Old Jan 16, 2016, 04:44 PM
beaverbuddy is offline
Find More Posts by beaverbuddy
New Zealand, Canterbury, Christchurch
Joined Sep 2011
Thanks for the update,Mutha.
Btw.,anyone ordering from oz w/house have any luck with the tracking?There are about 3 different Seko tracking sites,but none of them appear to work with HK,s tracking numbers.GGGGRRRR!.
I'll go back to page 65 now,plenty of reading to keep me quite till my bixler 2 arrives.
beaverbuddy is offline Find More Posts by beaverbuddy
Old Jan 18, 2016, 12:43 AM
Joined Sep 2011
Wow,here in 6 days.Well done,HK Oz.
As for the actual Bixler,appears to be quite nice finish to the foam.
Screws are 2mm and as such seem a bit puny.I bought some 3mm machine screws and 1/8" selftappers to replace them.
Also got some 4mm dowel to fit inside spar.The 1st lot i got claimed to be 4mm,but was closer to 5mm!(?????).Cr*p.Went to a different supplier,taking the spar with me for fit.The short lengths were all too big in diameter,but the 1.8m length fitted good.
I also got the wheel set with my bix,but I'm not too keen on the way it's fitted.
I found an alternative mount on thingiverse,so I'll put my 3d printer to work.
I'll have to wait for my servo extensions to arrive,so I can fit flap servo's.Waiting...........waiting...........
Old Jan 18, 2016, 02:35 AM
mutha is online now
Find More Posts by mutha
RC Airplane (Recently Crashed)
mutha's Avatar
Australia, VIC, Melbourne
Joined Jan 2011
Good luck with it ....
mutha is online now Find More Posts by mutha
Old Jan 18, 2016, 08:25 AM
LuxKeiwoker is offline
Find More Posts by LuxKeiwoker
Joined Mar 2015
Has anyone made the wing magnet mod and is using a compass? Thinking over getting rid of the screws and using some strong magnet to hold the wings together. But I'm worrying over bad influence on the external compass of my APM.
LuxKeiwoker is offline Find More Posts by LuxKeiwoker
Old Jan 19, 2016, 01:55 AM
gbmarsh is online now
Find More Posts by gbmarsh
Wait...what?
gbmarsh's Avatar
Canada, BC, Abbotsford
Joined Sep 2010
Yeah, stay away from the magnets if you are using APM, I even got rid of the cockpit magnets on mine. Use something like the velcro method instead and enjoy rock solid navigation with your APM
Cheers,
Geoff
gbmarsh is online now Find More Posts by gbmarsh
Old Jan 19, 2016, 05:30 PM
Joined Mar 2015
Thanks - so in that case I will ditch the idea and will use the screws instead.
Old Jan 19, 2016, 08:34 PM
Joined Sep 2011
I note there is now a disclaimer on page 1 of the manual:"Do not fly this Airplane at full throttle for long periods of time,recommended 20-25 second burst!"
This means HK knows about the problems with the power setup,yet chooses not to fix them!
I know it's dirt cheap,but that does not excuse selling a plane with an unsuitable motor.By all means put the price up by a couple of dollars,but for goodness sake,put a halfway decent motor in it.Rant off.
I've fitted a 4mm dowel inside the cf spar,which makes it quite a bit stiffer.
Just waiting for my servo extension cables,so i can fit the flap servos.
I've also ordered a 2826-6 1400kv motor from a local supplier.That means it'll cost me 30 bucks,but [I] didn't want to wait another 2 weeks for stuff to arrive.
On a side note,it appears NZ Customs now open all parcels from hobbyking,to check for li-po .
It seems you are no longer allowed to import them.
Another clueless politician at work
Old Jan 25, 2016, 04:21 PM
Cesco is offline
Find More Posts by Cesco
Cesco's Avatar
Joined Dec 2007
With original motor/prop i did 14min of flight using a 2200mah 3S lipo down to 3.85V/cell. What flight times can i expect with bigger lipo´s? I got a 3S 2650 and a 3800 here.
Calculating a speed of 50km/h this would be 15km distance for the 2200mah lipo. I need to double that distance ...
Cesco is offline Find More Posts by Cesco
Old Feb 02, 2016, 08:54 AM
zanthor is offline
Find More Posts by zanthor
Dirt Dobbins
United States, IA, Des Moines
Joined Dec 2014
I got my bixler kit on the Black Friday deal and all I have to say is I'm pissed... that I didn't buy two!
As my first fixed wing it's been a great learning tool but has taken a beating as well. I learned about the boiling water trick to repair the foam yesterday and fixed the crumpled nose from my first bad flight as well as the motor mount that broke yesterday.
Since my canopy blew off I also figured it was time to jump on the FPV train... I think I'll wire up a MinimOSD to a Naze tonight so I can get some artificial horizon action.
zanthor is offline Find More Posts by zanthor
Latest blog entry: Diverse Diversity
Old Yesterday, 11:48 AM
noobiznessflying is offline
Find More Posts by noobiznessflying
Fly more, bitch less.
noobiznessflying's Avatar
United States, CA, Arcadia
Joined Nov 2010
had my maiden flight of my brand new bixler 2 yesterday. Found out that stock motor is quiet anemic as it struggled to reach higher altitudes.
overall nice plane and much better build than my old dynam hawk sky. just not very happy with the stock motor but eh...its an easy enough upgrade.
Can't wait to FPV her after I upgrade.
noobiznessflying is offline Find More Posts by noobiznessflying
Old Today, 06:32 AM
chucky21022002 is online now
Find More Posts by chucky21022002
Joined Oct 2011
This is the difference between a stock motor and the upgrade motor. It is a Ntm prop drive 28mm 2200kv. The Bixler will take off at 1/4 throttle against a headwind of 25mph.
chucky21022002 is online now Find More Posts by chucky21022002
Discussion Hobby King USA Warehouse wait time for bixler and 9x? elcid79 HobbyKing 13 Jun 09, 2014 09:13 AM
Discussion Hobby King Bixler motor? wehrwolfzug Power Systems 6 Mar 01, 2014 12:33 PM
Discussion Hobby King Buddy codes for Bixler FPV Build xxdixonxx Hot Online Deals 0 Jun 19, 2012 01:51 AM
Discussion Hobby king Bixler Buddy Code aaluu Foamies (Kits) 1 Feb 23, 2012 01:06 PM
