Old Jan 30, 2015, 02:30 AM
Mr Solution
TMASTER's Avatar
TX
Joined Aug 2004
Help!
DSM2 TX/AR6400 brick throttle channel is reversed
Some how I managed to reverse the throttle channel on this little cheapy DSM2 transmitter to the brick, so when the left stick is down its full throttle, and when its up it's no throttle. The motor is going in the right direction though.
Does anyone know how to reverse the throttle channel back on the brick? I have been through 3 different manuals for this transmitter and brick and there is nothing on reversing it. Only the other channels.
Is there a master reset for the brick?
I got it fixed
Turns out I just needed to program it back to brushless mode, because I am using a brushless esc wired to it. In brushed mode with the brushless ESC wired up the throttle stick was reversed. I guess it has to do with the 3 pin connector changing signals or polarities when switching motor modes.
TMASTER is offline Find More Posts by TMASTER
Sold Spektrun 6 channel brick (ar6400) + motor fm_head Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Oct 03, 2014 04:37 PM
For Sale (2) new 3A 1s Bl esc with ar6400 servo connector will trade for ar6400 brick nemoskull Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Jul 08, 2014 09:39 PM
Found Looking for an AR6400 brick (or planew/brick)) mr.fowl Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Mar 23, 2014 03:03 AM
Wanted AR6400 Brick Receiver DSM2 PonyMan Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Oct 27, 2013 07:05 AM
Sold AR6400 Brick Receiver DSM2 scharlach Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Oct 09, 2013 10:44 PM
