Old Apr 14, 2004, 11:15 AM
dave morris is offline
Find More Posts by dave morris
dave morris's Avatar
orlando fl
Joined Oct 2000
BEC using a 5v reg chip
I tried to search but not working. I have a 4s lipo setup and want to make my own BEC as I dont think the one on the ESC will handle the load. I would like to be able to cover a 35 watt load (got several servos) and was wondering if one of the 3 pin 5v reg ic could handle it? I am not an electronics expert so plain english please on how it would go. I have looked into the sbec, and ubec, but would like to keep it a little cheap and light
dave morris is offline Find More Posts by dave morris
Old Apr 14, 2004, 12:21 PM
Chippie is offline
Find More Posts by Chippie
North East England UK
Joined Jan 2003
the majority of the 5v regs or even adjustable one's wont cater for that sort of load....7amps-ish...(35 watts @ nominal 5v I reckon)
If you dont wanna go the Ubec route then the other option is to use a series pass transistor to carry the extra load, then the project is starting to become involved...unless any one else has any ideas ? ;P
Chippie is offline Find More Posts by Chippie
Old Apr 14, 2004, 12:49 PM
jeffs555 is offline
Find More Posts by jeffs555
"Simplify, then add lightness"
Raleigh,NC
Joined Nov 2000
First off, I dont think you really mean 35 watt load, if you do, you are talking about one hell of a big regulator. At 5 volts, 35 watts would be 7 amps which sounds very high even for 4 servos, so the first thing to do is to figure what your actual requirements are. You need to know the peak current and the average current for your servos. For a regulator, you first need to make sure it will handle the input voltage of 4 LiPos(16.8volts), the peak current, and the average power disipation. The first two are easy, provided you can find peak current specs for your servos, as the regulator will have a fixed spec for maximum voltage and current. The allowable power disipation is much harder to figure, as it depends on how the regulator is mounted and what kind of heat sinking you use, and the actual average current for the servos depends on how they are being used. For a simple linear regulator, the average power disipation is equal to the average current times the difference between the battery voltage and the output voltage, so with 4 LiPos, 16.8v-5v=11.8v, and 11.8volts x 7 amps = 82.6 watts which would take a huge heat sink and probably a very large external pass transistor on 3-pin regulator. If you are really talking about this much power, you would probably want a switching regulator.
Jeff
jeffs555 is offline Find More Posts by jeffs555
Old Apr 14, 2004, 06:05 PM
orlando fl
Joined Oct 2000
my bad, I just check with the watt meter, I have 5 servos, two for retracts, worst case I stalled both the retract servos, and wiggled the control surfaces, saw about 1.2 amps (hs50's and 55). So looks more on the max of 15 watts should be safe. So with the revised numbers what do you think?
Old Apr 14, 2004, 06:29 PM
Mr.RC-CAM is offline
Find More Posts by Mr.RC-CAM
Mr.RC-CAM's Avatar
USA
Joined Oct 2001
With a 4S Lipo, worse case currents are going to be tough to handle for a simple series pass Vreg. Heatsinking for 10 watts of heat, inside a small fuselage, is the concern. Also, assuming nominal currents of a couple hundred mA's, you still have a Vreg that has to handle 2 watts.
Have you considered something like the UBEC? Switcher designs are best for "high voltage" BEC apps. Otherwise, add a big heatsink, in the airstream, and avoid stalling a servo.
RC-CAM
Mr.RC-CAM is offline Find More Posts by Mr.RC-CAM
Old Apr 14, 2004, 06:40 PM
orlando fl
Joined Oct 2000
I think I am being penny wise, pound foolish, will stick with the switching regs, and not put my jet in jeopardy, thanks guys.
Old Apr 15, 2004, 05:11 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
I was in the process of looking for switching regulator chips, so we can all make our own SBECS. My PC crashed and I got diverted.
Read Jeffs summary. 15w of servo power does not mean 15w of regulator heat.
On 4s and up you MUST use a switching regulator or a very heavy heatsink!
If I get time I'll do another search. Try googling on DC switching regulators etc.
Old Apr 15, 2004, 05:57 AM
clipclop is offline
Find More Posts by clipclop
QLD, Australia
Joined Sep 2003
I have seen switching regulators at maxum, texas instruments and national , was a while ago but from memory one these with a power tranny and a few caps resistors is pretty easy to do .
Stewart
clipclop is offline Find More Posts by clipclop
Old Apr 15, 2004, 08:02 AM
orlando fl
Joined Oct 2000
I only hope the ESC makers get with the program and start making all the ESCs with swithing BEC's, save us the overhead. Does it cost that much more? take up more board space?
Old Apr 15, 2004, 04:42 PM
jeffs555 is offline
Raleigh,NC
Joined Nov 2000
The answer to both of your questions is yes. A switcher does take up more board space, and the incremental cost over a simple linear regulator is relatively high compared to the cost of the rest of the components on a simple ESC. Also, there are the interference issues that a switcher generates, causing much more design work and support problems. On a low volume product(most anything for RC is low volume), the design and support costs usually far outweigh the parts cost.
Jeff
Old Apr 15, 2004, 05:30 PM
Haldor is offline
Find More Posts by Haldor
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Take a look at Kontronik Jazz xx-6-18 ESC's - these do just that.
Haldor is offline Find More Posts by Haldor
Old Aug 24, 2005, 04:59 AM
Chris T is offline
Find More Posts by Chris T
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
One could use a standard LM317 at 4s, as long as current is not too high. This device can heat up over 100 C without shutting down. With 3 micro servos and 2 LEDs it should be ok... and one can hook diodes in series with LM 317 input. Then power is dissipated in the diodes (.6V drop per diode). So you can make sure power dissipation in the controller is not so high, that it shuts down rx during flight
Chris T is offline Find More Posts by Chris T
Old Aug 28, 2005, 01:25 PM
raptorhelis is offline
Find More Posts by raptorhelis
Salt Lake City Intl, Utah, United States
Joined Jul 2004
this site i have put together has a ton of info on regulator and power consumption basically everything you want and need to know and understand about the electrical power systems for r/c aircraft. check it out www.microlitesystems.com email me if you have any other questions. thanks
raptorhelis is offline Find More Posts by raptorhelis
Old Apr 10, 2015, 06:32 AM
Eltouro is offline
Find More Posts by Eltouro
Joined Jun 2012
Bec
Guys,
Some advice, I am powering the Flir camera from a 3S battery.
Flir should be running at 5volts 1.2 amps.
I got the turning Ubec 5/6v at 3 ams, Max 6amps.
Do I risk in frying my camera?
Eltouro is offline Find More Posts by Eltouro
Old Apr 10, 2015, 09:51 PM
mjsas is offline
Find More Posts by mjsas
Joined Nov 2007
Here is a 3 amp UBEC, it uses the LM2676 which is the same part used in most UBEC circuits. The 4 amp rating is just the peak current and not the continuous current.
You can spend more and still get the same LM2676 circuit.
http://www.ebay.com/itm/5V-4A-RC-Mod...item4d2fd13e45
(Sorry, I didn't look at the dates. I never expected a ten year old thread to pop up.)
mjsas is offline Find More Posts by mjsas
Help! Honey Bee King 2 Using 30A ESC, 5V/6V Switchable BEC, Brand New, Servo not working? RcSuperSales Micro Helis 5 Aug 04, 2007 12:39 AM
Discussion Advice from Futaba - Cheapie BEC using diodes Miami Mike DIY Electronics 11 Jan 18, 2007 11:59 AM
For Sale New 3-5amp BEC's - 5v/6v Switchable - 35v input punkindrublik Aircraft - Electric - Power Systems (FS/W) 16 Aug 22, 2006 07:44 PM
Discussion CC Phoenix 45 w/Bec -- using separate on-bard battery for RX byrocat Power Systems 3 Jun 25, 2006 09:27 PM
disabling BEC - and using RX battery gingin Castle Creations 3 Oct 19, 2005 11:33 PM
