Old Mar 30, 2015, 11:26 PM
Joined Sep 2008
any one did this work with dsx7(dx7)?
i can bind with x4, so i think my problem is with ppm on dsc port(trainer)
i used the 10k voltage divider, but not work at all
tclima is offline Find More Posts by tclima
Old Mar 31, 2015, 05:37 AM
I Void Warranties
goebish's Avatar
France, Aquitaine, Bordeaux
Joined Feb 2010
Remove the resistor going to ground in the divider (leave only the one in serial) then it should work, that's because PPM output level is 3.3V on Spektrum radios, if you use a 1/2 voltage divider, only 1.65V goes to the AVR, which is not enough to pull the input HIGH.
You may have to set endpoints too.
goebish is online now Find More Posts by goebish
Old Yesterday, 03:25 PM
Joined Jan 2015
Hi Midelic,
I have a problem with your Recepter. I tested your 5 programs and none on work. I can't bind except for the "Hubsan_RX_ppm_M328_16Mhz" where ppm does not. Furthermore the ppm is inversed.
Would it be possible to have the sources to correct and test directly.
tipouic is online now Find More Posts by tipouic
Mini-HowTo DIY "FlySky" TX/RX module midelic DIY Electronics 2317 Mar 20, 2015 10:04 AM
Found WANTED: FUTABA TP-FSM 72MHz Synth RF Module svjerk Aircraft - General - Radio Equipment (FS/W) 1 Jun 28, 2013 09:44 AM
Discussion DIY Telemetry System base on TI CC110L RF BoosterPack spy004 DIY Electronics 2 Mar 06, 2013 07:58 AM
Discussion FrSky 2.4G DIY RF Module into JR XP 7202 kriss poppe DIY Electronics 5 Jun 04, 2011 08:39 PM
