Old Jul 21, 2015, 04:24 AM
Manolo Marcos is offline
Find More Posts by Manolo Marcos
Spain, CL, Salamanca
Joined Dec 2013
Help!
Engine stopped in flight
Hi, I've got a foammy Mirage 2000 EDF 90mm. I fly it with
EDF Ducted Fan Wemotec Midi Fan evo / HET 650-58-1480 and
HET 90A HV PRO ESC 4-8S OPTO and 6S lipo 3000 mAh.
Last day its engine stopped running in flight after 1 minute. I landed hardly but it´s ok.
Lipo was ok, it´s new, with 4'10 v by cell. Two lipos more on the floor but it didn´t stop.
Could you help me?.
Thank you very much.
(I´m sorry for my English).
Manolo Marcos is offline Find More Posts by Manolo Marcos
Old Jul 21, 2015, 05:21 AM
Shane Sunday is offline
Find More Posts by Shane Sunday
United Kingdom, Northern Ireland, Belfast
Joined Jun 2011
Id say it's the Low Voltage Cutoff on your ESC due to your lipo's capacity. that fan and motor combination will draw a few amps reducing the lipos capacity very quickly. I'd say move to a 4000 - 5000 mah lipo.
I could be wrong
Shane Sunday is offline Find More Posts by Shane Sunday
Old Jul 21, 2015, 05:22 AM
4stripes is offline
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
A 3000mah battery is small for a 90mm jet. If you stayed at full throttle it may have sagged in voltage to the low voltage cutoff of the ESC.
4stripes is offline Find More Posts by 4stripes
Old Jul 21, 2015, 07:14 AM
GordonTarling is offline
Find More Posts by GordonTarling
Supersonic Engineering
GordonTarling's Avatar
UK, Greater London, Uxbridge
Joined Mar 2001
It could also be the ESC overheating - has it got any cooling air going to it? Does it get very hot if you run it on the ground for 30 seconds?
GordonTarling is offline Find More Posts by GordonTarling
Old Jul 21, 2015, 09:23 AM
nighthawk0077 is offline
Find More Posts by nighthawk0077
Joined Oct 2009
I'd say the ESC quit on you, those Het units are known to be flaky. Try a hobbywing or yep ESC.
Your lipo sizing is fine as you have a very low amp setup (45amps max?) flying a very light model.
nighthawk0077 is offline Find More Posts by nighthawk0077
Old Jul 21, 2015, 01:01 PM
Castel101 is offline
Find More Posts by Castel101
Castel101's Avatar
United States, OR, Portland
Joined Sep 2011
El ESC tiene un parámetro llamado Low Voltage Cut-off. Está ahí para proteger las baterías cuando se descargan demasiado. Con un fan de 90mm la corriente es alta y si las baterías no son buenas o muy pequeñas el voltage puede caer demasiado, el ESC puede haber detectado esa caída de voltage como una señal de que están muy descargadas y apaga el motor. Para ese avión y fan seguro necesitas baterias más grandes como dijo Shane Sunday. Sigue funcionando?
Castel101 is offline Find More Posts by Castel101
Old Jul 22, 2015, 03:18 AM
Joined Dec 2013
Yes, it´s still working.
The LVC is on 8'4 v in my programming card. I could set it until 5 v.
Impossible overheating. It ´s got good cooling air going to it. It doesn´t get hot on ground nor air.
On ground never reach under 3'5 v each cell.
Do I set LVC on 5v?
Thanks mates.
Discussion What are the reasons for gas engines stopping in mid flight? Gamerjoe Engines 40 Sep 29, 2014 11:31 AM
Discussion help my quad flips or 1-2 motors stops for half a second in mid-flight jaas75 Multirotor Electronics 7 Nov 22, 2013 12:19 PM
Discussion MK stop engines in flight krall Multirotor Electronics 0 Aug 03, 2012 02:46 PM
Discussion My PZ P51 Engine keeps stopping in mid air. thercguru Scratchbuilt Indoor and Micro Models 2 Nov 25, 2010 10:01 PM
Alert Stopping Blades in flight Picture! Fred Bronk Micro Helis 5 Jun 17, 2003 06:22 AM
