Old Mar 03, 2015, 01:41 PM
thedeuce's Avatar
Canada, AB, Okotoks
Joined Apr 2007
Thanks for the kind words Kerry and Shane.
I don't have rudders, but with this flight it is so easy to fly that I don't think I will install them. With the power setup I have right now it's fairly quick, but the thrust to weight is very close to 1.5:1. Crazy vertical. On the next flight I will get a true amps/watt/weight reading.
John
thedeuce is offline Find More Posts by thedeuce
Old Mar 03, 2015, 01:57 PM
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
John , so great to hear of a successful flight. I may be retired, but so much in the way right now-- progress on mine has come to a stand still. Time to go through my building area start tossing stuff- early spring cleaning-- just no room to work.
With luck I'll get back on mine, next week. Got to have something to learn on, when it comes time to build this--
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Mar 03, 2015, 02:43 PM
thedeuce's Avatar
Canada, AB, Okotoks
Joined Apr 2007
Thanks, I'm glad it went well too
That's a great looking fuse, do you have the specs? Size, manufacturer etc? Would love to make a pusher out of something like that.
john
Old Mar 03, 2015, 03:49 PM
Joined Dec 2008
Here you go-- http://www.yellowaircraft.com/jets/f18s.htm
I paid around $400.00 for it-- although it was missing a few small parts-old kit that's why the lower price--got them from fellow members in a short time.
Retracts , struts and wheels . where even more than the kit!
If you don't mind doing some building/fabrication-- give Charles a call and sere if he has a fuse left--but don't wait too long--these are going the way of the dinosaurs--extinct.
his number is here-- http://www.yellowaircraft.com/order.htm
If he has one left. it will be a polyester fuse-- which I've been told, is lighter than epoxy? Good luck on your quest!
Mark
Old Mar 03, 2015, 03:55 PM
Joined Dec 2008
That would maker one big arsed pusher for sure--
Definitely not a belly lander -- unless you own stock in as prop company~!
length:......................67.5"
Wing Span:......................47"
Old Mar 04, 2015, 10:04 AM
thedeuce's Avatar
Canada, AB, Okotoks
Joined Apr 2007
Cooler,
Our foamie's are not much different in size to that one, no? But the yellow F18 looks huge
John
Old Mar 04, 2015, 10:38 AM
Joined Dec 2008
John, yes they are close- but ours/mine are/is onl;y 64.5 " long-- and ws is only 44" or so. Also a big difference in fuse width. The Y/A is much wider.
You will only notice that when you come to install retracts. With the gear I have, and a JF 90, not to much room to squeeze it all in.. Just barely
As a pusher, belly lander , you'd never see the difference. .... Anyway, that build is a ways off right now-Just wanted to get one B-4 there all gone.. I may have got the last one of the polyester fuses. ???
My shop/building area was looking like I was a hoarder.. time to clean house.. ... early spring cleaning! My younger son and his wife came over yesterday and disposed o f some stuff for me..
Don't get me wrong here-- after my stroke I'm not an invalid-- but no way can I wrestle a couch out the door any more!...Got a couple of lazy-boys coming tomorrow, needed the room.
Still have lots more cleaning to do, but it takes time-- can't stand for a long time, and my balance it still a bit off. Makes for an interesting day!
Discussion KMP ParkPilots F-18 thedeuce Foamy EDFs 5 Oct 08, 2012 12:20 AM
Discussion Kmp f-18 Roguemonkey Electric Ducted Fan Jet Talk 10 Mar 10, 2011 12:54 PM
Discussion KMP Glass F-18 splais Electric Ducted Fan Jet Talk 14 Feb 04, 2011 07:41 PM
Sold EJF/KMP F-18 foam bruff Aircraft - Electric - Jets (FS/W) 5 Aug 07, 2007 02:31 PM
Discussion Kmp F-18 Eps Foam Edf Jet PREACHHAMES Foamy EDFs 120 Feb 20, 2007 09:28 AM
