Old Nov 29, 2015, 03:31 PM
mliebs is offline
Find More Posts by mliebs
United States, TX, Houston
Joined Aug 2015
Adding Eflites SAFE to an EDF jet
Can Eflites safe be added to and EDF jet?
mliebs is offline Find More Posts by mliebs
Old Dec 01, 2015, 03:15 PM
JeffS69 is offline
Find More Posts by JeffS69
Maverick
JeffS69's Avatar
United States, MI, Macomb
Joined Jan 2015
Short answer. Yes.
Only limitation is it's only a 5ch Rx . (Well 6 if you count SAFE). So you can either use the one Aux channel for gears or flaps. But not both. I use this in all my 64mm jets and ME-262. Works flawlessly. Here is a link for more detailed info.
http://www.rcgroups.com/forums/showthread.php?t=2135213
JeffS69 is offline Find More Posts by JeffS69
Old Dec 29, 2015, 07:13 PM
JeffS69 is offline
Maverick
JeffS69's Avatar
Joined Jan 2015
Update. Video showing how to use Eflite SAFE Rx using both gears and flaps together.
Setting up Flaps-Gear on 1 switch for SAFE Rx (5 min 52 sec)
Special thanks to Jim Lafferty. AKA Suenaga
Old Feb 16, 2016, 01:47 AM
Arnout is offline
Find More Posts by Arnout
Joined Feb 2016
Goodmorning
I understand how to set gear and flaps on the aux channel on the safe receiver from the apprentice
But could it be done with a dx6 or I rally need a dx9 ?
I cant figure it out with my New dx6 because it looks like im one channel short. ..aux 1 is use for the panic switch. I would like to lose the panic switch and use aux 1 for my retracts
Thanx Arnout
Arnout is offline Find More Posts by Arnout
Old Feb 16, 2016, 08:37 AM
bandetlol is offline
Find More Posts by bandetlol
United States, TX, Irving
Joined Mar 2015
If you wanted more channels, some of the better stabilizers have functionality similar to safe. The HobbyEagle A3 Super II you can set it up to limit bank angle and it has auto-level.
bandetlol is offline Find More Posts by bandetlol
Sold Eflite Apprentice SAFE RX from an Apprentice. stearman17 Aircraft - General - Radio Equipment (FS/W) 4 Aug 12, 2015 11:50 PM
Discussion safe receiver in a f-22 raptor 64mm edf jet gnat20 Beginner Training Area (Aircraft-Electric) 5 Jun 10, 2015 08:57 PM
Discussion SAFE receiver in an EDF Mokey Foamy EDFs 1 Mar 15, 2014 09:23 PM
