Old May 03, 2014, 11:44 AM
robertus's Avatar
Poland, Dolnoslaskie, Jelcz-Laskowice
Joined May 2012
Build Log
F/A-37 Talon with moving wings (Stealth movie) with beta plans
I'm starting my new project F/A-37 Talon
From movie "Stealth"
F/A-37 Talon, Stealth Mission (2 min 49 sec)
Now, I'm having empty fuselage
F-37 Talon wing test (0 min 38 sec)
For a moment I'll paste pictures from the building.
robertus is offline Find More Posts by robertus
Old May 04, 2014, 08:51 AM
robertus's Avatar
Joined May 2012
Here are plans. There are beta version, It's means that you can build Talon with min or max wing configuration, but there are no engine mounts or any equipment marked on the plans.
It's up to you, where you mount engine, for example.
For me I'll try put propeller inside fuselage. Something like that.
Yellow circle is 7inch propeller.
Latest blog entry: My fleet
Old May 04, 2014, 09:06 AM
robertus's Avatar
Joined May 2012
My English isn't good, but I think, one picture is more than a hundred words, so there will be a lot of them
Main parts of fuselage
Front
Old May 04, 2014, 09:08 AM
robertus's Avatar
Joined May 2012
Upper intake
After glueing I'm removing marked trapeze
Both intakes
Back view
Old May 04, 2014, 09:12 AM
robertus's Avatar
Joined May 2012
Bottom of fuselage
Bottom intake
And side view. It's looking nice. I like it.
Rear view
Old May 04, 2014, 09:21 AM
robertus's Avatar
Joined May 2012
End at the end stabilizers. They are glued at 45 degrees.
Front view.
And at the end , wing configurations
max speed = min wingspan
and max wingspan
Old May 04, 2014, 09:26 AM
robertus's Avatar
Joined May 2012
This is my conception of moving wings mechanism
So this is good time to check CoG position.
This is my movie from glide testing
F/A-37 Talon, CoG with different wing configuration (2 min 8 sec)
As you see, It wouldn't be easy to build swing wing like this.
It will be a big challenge for me. I'm thinking about accu moving with wings to change CoG to correct position.
Or I'll build fixed wing in open position at the end.
Old May 04, 2014, 11:19 AM
rajazo's Avatar
Chile
Joined Jul 2010
Wow really impressive glide test...on full forward wing, glide better than I think. ...
And tye model looks awesome
The problem of the CG movement looks difficult compared to normal swing wing... it moves opposite that we need
rajazo is online now Find More Posts by rajazo
Latest blog entry: OV10 bronco
Old May 04, 2014, 12:29 PM
SebastianG.'s Avatar
Deutschland, HE, Schlangenbad
Joined Sep 2010
Very cool project. I like the size you are going to build this plane.
I think a moving lipo slide would be the answer.....
Hope this thing will fly...
Cheers Sebastian
SebastianG. is offline Find More Posts by SebastianG.
Old May 04, 2014, 03:11 PM
Fremont, CA
United States, CA, Fremont
Joined Jan 2009
Following...
djacob7 is offline Find More Posts by djacob7
Old May 04, 2014, 05:26 PM
elmagnificado's Avatar
United States, TX, Austin
Joined Jan 2013
Very cool! If possible, I would balance the plane with the wings extended then when the wings are folded in, it would just be a little nose heavy and still controllable.
Bobdearonort did a 5-easy pieces version a while back that I built and it flew great. I only built the open wing version and it was a profile plane, but a full 3d fuse and moving wings are freaking awesome!
elmagnificado is online now Find More Posts by elmagnificado
Old May 04, 2014, 06:13 PM
rajazo's Avatar
Chile
Joined Jul 2010
Isn't so simple. .. when you move the wings forward, the Aerodinamic center put in front of the defined CG, then you get a tail heavy effects...
Maybe make the inverse could be easier (cg on forward wing)... produce nose heavy on take off and landing
On normal swept wings the effect is inverse and nose heavy appears full backwards. .. it's more easy to control and the plane is on high speed configuration, not the most efficient....
On my F111 was only 4% elevator up...
Old May 04, 2014, 06:58 PM
Joined Jan 2013
Originally Posted by rajazo View Post
Isn't so simple. .. when you move the wings forward the Aerodinamic center put in front of the defined CG, then you get a tail heavy effects...
Maybe make the inverse could be easier (cg on forward wing)... produce noee heavy on tske off and landing
On normal swept wings the effect is inverse and nise hesvy appears. .. it's more easy to control and the plane is on high speed configuration, not the most efficient....
I get what you're saying if you're talking about the center of lift being pushed forward with the wings pushed forward relative to the CG. From the videos, it seems the CG doesn't move far enough to make that big a difference, though. This is not an F-14 with the lift near the CG and it should only be more stable when it's nose heavy like a standard delta. Trial and error may be the only answer.
Old May 04, 2014, 10:00 PM
skumgummi dave
Gresham, OR.
Joined Mar 2004
Robert:
Wow, wow, wow. Twój Inglés jest w porządku. Twój model jest niesamowity. Czekam na kolejną wspaniałą buduje. Dziękuję za plany beta. (Google Translate ...): o)
Ciepłe pozdrowienia;
-Dave
Robert:
Wow, wow, wow. Your english is fine. Your model is amazing. I look forward to another of your wonderful builds. Thank you for the beta plans. (google translate...) )
Warm regards;
Dave-
foamdave is offline Find More Posts by foamdave
Old May 04, 2014, 11:38 PM
BGR
Foam Junkie
United States, CA, Oceanside
Joined Dec 2003
If you use a stronger servo for the wings you could put the battery in a slide box and move it to change the CG as the wings swing.
BGR is offline Find More Posts by BGR
Build Log F-302 EDF from Stargate with plans robertus Scratchbuilt EDFs 74 Mar 31, 2014 01:41 AM
Discussion stealth drone from the movie STEALTH. built from scratch. crispy1074 Scratchbuilt EDFs 5 Sep 25, 2012 08:15 PM
Discussion stealth drone from the movie STEALTH. built from scratch. crispy1074 Foamy EDFs 7 Sep 21, 2012 02:01 PM
Discussion F/A 37 Talon Talon 1 Pusher Prop Jet Models 15 Feb 10, 2008 01:23 AM
really have F/A-37 Talon Sirio Fuel Jet Talk 9 Dec 15, 2005 09:26 PM
