Old Aug 26, 2015, 09:44 PM
Destroy is offline
Find More Posts by Destroy
Mil, WI
Joined Oct 1999
I'm getting jello but its the pulsing blurring that is more annoying.
Is vibration also the cause of this pulsing blur?
pulsing blur (0 min 40 sec)
Destroy is offline Find More Posts by Destroy
Old Aug 27, 2015, 01:30 PM
Terry Rigden is offline
Find More Posts by Terry Rigden
Terry Rigden's Avatar
UK, Bedworth
Joined Apr 2004
Apologies for going off topic but I just used mine to image an inaccessible area on my boat by attaching it to a stick. I just thought I'd mention that there are more uses for it than just hanging it on a toy aeroplane.
Terry
Terry Rigden is offline Find More Posts by Terry Rigden
Old Aug 27, 2015, 02:17 PM
Tom Frank is online now
Find More Posts by Tom Frank
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
https://www.youtube.com/watch?v=5nYf0oqGX6U
Does it do that with the camera stationary on the ground? That should answer your question.
I'm curious, though, what kind of aircraft is that you are flying? Vibration from normal prop-drive aircraft create low frequency and larger amplitude vibration, resulting in varying forms of "jello" waves. To blur the entire frame uniformly like that would require a VERY high frequency and low amplitude vibration. Ducted fan propulsion maybe... can't tell from the audio in the video?
It looks more like a problem with a cyclical compression codec pulsing, which other cameras of this small size have demonstrated. The #16 is not one of them, though.
Tom Frank is online now Find More Posts by Tom Frank
Old Aug 27, 2015, 08:07 PM
Destroy is offline
Mil, WI
Joined Oct 1999
The plane is a Dynam PBY-5A Catalina like this. I had the camera velcro'ed to a sponge foam piece then duct taped the whole thing( like a bandaid) to the top of the nose gunner plastic, in front of the cockpit windshield.
I did not realize these cameras are so sensitize to vibrations. The plane feels smooth and is very quiet at 1/2 throttle.
Old Aug 27, 2015, 08:19 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
The watermarks in the photo tells me the picture was not taken with the same #16 camera? Does the camera do the same blurring in 720-15fps that it does in 720-30fps? It's not normal... the plane motor audio in your video was very smooth, but volume must have been reduced quite a bit.
Last edited by Tom Frank; Aug 27, 2015 at 08:24 PM. Reason: corrected camera references - got off track with mobius in the #16 thread
Old Aug 28, 2015, 12:56 PM
zarquon77 is offline
Find More Posts by zarquon77
Joined May 2015
How long do these normally hold a charge? I got one a few weeks ago, and if I fully charge it, then don't end up using it for a while, say a few days to a week or so, it's generally stone dead. Is this normal?
zarquon77 is offline Find More Posts by zarquon77
Old Aug 28, 2015, 02:52 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
No it's not normal for a normal healthy battery! Charging to full voltage, unfortunately, tells you nothing about the health of the battery. If it has built up deposits and possibly even bridging between the+ and - plates, it can self discharge quickly in a worst case scenario, or not hold a full charge in spite of what the charging LED tells you. The battery still draws a tiny bit of power when turned off to the time/date clock running, but it should not run down a battery in the short time period you mention.
A few cases have been posted here where some kind of circuitry malfunction has caused rapid battery draining, but it's rare. You should replace your battery for starters. If it still does the same thing, perhaps there is some warranty relief available from your vendor (hopefully they are one of those listed in post #2 here.
Old Aug 28, 2015, 07:16 PM
Djob is online now
Find More Posts by Djob
Joined Jun 2015
Am I correct in that the #16 does NOT have any built in Image Stabilization feature?
Some videos on youtube have a very warpy or snaking look to them instead of vibrations and I was trying to figure out why that would be? Some post processing done to the video perhaps?
You are correct.
Djob is online now Find More Posts by Djob
Old Yesterday, 05:11 PM
Tom Eutsler is offline
Find More Posts by Tom Eutsler
Tom Eutsler's Avatar
Asheville,NC
Joined Jun 2002
Max Memory on Micro SD card
What is the Maximum size on a class 4 [ in Gb's] that one could use without going into "overkill " or going beyond the 16's capabilities ?
I have a 2 Gb installed but wanted to use one with a bit more capacity
thanks ................te
Tom Eutsler is offline Find More Posts by Tom Eutsler
Old Yesterday, 05:38 PM
Djob is online now
Joined Jun 2015
Lol just stick one in and you will find out.
I use 8 gb
Old Yesterday, 06:00 PM
Not a Number is offline
Find More Posts by Not a Number
United States, CA, LA
Joined Jun 2015
The user manual says 32 GB. You can go higher but you have to format the card with Fat32 and you won't get the full capacity of the card.
Not a Number is offline Find More Posts by Not a Number
Old Yesterday, 06:11 PM
Asheville,NC
Joined Jun 2002
Gb card
Thanks will order a 16 Gb. the card I have now , cut off Just at the point of my interest . Only later did I find some vid garbage on the card , which I had not erased [formating ]
................te
Old Today, 08:35 AM
zsumo is online now
Find More Posts by zsumo
(pr zedsumo)
South Africa, GP, Johannesburg
Joined Jun 2013
How do most of you attach this camera to your rc airplanes?
Whichever method you use, add a safety cord so that when you crash and it gets knocked loose, you won't have to spend two hours in long grass looking for it ... or, in the case of the Catalina, find scuba gear to cruise the bottom of the lake ...
zsumo is online now Find More Posts by zsumo
Discussion The REAL (#11) HD Key Cam Thread (PLEASE! READ POSTS #1-#3 BEFORE POSTING QUESTIONS!) Tom Frank Aerial Photography 9936 Feb 11, 2014 09:56 AM
Discussion Looking to buy #11 HD Key Cam within US Abolfazl Aerial Photography 1 Feb 14, 2012 01:59 AM
Poll Poll For Current and Future #11 HD Key Cam Users Tom Frank Aerial Photography 0 Sep 25, 2011 11:55 PM
Discussion New HD Key Cam CHAMP? 1080x720p 3 HOUR RECORD TIME! Jaybee Aerial Photography 4 Jun 02, 2011 11:39 AM
