Old Jan 16, 2015, 01:49 PM
Joined Jan 2015
Hi Mike!
Thanks for the link but I already chewed myself thru the whole topic.
Just want to know that if I replace the motor for the mentioned one than just need to make 2 bigger holes on the mount and thats it.?.
That was not 100% clear for me.
The ESC is another question but I will see how it's handle that motor.
I have this car ESC btw.: http://www.hobbyking.com/hobbyking/s...s_Car_ESC.html
Still waiting HK for replacing my motor or at least answer stg about it.
Cheers!
c6doki is offline Find More Posts by c6doki
Old Jan 16, 2015, 11:53 PM
MDK_187's Avatar
Joined May 2013
Couple things...
The motor you linked too pulls 34amps max according to the specs. Allowing for overhead, your ESC should be rated at 45amps minimum. I like to allow plenty of overhead in my setups - so I would be running a 60amp ESC . Not sure if a car type ESC would be better than a plane type for this application. Don't know enough bout airboats at this time.
After reading through this thread, I wanna get one of these... http://www.aliexpress.com/store/prod...686623779.html - next month. It's a swamp dawg with different decals. Check out the motor mount setup, it's different than the dawg - according to reviews on HK it's better - look under files tab @ international store.
Thinking 25C not enough for a 34amp motor (I'm sure prop size affects amp draw), 35C might be a better choice for airboats.
Originally Posted by _nicos View Post
It's a Zippy 1300 3s 25c and I currently use an APC style 6x4 prop... it only juuust fits in the space and also suits my all terrain plane.
I kinda want reverse gear to be able to get unstuck instead of a swimming, so will prolly get this 30A esc (without the fan or watercoolery).
Would using a 5x5 prop help some? Pardon the newb questions, thanks y'all.
MDK_187 is offline Find More Posts by MDK_187
Old Jan 16, 2015, 11:58 PM
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
Originally Posted by c6doki View Post
Hi Mike!
Cheers!
So, you want to use this motor:
http://www.hobbyking.com/hobbyking/s...dProduct=44906
And, this ESC:
3S batt right? What mah?
Just so we are on the same page.
Mike.
Chap1012 is online now Find More Posts by Chap1012
Old Jan 18, 2015, 02:06 AM
Joined Jan 2015
And, this ESC:
Mike.
With this battery: http://www.zenn.hu/modelsport/produc...oducts_id=6047
...but yes, at least wanna try...
Maybe I'll see the holy smoke fly out from the ESC right away, dunno.
But I give it a try.
Overkill ESC?
Old Jan 18, 2015, 11:39 PM
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
c6doki, IMHO, I think you should follow MDK_187's advise. If you install an ESC smaller than what the electronics put out, you'll fry your system in no time.
Mike.
Sold New Imex 2.2 All-T Dawg (4) jeepcrawler08 Cars - Trucks and Parts (FS/W) 2 Jun 04, 2011 07:02 PM
For Sale cox nitro cat , or cox gator rc boat swamp buggy rcrick10 Boats (FS/W) 2 Mar 16, 2011 11:59 PM
Help! Help with swamp boat Sune Nielsen Dock Talk 4 Mar 16, 2011 02:27 PM
