Old Sep 23, 2014, 01:40 PM
Joined Sep 2014
Quadcopter Build As Senior Project
Hi Guys,
I will make a quadcopter as senior project. I read many articles about quadcopters I chose some parts of quadcopter. I want to ask if these parts compatible each other.
Frame
Motor
Propeller
ESC
Battery
Besc Programming Card
IMU
Transmitter/Receiver
Microcontroller
I also want to have FPV. How camera should I choose? I want good quality and it shouldn't be over 100$
Transmitter/Receiver for FPV
_MeRKeZ_ is offline Find More Posts by _MeRKeZ_
Old Sep 23, 2014, 03:38 PM
Joined Apr 2013
A comment and a question:
Check you motor choice. You should be able to check motor, ESC, prop and battery combinations at ecalc.ch. A quick adding of your components in my head yields an AUW around 1.2kg or more. My gut says 'too high a KV rating on the motor'. In general for heavier models of that size you may be be better served with a lower KV rating. But ecalc will help you validate that.
Is there a code base for quad copters that you can port to your chosen microcontroller? I'm just not familiar with that processor and whether you are writing your own code or not.
jeffjblack is offline Find More Posts by jeffjblack
Old Sep 23, 2014, 03:51 PM
AlPackin's Avatar
United States, CT
Joined Mar 2011
As far as your flight controller goes the closest code base would be the Flying F4 from Tau Labs. It pre-dates the dev board you are using however and is designed around a shield (breakout board) that contains the gyros and accels. I bought a few of the boards that you are using in hopes that a developer would build a simple shield and do the coding changes that would be required. Do you have the programming capability to do this? I'm sure that you could get all the help you would need from a super group of developers.
https://github.com/TauLabs/TauLabs/wiki
scroll down to targets to the Flying F4
AlPackin is offline Find More Posts by AlPackin
Old Sep 23, 2014, 04:13 PM
AlPackin's Avatar
United States, CT
Joined Mar 2011
The Tau Labs code base would give you fully autonomous flight control as well.
Old Sep 24, 2014, 02:31 AM
Joined Sep 2014
Thanks for your replies.
I changed motor. I chose SunnySky 800 Kv. I also put these values in eCalc.
BTW, Flying F-4 sounds good, I will make a search, thanks for information
Edit: I'm thinking of buying PZ0420 Camera
Are my frame, motors,props suitable with this camera?
Help! Quadcopter Build Check For Project UniQuadProject Scratchbuilt Multirotors 5 May 23, 2014 09:21 AM
Discussion Project Mini-H Quadcopter - build / photo / video! World Citizen Scratchbuilt Multirotors 4 May 10, 2014 05:50 PM
Discussion Senior Project Build! scubaru89 Scratchbuilt Multirotors 9 Apr 02, 2013 10:44 PM
Discussion Need Help Guys- building QuadCopter For School Project! MD2 Multirotor Talk 0 Sep 06, 2012 02:22 PM
Discussion I want to build a quadcopter for my school project lazer155 School Projects and Competitions 7 Apr 20, 2011 08:28 AM
