Old Nov 16, 2014, 06:19 PM
United States, TX, Houston
Joined Mar 2014
Originally Posted by pencon View Post
Is everybody using the stock elevator setup ? I'm looking at the little plastic tabs on the elevator covering the music wire and it sure doesn't look too sturdy . Do those tabs go through the elevator or are they just glued onto the surface ?
No problems with mine on 4s and 5s or 6s, but I have added carbon fiber flat rods to the stab and wing.
kthadlee53 is offline Find More Posts by kthadlee53
Old Dec 05, 2014, 12:05 AM
I'm not lost, they are
pullup!'s Avatar
Co.
Joined Jan 2005
So the winter has opened up the brief window when when the runway is smooth and snow packed and I can fly my non-bungee launched EDF's.
Last night I dropped a Tacon 2860-2550KV into the Meteor with the stock Dynam EDF unit and ripped a couple 6s 3300 packs in it today. 1150 watts 47amps WOT, need to temp gun it next time but the motor was running in 35 degree weather so should give me a little over head. Its only rated for 5s but gave it a shot anyway since it was just sitting around. So far it worked awesome!
Last landing hit some ice chunks in the huge smooth runway and sheared of the front retract gear. Ordered new one from Motion.
Flew slightly nose heavy even with my dual elevator servos out back but it really carved it up.
pullup! is online now Find More Posts by pullup!
Old Dec 05, 2014, 11:22 AM
Joined Mar 2014
pullup
That looks great. Sorry about gear. Got a couple of flights on Wednesday on Meteor, Stinger64, Viperjet, and nitro Ultrasport 45 (OS 55 power eflight retracts)
It was a great day. No snow here.
Old Dec 05, 2014, 06:49 PM
Joined Sep 2008
Using the stock electronics is it okay to use 6s.. I need all the speed I can get, we have a couple of the H models out there that are making a lot of noise and the slowest one of them all has a turbine in it. I just ordered my Meteor and need to order batteries.
sweetj is offline Find More Posts by sweetj
Old Dec 05, 2014, 07:30 PM
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
I would not use 6s on the stock motor and esc. There are some that use 5s on the stock set up but 6s would be pushing it too far.
DamonH is online now Find More Posts by DamonH
Old Dec 05, 2014, 07:32 PM
Ron - AMA 1025
ronwc's Avatar
USA, FL, Largo
Joined Aug 2005
When I first got my Meteor I tried 4, 5 and 6 cell all stock. Almost any pack you use, especially anything with more cells than 4 or larger than 2200mah, you need to cut out rear stop block and move battery all the way back. I tried all the way up to 4000, and it was really getting too heavy with that kind of weight. The 2 best packs I use in mine are a 5 cell 2800mah http://www.ebay.com/itm/380792177991...%3AMEBIDX%3AIT and 4 cell 3000mah with high 75C rating. Really didn't feel like i got any more speed with 6 cell.
ronwc is offline Find More Posts by ronwc
Old Dec 05, 2014, 08:46 PM
Joined Sep 2008
Thanks guys, I have some 4s and 5s packs that I will try first.
Old Dec 11, 2014, 05:15 PM
pullup!'s Avatar
Co.
Joined Jan 2005
Got the new nose gear this morning and popped it in at the field.
Three fantastic flights with three of the smoothest landings yet.
Fantastic flying EDF!
Old Dec 11, 2014, 11:41 PM
Joined Mar 2014
Pullup
Yes it is a good edf. I had some issues with mine being squirrely on take off so I replaced the wire struts with some oleos and reinforced the wing and stab with carbon fiber strip. I've had about ten flight with no issues since then,
Old Dec 12, 2014, 08:40 PM
Joined Mar 2014
New Batts
Got some new Genesis 6s 65c 3300s. 96 amps and 2181 watts. I will have to watch the full power passes. ESC is only 100 amp. Does a Castle Phoenix Edge Lite 100 have any headway in the amp ratings?? Thanks
Old Dec 13, 2014, 10:26 PM
Joined Sep 2008
New meteor
Got mine yesterday and I'm satisfied, I assembled it last night and everything seems okay. I think they could add a plug like in the sviper for all the cables running from the wing to the fuse. I plan a multi blade fan either the vs. or the wemo. Ordered both. Too much wind for the maiden today.
Happy holidays
Old Dec 15, 2014, 12:46 AM
Joined Dec 2008
What Motor are you running with 6S Kthadlee ?
pencon is online now Find More Posts by pencon
Old Dec 15, 2014, 05:56 PM
Joined Mar 2014
Cyclone Power 2200 kv12 blade 70mm from Edf Hobbies. I got 4.8 # thrust in 3.8# plane. Fan and motor was $85.00 .
Kevin
Sold Larry Jolly "Meteor"-127" Kit NIB --Now $275 Shipped ldm1839 Aircraft - Sailplanes (FS/W) 5 Sep 29, 2010 06:34 PM
Discussion Meteor shower tonite, You goonna stay up for it? Bilbobaker Life, The Universe, and Politics 13 Aug 16, 2010 12:32 AM
Build Log Peter Rake's 30" General Western Meteor Prototype dz1sfb Scale Kit/Scratch Built 19 Aug 15, 2010 11:38 PM
Discussion Two Hours Outside and I only Saw One Perseid Meteor Chophop Life, The Universe, and Politics 12 Aug 12, 2010 08:28 PM
For Sale Russ Thompson Meteor fuse Bill L Aircraft - Sailplanes (FS/W) 0 Oct 15, 2009 10:18 PM
