cloth" at the clew, I think you would get more power for little heel... without affecting CE position... Am I crazy?
Old Oct 09, 2014, 03:57 PM
Auckland New Zealand
Joined Sep 2010
These are the Goth sails with measurements, classic and swing rig. Both in A, B, C sizes.
KIWINB is offline Find More Posts by KIWINB
Old Oct 09, 2014, 05:12 PM
Joined Dec 2012
Ok, I am building a RG65 rig comparison chart here...
https://docs.google.com/spreadsheets...it?usp=sharing
Fourth column shows what % of maximum allowed sail surface is each rig, so it gives a sense of "size". Note on column headings explain what is what.
Any additions welcome!
Old Oct 14, 2014, 10:58 AM
Joined Dec 2012
Decision time. So, I took a practical approach to choosing what kind of smaller rigs I want. Goals:
  1. Have smaller rigs for use when wind is too strong for 2250 sqcm A-rig
  2. Minimize heel (force perpendicular to hull)
  3. Maximize power (force longitudinal to hull)
Yes, pretty obvious and contradicting goals... So I took a look at my current A-Rig and got to think: how do I make it smaller? I simplified the problem by looking at it as a simple 2 parameter/2 outputs problem. Parameters are mast height and foot length, outputs are heel and power forces.
My thinking is:
  • A-rig goal is to maximize power with little concern on heel. So it is as high as it can be, and with an even surface distribution. Hence, Frank Russel A-rig design looks almost perfect for this: just vertical wing, with a curve at the top.
  • Frank Russel designed smaller rigs by just shortening the mast, but keeping sail foot same length as the A-rig. Short mast + same foot = smaller sail area than A-rig. Radically smaller sail area!
  • Chris Jackson took another approach: he shortened the mast but kept same sail area. Short mast + long foot = same sail area than A-rig. Radically longer foot length!
  • Both approaches tackle the heel problem: in both cases CE is lower than before. But there are differences. Comparing same mast length, Frank's design has low power/low heel, Chris's has high power/high heel.
In my opinion these two designs are too extreme: one keeps foot length fixed; the other keeps sail area fixed. Somewhere in between there should be an optimum.
Then I took a look at what winners are using: Pedro Stier in Brazil, Andres Lioi here in Chile. Both are using rigs that look in between solutions. Their designs use a longer foot (but not too long), and shorten mast so that sail area is reduced, but not that much (around 13% from A to B and from B to C-rigs).
So I took these ideas and started building my C-rig, similar to what Andrés uses (I sail same places as he does )
Hopes this rationale makes sense and helps others.
Camber and building details? That's another story altogether! This was only about overall sail shape...
Old Oct 14, 2014, 12:03 PM
Joined Jul 2008
rig designs
I have a skinny from brazil and the b-rig is a lower aspect same sail area as the
A-rig. The c-rig is a lower aspect slightly smaller sail area rig.
will try to post pictures.
Old Oct 14, 2014, 01:05 PM
Joined Jul 2008
sail pics
pictures of my skinny rigs
mike
Old Oct 14, 2014, 02:56 PM
Joined Dec 2012
Thanks a lot mike! Would you like to share some measurements? You should be able to take them from your certificate... (main foot, main height, jib foot, main area, jib area)
For Sale Carbon Fiber Marblehead 50-800 Swing Rig. breakwater Boats (FS/W) 1 Jun 06, 2014 10:16 PM
For Sale Marblehead Swing-Rig Sails breakwater Boats (FS/W) 1 May 22, 2014 09:08 PM
Cool An RG65 that is 3 Sail rig capable. bill dewey Sailboats 6 Aug 26, 2012 07:56 AM
Sold Marblehead Class A+ Swing Rig Sails breakwater Boats (FS/W) 2 Feb 01, 2012 10:33 PM
Discussion Can you explain the Footy Swing Sail rig..... ROADTOAD Sailboats 5 Jul 27, 2006 12:23 AM
