Old Feb 05, 2015, 11:49 PM
dinuc is offline
Find More Posts by dinuc
Joined Nov 2014
EDF noob
Hi,
I am planning to build the FT Viggen and ordered a 70mm OD edf to suit.
I connected it up and ran for 30 seconds to a minute before I shut down due to scraping sounds. I was at approximately 1/3 throttle.
The following photos show the damage.
So, is this normal ?? Is this part of the running in procedure ?
Run gently until the walls have confirmed with the fan type of thing ??
Andrew
dinuc is offline Find More Posts by dinuc
Old Feb 06, 2015, 02:17 AM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Normal? If it' an out runner and the fan and motor are not balanced--yes.
Do some searches on balancing fans-- lots of info here to digest.
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Feb 06, 2015, 03:27 AM
whatarascal is offline
Find More Posts by whatarascal
Sad old git
United Kingdom, Andover
Joined Apr 2014
Best to check that the fan is in the center of the shroud.
If it is slightly of center then when the fan starts to flex it could touch the shroud.
And of course as already mentioned make sure it ballanced
whatarascal is offline Find More Posts by whatarascal
Old Feb 06, 2015, 10:21 AM
dinuc is offline
Joined Nov 2014
Thanks for the replies.
I also had a reply from the supplier, "From what you are describing this is normal, as the center fans spin, they heat up and expand. This will make a near perfect fit"
I will look into balancing the fan.
cheers
Andrew
Old Feb 06, 2015, 11:57 AM
turbonut is offline
Find More Posts by turbonut
Pro Horder
turbonut's Avatar
upland CA
Joined Dec 2004
When you ran the fan were you holding it in your hand? the shroud will deform and rub as you have seen. But many fan can rub like that depending on how they were assembled.
Old Feb 06, 2015, 08:22 PM
jumo004 is online now
Find More Posts by jumo004
jumo004's Avatar
Joined Apr 2010
Most definitely wear eye/face protection. If/when it lets go it will be FAST.... guaranteed.
I spun up a fan (30mm dia.) and didn't even get to full power and because the fan was out of balance it let go. The fan vaporized and took out the shroud.
jumo004 is online now Find More Posts by jumo004
Old Feb 06, 2015, 11:48 PM
dinuc is offline
Joined Nov 2014
[QUOTE=jumo004;30713289]Most definitely wear eye/face protection. If/when it lets go it will be FAST.... guaranteed.]/QUOTE]
Yep, Engineer, so safety third ...
Ouch.
cheers
Andrew
Discussion Noob Noob Noob - Please help Stothex Multirotor Power Systems 4 Nov 20, 2014 10:02 AM
Question Advice needed for an EDF noob Aero Andy Micro EDF Jets and Power Systems 60 Sep 26, 2011 09:56 PM
Discussion Noob looking to start a micro EDF Britnkurt Micro EDF Jets and Power Systems 6 Feb 18, 2011 09:50 PM
Discussion EDF Noob Question anavlas Electric Ducted Fan Jet Talk 7 Jul 23, 2008 12:33 PM
Discussion Noob EDF question A.T.A.C. Electric Ducted Fan Jet Talk 91 May 13, 2006 10:38 PM
