Old Jul 27, 2015, 11:13 AM
shinck is offline
Find More Posts by shinck
Utah, USA
Joined Jun 2007
Gene,
Thanks for the tow video, in spite of my disappearing act. The Olympia does fly well, but I am going to try some more nose weight as there is still some down trim. Will put in some more info when I get to a proper keyboard--I'm not fast on a phone!
shinck is offline Find More Posts by shinck
Old Jul 27, 2015, 07:03 PM
dgliderguy is offline
Find More Posts by dgliderguy
Where's the lift?
dgliderguy's Avatar
United States, WA, Snohomish
Joined Mar 2001
Nice!
Will I ever live long enough to build all of the sailplanes that turn me on? Seeing Scott's newly-completed rendition of the Charlesworth Olympia Meise this weekend had me poring over my copy of the plans again last night.
Will it bump something else on the build list? Could happen! What a nice looking glider. Must have... must have...
dgliderguy is offline Find More Posts by dgliderguy
Old Jul 28, 2015, 10:03 PM
shinck is offline
Utah, USA
Joined Jun 2007
Look here, http://www.rcgroups.com/forums/showthread.php?t=2319281
starting at Post #72 for some more information on the Monroe Aerotow
I have added 3 photos below of the Olympia at that event
Old Jul 29, 2015, 09:14 AM
Seadog is offline
Find More Posts by Seadog
Seadog's Avatar
Canada, ON, Toronto
Joined Jan 2004
Dihedral
Scott,
It looks like flight loads bring just enough dihedral into play so that it "looks right".
Beautiful shots.
DS
Seadog is offline Find More Posts by Seadog
Old Jul 29, 2015, 06:46 PM
dion9146 is offline
Find More Posts by dion9146
dion9146's Avatar
United States, KY, La Grange
Joined Feb 2006
actually, doesn't the Olympia have that dihedral built in already?
dion9146 is offline Find More Posts by dion9146
Old Aug 12, 2015, 11:08 PM
shinck is offline
Utah, USA
Joined Jun 2007
Dihedral
In answer to dion9146
Sorry to be a while between posts—pre- and post- extended vacation has taken some time. As for dihedral, I have pulled the information together for the Aussie Plans model I built, the Charlesworth plans that had access to original full-size Oly plans and sailplane, and the Simons 3-view from Sailplanes 1920-1945. The dihedral could be measured on the bottom of the wing or at the center of the LE. I have shown both below. The Charlesworth and Simons drawings are close enough to be called a match. All measurements were laid out together at full size on a computer drawing program.
Source / Tip Height / Degrees, bottom / Degrees, LE Center
Aussie build / 2-5/8" / 2.05 degrees / 1.7 degrees
Charlesworth/Simons / 4-1/4" / 3.3 degrees / 2.9 degrees
Conclusions:
The average Charlesworth/Simons dihedral is around 3 degrees.
The Aussie RC Plans average dihedral between methods is about 1.8 degrees.
The actual difference at each tip is about 1.2 degrees or 1-5/8", which is why the wing on my model looks a bit flat.
I have attached a scan of the Simons 3-views.
Old Aug 14, 2015, 11:23 PM
shinck is offline
Utah, USA
Joined Jun 2007
Tip skids and balance
For the salt flats I normally aerotow from, tip skids are a must. It's hard and abrasive and will sand a flat in the tips quickly.
For my first try, wood craft eggs were used. Cut in half, sand a little thinner, use servo tape so they can be removed easier, and put them right out on the tip. If there is a problem or I think they look too clunky, then there will be a v.2.
Our club has an aerotow tomorrow/Saturday—last weeks was rained out, again!
I have added another 2-1/3 oz of lead to the front of the battery tray to see if I can get the down trim out of the elevator. Will it fly better? Trial and error…
Build Log Olympia 2b 1/4 Scale Build Log ShaneW Scale Sailplanes 7 Oct 14, 2010 02:03 AM
Discussion Flightpower Eon vs Eon-X Seahawk82 Batteries and Chargers 89 Jan 14, 2010 06:34 PM
Discussion Kranich 2B Plans scervetto Scale Sailplanes 1 Aug 04, 2008 12:16 PM
Wanted Wanted:Cliff Charlesworth Olympia 2B (DFS Meise) WarBirdCrazee Aircraft - Sailplanes (FS/W) 1 Feb 07, 2008 03:06 PM
Eon Olympia? Tominator Scale Sailplanes 2 Dec 20, 2004 02:34 PM
