Old Jan 27, 2015, 08:16 PM
United States, CA, Redondo Beach
Joined Oct 2013
Reworked with sullivans 2-56....work on covers tonight
hubcapsteve is online now Find More Posts by hubcapsteve
Old Jan 27, 2015, 08:37 PM
ehelibuff
ehelibuff's Avatar
United States, CA, Santa Clarita
Joined Aug 2014
That's exactly how I did my ailerons on my Jolt 2. Worked perfectly.
ehelibuff is offline Find More Posts by ehelibuff
Old Feb 19, 2015, 01:29 PM
feefo's Avatar
Staffs, UK
Joined Apr 2009
Can anyone tell me if the flapped version has top or bottom hinged control surfaces for the flaps?
feefo is online now Find More Posts by feefo
Old Feb 19, 2015, 01:44 PM
ehelibuff
ehelibuff's Avatar
Joined Aug 2014
Top hinge
Old Feb 19, 2015, 01:49 PM
feefo's Avatar
Staffs, UK
Joined Apr 2009
Cheers
Old Feb 19, 2015, 02:17 PM
ehelibuff
ehelibuff's Avatar
Joined Aug 2014
If you're getting a Jolt 2, you may want the flap version. The plane is a lil heavy and doesn't slow down well. Mine is no flap and it lands fast!
Old Feb 19, 2015, 02:23 PM
feefo's Avatar
Staffs, UK
Joined Apr 2009
No I'm not getting a Jolt 2, definitely going for a Swist, just not sure whether to get a flapped version or not.
Old Feb 19, 2015, 03:32 PM
ehelibuff
ehelibuff's Avatar
Joined Aug 2014
I have the Swist as well. I bought the flapped version. I'm also using a Neu 1115/1.5D with P29/5.2 gearbox, GM10x23 prop, CC130 Edge Lite & TP 5S 1800mah 70C in it. Went with (4) Hyperion HP-DS09 AMD's in the wing and (1) MKS DS6100 on the elevator. I wanted a geared one after building my Jolt 2 as direct drive no flap.
Old Feb 20, 2015, 02:48 AM
feefo's Avatar
Staffs, UK
Joined Apr 2009
I take it you've not suffered any flutter from the flaps?
Old Feb 20, 2015, 11:50 AM
ehelibuff
ehelibuff's Avatar
Joined Aug 2014
Nope. Do the linkage properly, you won't get flutter. Good servos, good horns (servo & control), make the holes slightly snug. Don't put the holes too close to the surface.
Old Feb 20, 2015, 01:09 PM
arcticflyer's Avatar
Canada, SK, Prince Albert
Joined Jan 2006
On a two servo wing run spoilerons...they work rather well...not as good as flaps or crow but better than nothing and they do slow fast airframes down a bit
arcticflyer is online now Find More Posts by arcticflyer
