Old Nov 25, 2015, 03:04 PM
SeByDocKy is online now
Find More Posts by SeByDocKy
SeByDocKy's Avatar
France, PACA, La Valette-du-Var
Joined Dec 2012
Mini-Review
GW008 Skull Drone, a new sporty quadcopter (Under construction)
INTRODUCTION
Here is a new beasty nanoquadcopter, the GW008 Skull Drone a direct clone of the excellent UDI U939.
This model thanks to its larger motors offer more outdoors capacities without sacrifying indoors goodies.
BOX CONTENT
+ 1 x GW008 Skull Drone (with a 1S 150mAh LiPo directly soldered)
+ 1 x Transmitter (using 4xAAA batteries not included)
+ 1 x USB charging cable
+ 4 x Spare props (2 CW, 2 CCW)
+ 1 x Screwdriver
+ 1 x Instruction manual (English)
OVERVIEW
The U939 recloning is obvious: same canopy type, same lower part with transparent LEDs support. In another hand, the props are larger for the GW008 offering probably more thrust.
-Front view
Two white eyes give orientation. Out of the box, the bodyguard is pre-installed. Just pull gently to remove the two tiny clips per arm.
The plastic is a matte/smooth model.
-Side view
-Rear view
The four arms bight in orange color.
-Upper view
-Bottom view
As for the UDI, the battery can be removed. There is enough room to welcome a 200mAh as soon as you have to check the polarities of the battery.
-Weight
The GW008 is even slight lighter than the U939 (0.3g lighter)
Motors
Motors are 6mmx15mm coreless type so stronger than usual 6mmx12mm usualy used for nanos
LiPo
A 150mAh 1 cell LiPo battery ending with a 1.25mm miniJST connector. No discharge rate mentioned. Be aware, the connector are inverted versus the classic "miniJST" nomenclature. It means you will need absolutly to use the associated USB charger (put some mark on it), the same type of battery (U839/U939 batteries are compatible).
Disassembling
Just unclip the two latteral attach to pull the canopy part
The XN297 is used for the 2.4G part, the so classic MPU6050 for the 6-axis stabilization. Good news, the protocol is the same than for the CX-10 "green" edition, already hacked in DeviationTX.
The 2.4G antenna is perfectly tuned to 33mm
Just drill a small hole on the canopy to install vertically the antenna to extend the control range in the horizontal plane
Transmitter
4 x AAA to feed the transmitter. Notice, you need to tight screws to lock the battery door, it's a little bit annoying
The two shoulder buttons are trim buttons. In practice, only one flip button and one speed mode. No headless and pseudo one key return.
The flip button is harder to press than a classic shoulder one. To calibrate gyros, you need to turn on first the quad then while pressing the speed button to turn the radio and wait leds to flash. Can be done only once per session.
FIRST USAGE
When controlled with a Devo7E TX
GW008 first outdoors test with devo7E (Courtesy Banggood) (4 min 22 sec)
and with the original TX
GW008 Skull Drone new outdoors test (Courtesy Banggood) (7 min 22 sec)
CONCLUSIONS
Probably one the best nanoquadcopter in the market: powerfull, stable, fast, good range, oudoors able and good flight time. WIth its full propguard, the GW008 is also suitable for beginners. Minor con points (none standard miniJST connector, none shoulder flip button). WIth a potential payload of 3-4g, it would be posible to install a microFPV setup.
UNBOXING
GW008 Skull Drone Unboxing and quick analysis (Courtesy Banggood) (8 min 56 sec)
PROS
+ Great flyer
+ Super smooth and precize
+ Nice packagaging
+ Good radio range out of the box (approx 40-50m)
+ DeviationTX compatible (CX-10/Green protocol)
+ More than 6min of flying duration
+ Removable LiPo
+ Bodyguard
CONS
- Flip button should located on shoulder
- Yaw not proportional to speed mode (constant for the two rates)
- Inverted LiPo/connector polarities
- Calibration procedure
This quadcopter have been courtesy provided by Banggood in order to make a fair and not biased review. I would like to thanks them for this attitude.
You can find it actually for 18USD at http://www.banggood.com/GW008-Mini-Skull-2_4G-4CH-6Axis-Automatic-Parallel-System-3D-Rolling-RC-Quadcopter-p-999563.html
SeByDocKy is online now Find More Posts by SeByDocKy
SeByDocKy's Avatar
Joined Dec 2012
reserved1
Old Nov 25, 2015, 04:43 PM
SoloProFan is online now
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
We told you that you would like this one.
Good detailed review, and how does it fly compared to the 939?
SoloProFan is online now Find More Posts by SoloProFan
Old Nov 25, 2015, 04:46 PM
Lycan Animal is offline
Find More Posts by Lycan Animal
Vox Furry Regem
Lycan Animal's Avatar
Australia, VIC, Melbourne
Joined Dec 2014
Great autopsy! I hope they don't make any 'silent upgrades' to this one. I just wish there were more colours to collect. Any potential as a mini FPV platform you think?
Lycan Animal is offline Find More Posts by Lycan Animal
Old Nov 25, 2015, 05:01 PM
SeByDocKy's Avatar
Joined Dec 2012
A little bit less faster, just a fiew but banking better IMHO. I really like this one
Old Nov 25, 2015, 05:03 PM
SeByDocKy's Avatar
Joined Dec 2012
There is a red edition too ... but it's true more flashy colors can be nice
Thinking about this one: http://www.banggood.com/FPV-AIO-600TVL-170-Degree-mini-Camera-5_8G-8CH-Transmitter-All-in-One-Only-3g-p-1015137.html
Old Nov 25, 2015, 05:16 PM
Vox Furry Regem
Joined Dec 2014
Should easily manage? Plenty of power this one.
Old Nov 25, 2015, 05:33 PM
XFM is offline
XFM
Find More Posts by XFM
XFM
eXperimental Flying Machines
Joined Aug 2010
A very nice flyer
but I want to mod this one.
All white LEDs on the FCB channel the light through the red/orange tinted plastic arms
like optic fibre. So not as colourful.
The skull needs some plastic surgery Muhahaha !
XFM is offline Find More Posts by XFM
Old Nov 25, 2015, 11:47 PM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
With "yaw not proportional" you mean the yaw will no change between beginner setting and advanced, right? Because the yaw is very smooth and very proportional, as in it responds well to stick commands.
If that is what you mean, it might be more clear if you change it too "same yaw speed on all rates" or so.
Old Nov 26, 2015, 12:16 AM
SeByDocKy's Avatar
Joined Dec 2012
Yes you are right. In general, "yaw not proportional" means "Yaw not proportional with speed mode"
Old Nov 26, 2015, 12:24 AM
SeByDocKy's Avatar
Joined Dec 2012
I should review this module too (I will post in FPV section).
But here is my Ni Hui U207 FPV
http://www.rcgroups.com/forums/showthread.php?t=2226779
Old Nov 27, 2015, 09:20 AM
Vox Furry Regem
Joined Dec 2014
I remember you turning the u207 into a little FPV quad. It's where I got the thought that the GW008 might be able to do the same. That's a JXD 392 next to it?
Old Nov 27, 2015, 12:02 PM
SeByDocKy's Avatar
Joined Dec 2012
Yes "SeByMini" based on the JXD 392 one of my best FPV flyer
Old Nov 27, 2015, 12:07 PM
Vox Furry Regem
Joined Dec 2014
The JXD still on V2x2 protocol?
Old Nov 27, 2015, 12:19 PM
SeByDocKy's Avatar
Joined Dec 2012
Yes
Review Global Drone GW008 Skull Drone Quadcopter from Banggood.com Review DismayingObservation Mini Multirotors 20 May 18, 2016 12:47 AM
Mini-Review "Trick or Treat!" - GW008 "Flying Skull" Quadcopter review SoloProFan Mini Multirotors 116 May 17, 2016 06:48 PM
Mini-Review Mini Skull Quadcopter ( model GW008 ) from Banggood vojimen Mini Multirotors 0 Nov 06, 2015 11:37 PM
Discussion GW008 Mini Skull 2.4G 4CH 6Axis Automatic Parallel System 3D Rolling RC Quadcopter GeekBuying Mini Multirotors 1 Oct 06, 2015 01:05 PM
