Old Jan 29, 2015, 04:34 PM
flyifr is offline
Find More Posts by flyifr
K4MGPO
United States, GA, Eatonton
Joined Nov 2009
Question
UBEC with Vector
I generally don't use the BEC on a ESC, but use a UBEC for obvious reasons. Wiring in a Vector and before I blow something up where would the UBEC wire into the Vector? I know the ESC plugs into throttle...but what about the UBEC OR....does thorough the marvelous engineering at ET is the need for a UBEC mitigated in some way. In other words...do I still have control of my surfaces when a ESC blows out like I do with the UBEC ?
BTW, the ESC has a BEC, I just have the red pin pulled and taped down to prevent any chance of a short and have been using the BEC.
flyifr is offline Find More Posts by flyifr
Old Jan 29, 2015, 08:59 PM
flyifr is offline
K4MGPO
Joined Nov 2009
I THINK I figured this out...UBEC plugs into Battery port of Receiver...if wrong, it seems to work. If I should not, please chime in and let me know...thanks.
Old Jan 30, 2015, 07:37 AM
JohnET is offline
Find More Posts by JohnET
JohnET's Avatar
United States, NC, Charlotte
Joined Apr 2013
That will work fine as long as you are not over 6 amps current draw on your servos. Please see "3.5.5 Receiver Connection Harness Load Capacity (Fixed Wing Only)" in the manual for additional info.
Regards, John
JohnET is offline Find More Posts by JohnET
Site Sponsor
Discussion Cloud 200 AMP ESC with UBEC acpd22 Racing Boats - Electric 1 Jan 02, 2015 08:44 AM
Question To UBEC or not to UBEC? Oldgazer Power Systems 9 Dec 01, 2014 07:33 AM
Discussion TO UBEC OR NOT TO UBEC????F450 ARF with Multiwii Pro ez3.0 That is the question..? navycut81 Scratchbuilt Multirotors 9 Apr 06, 2014 07:22 AM
Discussion TO UBEC OR NOT TO UBEC????F450 ARF with Multiwii Pro ez3.0 That is the question navycut81 Multirotor Power Systems 1 Mar 31, 2014 03:16 PM
Discussion Vector Vector **with maiden vid** sno Slope 82 Apr 21, 2008 09:50 AM
