Old Jul 09, 2015, 05:58 PM
animal53 is offline
Find More Posts by animal53
Joined Nov 2010
Help!
Foam cored wings
When I go to buy foam for a balsa sheeted wing , what do I ask for? There must be all sorts of types and densities!
animal53 is offline Find More Posts by animal53
Old Jul 09, 2015, 08:32 PM
Free2air is offline
Find More Posts by Free2air
Joined Dec 2014
My understanding is and my dlg and gliders use blue foam, its the best for shaping or sanding qualities and is not bad on weight it's insulation foam and used to be available at bunnings , tho it seems it could be a funny yellowish colour these days
Free2air is offline Find More Posts by Free2air
Old Jul 09, 2015, 08:37 PM
oziflyer is offline
Find More Posts by oziflyer
oziflyer's Avatar
Sydney Australia
Joined Sep 2004
No need to ask, just head to you local Bunnings and pick up a block....
See the last 2 pages of this thread...
http://www.rcgroups.com/forums/showt...light=bunnings
Blue, pink, yellow... same stuff.
oziflyer is offline Find More Posts by oziflyer
Old Jul 09, 2015, 09:03 PM
Curare is offline
Find More Posts by Curare
KE your cub.
Curare's Avatar
Australia, WA, Perth
Joined Jun 2005
NOT TRUE!
Depending on what type of wing you're making, you'll want to use heavier density stuff like XPS foam (extruded polystyrene), or SL (superlight) polystyrene.
If you're building a sport/aerobatic model, with a reasonably thick wing, you'll want to use SL foam, and sheet it with balsa, obechi, thin ply, or even card! the sheeting gives the strength to the wing, and really, the core is just there to hold the sheets apart so you want to have something as light as you possibly can.
This type of wing looks like this:
If you're doing a sloper, or DLG style wing that's bagged, then XPS is what you want. the higher density gives the wing some ding resistance, becuase if you distort the glass outer skin too much, you'll have a spot were the wing can buckle.
Bagged wings are generally done like this:
Choose your wing styles and takes your choice!!
Curare is offline Find More Posts by Curare
Old Jul 10, 2015, 06:34 AM
ZIPPER is offline
Find More Posts by ZIPPER
by ZIPPER
ZIPPER's Avatar
East Kurrajong Sydney Australia
Joined Aug 2004
IT'S PARTLY OF TRUE!
Depending on who you get your foam from will depend on the colour you get, its only a die that gives it the colour.
It is essentially all extruded polystyrene, but there is a large range of densities and cell structure.
The rule is: If you want a light plane, use light foam. If you want a heavy plane, use heavy foam.
ZIPPER is offline Find More Posts by ZIPPER
Old Jul 15, 2015, 02:58 AM
mavericko is offline
Find More Posts by mavericko
mavericko's Avatar
Australia, ACT, Majura
Joined May 2009
Differences with Blue and Yellow
Some suppliers have replaced the Blue foam (insulation foam made by Dow) with a yellow product SUPPOSEDLY having the same qualities/characteristics.
However, its not the same and it cuts differently and is kinda stringy. We have used the yellow for a few builds but now given it the flick
mavericko is offline Find More Posts by mavericko
Old Jul 15, 2015, 05:36 AM
ZIPPER is offline
by ZIPPER
ZIPPER's Avatar
Joined Aug 2004
I disagree. We have cut A LOT of wings (hundreds) with with the blue and the yellow foam and found it to be the same. We did have an issue with the quality of a couple of sheets that we got, it had lumps in it that the wire would catch on, it also had air bubbles through it, we changed to a higher density and the quality is much better.
We found that the air bubbles helped bond the skins to the foam because the adhesive would go into the bubbles giving a better bond. I now run a knife the length of the cores and at 45 deg, about 3mm deep, it gives a better bond and also acts like a small spar.
Old Jul 15, 2015, 07:49 PM
Curare is offline
KE your cub.
Curare's Avatar
Joined Jun 2005
Wow, sounds like you're one step away from the 'resin nails' in coremat™ that bond the top and bottom skins together
Old Jul 22, 2015, 10:11 PM
mavericko's Avatar
Joined May 2009
Its like chalk and cheese!!!!
Old Aug 01, 2015, 04:48 AM
Scaledown is offline
Find More Posts by Scaledown
It must have a machinegun
Scaledown's Avatar
Perth, Western Australia
Joined Sep 2004
Does anyone in Australia (or Perth preferably) cut foam cores to order?
Scaledown is offline Find More Posts by Scaledown
Old Aug 01, 2015, 05:08 AM
ZIPPER is offline
by ZIPPER
ZIPPER's Avatar
Joined Aug 2004
Off The Edge Sailplanes do them, but we are on the east coast.
Old Aug 06, 2015, 02:39 AM
mrmick77 is offline
Find More Posts by mrmick77
Joined Mar 2008
I think ijr or pnb mentioned they can cut them try asking on perth slope soaring mines awhile away from finishing (CNC one) got sick of making templates.
mrmick77 is offline Find More Posts by mrmick77
Old Aug 06, 2015, 06:15 AM
ZIPPER is offline
by ZIPPER
ZIPPER's Avatar
Joined Aug 2004
offtheedge.com.au
Old Aug 17, 2015, 05:13 AM
dont is offline
Find More Posts by dont
Have Wings, will Fly!
dont's Avatar
Perth, WA, "The land of OZ"
Joined Jul 2004
Scaledown,
What cores do you want cut?
What Airfoil, 1/2 span, cord, tip...?
I'm in Perth
dont is offline Find More Posts by dont
Old Aug 18, 2015, 12:29 AM
This guy is offline
Find More Posts by This guy
This guy's Avatar
Australia, WA, Ellenbrook
Joined Feb 2014
Its nice of you to offer your services to the kind people on this forum.
Glad to see you helping..
This guy is offline Find More Posts by This guy
Discussion Glue for foam core wings MWCores Sailplane Talk 19 Aug 20, 2015 08:25 AM
Discussion Best glue for lite ply- foam core wing Union? walter3rd Balsa Builders 10 May 25, 2015 03:04 PM
Discussion Profili Pro templates for cutting foam wing cores BillO CAD/CAM 3 May 05, 2015 11:46 PM
For Sale NIB, Wing MFG. Super Kaos Foam Core Wings? joemetal Aircraft - Fuel - Airplanes (FS/W) 0 Apr 03, 2014 10:51 AM
For Sale ACE Foam Wing Cores in Blu Dow Foam MWCores Aircraft - Sailplanes (FS/W) 4 Mar 05, 2014 03:53 PM
