Old Yesterday, 06:29 PM
Joined Jun 2014
DX5E Question!
Im resurrecting an old PZ Decathlon, and I set it up with ailerons....it was originally rudder only....im using a DX5E TX with an AR6100E Rx.....I have a servo per aileron tied together with a Y harness, then plugged into the aileron port on the RX........its not working, only the right aileron works........ive set up other planes this way with my DX6i, can I not do this with my DX5E? What am I doing wrong? Many thanks! Bill
Bill Gibson is online now Find More Posts by Bill Gibson
Old Yesterday, 07:19 PM
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
It has to be a bad "y" or servo, or connection. Check that one servo is connected backwards.
Try each servo with out the "y".
This is why I like to connect all the parts I will be using on a plane on the bench before installing
in the plane, rec, extension, y's, servos. esc, motor without the prop. Then I know all is working
and the servos are centered. I also make sure the motor is turning the proper direction and
mark the leads with a small piece of shrink tube.
Kimber is online now Find More Posts by Kimber
Old Today, 01:12 PM
Joined Jun 2014
Kimber, you ROCK!!! upon inspection of my Y harness, sure enough one of the pins in the connector to one of the servos had "popped"out of the back side of the pin case!!! Pushed it back in till i heard a little SNAP, and BAM! Everything is OPERATIONAL! You are ABSOLUTELY RIGHT about pre checking stuff before you install it! Im normally ANAL about this, but got in a big hurry and it just doesnt pay! THANK YOU SO VERY MUCH! Oh, and ....not an HK fan either!
Discussion Spektrum dx5e questions Runpaulone Radios 3 Jan 14, 2014 01:29 PM
Discussion Question re DX5e to PC/Phoenix Flight Sim Link BSquared18 Radios 0 Nov 30, 2013 08:34 AM
Discussion DX5e question steve riall Electric Heli Talk 0 Nov 03, 2013 11:20 AM
Wanted dx6i tx module vrs dx5e module question helizrnew2me Aircraft - General - Radio Equipment (FS/W) 1 Oct 19, 2013 01:29 PM
Discussion USB Cable for DX5e (Noob question) Swanson Simulators 3 Oct 13, 2013 07:50 AM
