Old Oct 12, 2009, 04:52 PM
Feliks is offline
Find More Posts by Feliks
Feliks's Avatar
Joined Oct 2009
New 4 stroke engine
Pease visit new 4 stroke engine
Regards Andrew
Feliks is offline Find More Posts by Feliks
Old Oct 12, 2009, 05:06 PM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
Czesc! Morze cie wyrzuca stat. Ale, masz interesujacy silnik. Widzialem strone pare lat temu.
Greg
dieselrc.com
gkamysz is offline Find More Posts by gkamysz
Old Oct 13, 2009, 06:32 AM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
It reminds me of the sleeve valve engines of the 1920's and 1930's. The British had built hundreds of bombers that used the sleeve valve design engine.
Not bad though. We need some model engines to put on airplanes. it might be a lot of fun.
http://en.wikipedia.org/wiki/Sleeve_valve
With a sleeve valve engine you can get better volumetric efficiency but you usually have a problem with getting higher compression ratio's and the combustion chamber can't be as well designed. So in a automobile the engine would likely run pretty good but have problems with excessive emissions and polutants coming out.
earlwb is offline Find More Posts by earlwb
Old Oct 13, 2009, 08:07 PM
skippyspad is offline
Find More Posts by skippyspad
Sudden Crosswind on Final
skippyspad's Avatar
Loveland, CO
Joined Jun 2008
I don't see how it would be any better or more efficient than a standard 4 stroke. You still have to have some sort of cam system to run the other crank/pistons or you would never have consistant timing. You have much more surface area to lubricate with two additional pistons/rings/cylinders and all the associated bearings instead of a couple pushrods, valves and springs.
Although it is a neat idea.
skippyspad is offline Find More Posts by skippyspad
Old Oct 13, 2009, 08:12 PM
Deuce is offline
Find More Posts by Deuce
Übung macht den Meister..
Deuce's Avatar
United States, OR, Fairview
Joined Jul 2006
One advantage is it's unlikely you'd experience valve float with this at high rpm.
Deuce is offline Find More Posts by Deuce
Old Oct 13, 2009, 09:40 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
This type of engine does not have valve float at high rpms. Engine RPM is only limited by the design characteristics of the engine. It was a big reason why sleeve valve engines were popular for a while. At the that time or era, valves were a problem with not seating correctly, valve float, and valve stretch as the engines were used. Plus you didn't have to adjust valve gaps from time to time too.
Latest blog entry: My new Gaui X5 Rc Helicopter
Old Oct 14, 2009, 06:40 PM
Feliks is offline
Feliks's Avatar
Joined Oct 2009
O yes.
This is antyboxer or trueboxer ??
And weight....
Regards Andrew
Old Oct 18, 2009, 09:47 AM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I forgot about the RCV sleeve valve engines:
http://www.rcvengines.com/rcv91cd.htm
or
http://www.hobbyhorse.com/rcv.shtml
I wonder if one can still buy the engines or not.
A vendor forum is here:
http://www.rcuniverse.com/forum/forumid_145/tt.htm
Old Oct 18, 2009, 11:34 AM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
RCV is still producing engines. Their scooter and UAV program appears to be in full gear.
Greg
Old Oct 18, 2009, 11:51 AM
bogbeagle is offline
Find More Posts by bogbeagle
Joined Mar 2007
Yes, my mate bought an RCV .91 this morning, at a swapmeet. Good paperweight, if you ask me.
bogbeagle is offline Find More Posts by bogbeagle
Old Oct 18, 2009, 04:33 PM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
The model engines do leave something to desire. The seals on the larger engines much better.
Greg
Old Oct 18, 2009, 04:40 PM
Fylingdales Flyer is offline
Find More Posts by Fylingdales Flyer
Fylingdales Flyer's Avatar
Yorkshire Coast. United kingdom
Joined Apr 2008
RCV are an efficient and well respected motor, you obviously have no experience of them, so maybe it's better if we don't ask you.
For a proper view on RCV engines, including user comments, take a look at www.rcvengines.com or search RCV on RC Universe.
Another rotary valave engine was the Austrian HP 21/25/49/61VT series. Now in production in California by RJL industries. Take a look at www.mecoa.com and click on HP engines
Fylingdales Flyer is offline Find More Posts by Fylingdales Flyer
Old Oct 18, 2009, 04:46 PM
Joined Mar 2007
Not in this neck of the woods.
Old Oct 18, 2009, 06:06 PM
GeoffinIN is offline
Find More Posts by GeoffinIN
Two left thumbs
Muncie, IN
Joined Sep 2006
Sleeve valve automobiles existed in the early 1900s. One even raced at Indy! US patent, perfected in England.
http://en.wikipedia.org/wiki/Knight_Engine
GeoffinIN is offline Find More Posts by GeoffinIN
Old Oct 18, 2009, 08:03 PM
Feliks is offline
Feliks's Avatar
Joined Oct 2009
Yes, you are right, only to office destinations
Why: yeah because from the cylinder a hindered outflow is warm to chilling ribs, and collecting carbon deposit sie on the rotational valve of not a fortune-teller of the long failure-free exploitation. Appropriately the great channel in the rotational valve is also making the top compression ratio impossible, and behind it good effectiveness.
It is my proposal, le unfortunately nobody still for her produces. Please treat everything only as general outlines of the road which one could go.
This my 35 year old collections of new engines: two 2,5 ccm and one 5 ccm
and my flathead engine or sidevalve engine (flatty)
principe http://en.wikipedia.org/wiki/Flathead_engine
Only orientation schematics
Are unfortunatelly drawing - need 3D Drawig- first engine whos impossible drawig in 2D right.
And my vision this engine made orginal part other engines.
Two crankshaft in timing are work exellent.! ( my first prototype)
In this excell work , are possible changes all colour pole value.
pistons positions
my by sometime made it
Regards Andrew
Discussion for sale Used Magnum 91 4 stroke engine in almost new shape pitbull1701 Engines 2 Sep 01, 2009 09:29 PM
Enya 90-4C 4 Stroke Engine for Sale New in the Box robsley Other Websites 0 Apr 01, 2008 01:23 AM
Sold RCV 91-CD 4-stroke engine. New In Box. dmajchrzak Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jan 26, 2007 12:21 PM
FS: New in Box MAGNUM 61RFS 4 stroke Engine sgil2001 Aircraft - Fuel - Airplanes (FS/W) 3 Jun 19, 2004 10:36 AM
Near New Magnum .52 4-stroke engine ExpertFlyer Aircraft - Fuel - Airplanes (FS/W) 1 Nov 05, 2003 07:08 AM
