Old Dec 07, 2014, 01:41 PM
United States, CA, Weimar
Joined Feb 2014
Help!
help with fpv problem
i had a similar problem a wile back with the same symptoms and it turned out that i was powering my cam through the tx and and it was only giving it 5v and it needed 12v so wired up a cable with a lead going straight from my bat and it worked great. i had to buy a new tx and wired it up the same way and it dose not work it's the same wiring so im really confused! if you can help me that would great!!!
thanks
this is my old post http://www.rcgroups.com/forums/showthread.php?t=2269852
rc monkey is online now Find More Posts by rc monkey
Old Dec 07, 2014, 02:16 PM
Semper Fi
greedyg76's Avatar
United States, CA, Rancho Cucamonga
Joined Mar 2009
What is the new transmitter you are using? Still a FatShark?
greedyg76 is offline Find More Posts by greedyg76
Old Dec 07, 2014, 02:19 PM
Joined Feb 2014
same thing that i had before. http://www.getfpv.com/5-8ghz-600mw-video-tx.html
Old Dec 07, 2014, 03:52 PM
Semper Fi
greedyg76's Avatar
Joined Mar 2009
That transmitter only outputs 5v for the camera, but your camera requires 12v
Old Dec 07, 2014, 04:47 PM
Joined Feb 2014
Yes I know I don't power it through the tx I have a lead going from my esc runing from the 3s
Old Dec 07, 2014, 04:56 PM
Joined Feb 2014
I think I found the problem a little tiny box thing on the top back of my camera is broken a little so that mite be casing it. do you know if it fixable? I will post pics when I get home.
Old Dec 07, 2014, 06:22 PM
Australia, NSW, Bradbury
Joined Dec 2007
ESC's only output ~5v also.
knobby1 is offline Find More Posts by knobby1
Old Dec 07, 2014, 08:42 PM
Joined Feb 2014
No i mean befor it gets to the esc from the 3s
Old Dec 07, 2014, 09:46 PM
Joined Feb 2014
the little tiny box on the top back of the cam is cracked you mite not be able to tell from the pics
Old Dec 08, 2014, 12:56 PM
Semper Fi
greedyg76's Avatar
Joined Mar 2009
get a new camera and put a plastic case on it for protection.
Old Dec 08, 2014, 02:36 PM
Joined Feb 2014
I mite just get a mobius instead
Help! Problems with 8" Lumenier LCD FPV Monitor with 5.8GHz 32CH Diversity Receiver rockdude14 FPV Equipment 2 Nov 13, 2014 10:03 PM
Discussion Help with cfg-eer problems socommfg Multirotor Talk 28 Oct 23, 2014 10:00 AM
Found help with fpv setup problem rc monkey FPV Equipment (FS/W) 14 Oct 22, 2014 04:11 PM
Help! Flamewheel F550 with kk2 board, self level problem. Please Help.... OkaNare Scratchbuilt Multirotors 2 Sep 28, 2014 06:37 AM
Help! Flamewheel F550 with kk2 board, self level problem. Please Help.... OkaNare Multirotor Talk 0 Sep 27, 2014 03:27 PM
