Old Apr 12, 2013, 08:45 AM
Joined Sep 2005
I need to extend the power leads 12" from the PL6 to the power supply. I know the PL8 comes with 10AWG, but the PL6 comes with 12AWG.
Should the extended leads be better with 10AWG, or is 12AWG fine? (I will be pulling 40A on some of my charging)
SuperFatCat is offline Find More Posts by SuperFatCat
Old Apr 12, 2013, 11:33 AM
Seattle
Joined Sep 2007
Although 12AWG would probably work, my preference would be to use 10AWG. Wire resistance is cumulative. The larger size will run cooler with less voltage drop.
Gregor99 is online now Find More Posts by Gregor99
Latest blog entry: Dual Powerlab Case Project
Old May 19, 2013, 11:58 PM
TG43's Avatar
Glens Falls, NY
Joined Apr 2010
I have a pile of batteries I want to check the maH capacity on. Can the PL6 do that? At what discharge rate? Regenerative only right? I have a deep cycle battery, that would work right?
TG43 is offline Find More Posts by TG43
Old May 20, 2013, 12:43 AM
Seattle
Joined Sep 2007
Internal discharge is 50 watts. Depending on the pack size and amount of time you are willing to wait, that might be enough. Since you have a Pb battery the discharge rates can be much higher.
Old Apr 09, 2014, 06:17 AM
Chris
The Netherlands, NB, Eindhoven
Joined Sep 2010
Can you help me a bit regarding the input plug of this charger?
I've bought it but don't have it yet, and I'm preparing the connector because when I get it I won't be in my lab.
So, the official description reads:
12AWG input wire terminating with an EC5, female pin connector
This doesn't sound "right". Why female connector on a device?
Or maybe this pic has got it all wrong:
FMA's pics are not close enough. Can someone confirm that this is correct?:
So let's just call them "male/female pins" and "male/female housing". Looks like PL6 has female pins and male housing.
thanks
cmavr8 is online now Find More Posts by cmavr8
Old Apr 09, 2014, 07:12 AM
United States, MN
Joined Feb 2011
You are correct, it is backwards. I asked why this was done once and they said it was for safety. Since the charger automatically does a regenerative discharge when set as running from 'battery' they didn't want someone to power it from a lipo and inadvertently do a regenerative discharge. It's more of a lets make this inconvenient so someone is less likely to screw up.
Most people I know have replaced the connector with the male device connector. I replaced mine with an APP
grimbeaver is offline Find More Posts by grimbeaver
Old Apr 09, 2014, 07:26 AM
Chris
Joined Sep 2010
Thanks!
Yes I'll also replace with what I use (XT60s) but not until I make sure the charger is good and won't need replacement/warranty etc...
Old Apr 09, 2014, 08:23 AM
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
thanks
I have removed then from my PL6 but I assume they are the same as the Dual PowerLab 8X2 which is female pins and female housing.
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Apr 11, 2014, 07:24 AM
Chris
Joined Sep 2010
Glen
Wait, this is not what is shown in the pic above... are you positive?
Old Apr 11, 2014, 11:42 AM
Seattle
Joined Sep 2007
The "pins" in the image are definitely female. Same as you should find on most packs. Look close. You'll see a hole, not the tip of a pin. Trust me, what will arrive is charger with the female "pins". Again same as most users are configuring for their packs.
Old Apr 11, 2014, 03:36 PM
Chris
Joined Sep 2010
Yes I agree, female "pins" or "metal things" haha.
But the plastic housing looks male to me... not female
Old Apr 11, 2014, 03:57 PM
Tallahassee, FL
Joined Sep 2009
That's the way EC's work, male bullet in female housing, female bullet in male housing.
Turner2 is offline Find More Posts by Turner2
Latest blog entry: DX7 Programing - Ultimate...
Old Apr 11, 2014, 04:03 PM
Chris
Joined Sep 2010
Yes yes, but I was confused by ggcrandall1's comment:
Glen
I'll assume it's just what I see in the pic: female metals, male housing.
Next saturday (1 week) I'll have it in my hands
Server PSUs ready to supply current
Old Apr 11, 2014, 04:57 PM
USA, GA, Marietta
Joined Aug 2005
Here is what is on the Dual PL8
The connector on the left is the input power to the right channel.
The connector on the right is from my 24V power supply.
The shell on the power supply connector goes over the shell on the input power connector.
Glen
Old Apr 11, 2014, 05:24 PM
Chris
Joined Sep 2010
This was exactly what I needed!
Thanks a lot, I won't spam any longer
New Product Sneak Peek at the NEW Cellpro PowerLab 8 (v2) Tim Marks FMA Direct 5789 Today 11:40 AM
New Product Introducing the ALL NEW Cellpro 10XP Charger Howard Matos FMA Direct 348 Dec 17, 2013 11:47 PM
New Product Introducing the Scirocco--All Molded, All Carbon Pitcheron Ward Hagaman Slope 174 Nov 16, 2012 08:40 AM
Sold Revolectrix/FMA direct Cellpro PowerLab 8 unused new thwang99 Aircraft - Electric - Batteries & Chargers (FS/W) 2 Aug 26, 2010 03:24 PM
Wanted Cellpro 4S 4amp Charger-New Version ( Found One--Thanks! ) helinut4ever Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 27, 2009 04:24 PM
