Old Feb 25, 2015, 07:35 PM
Enterprise7 is offline
Find More Posts by Enterprise7
Huckin around the Shire
Enterprise7's Avatar
USA, NH, Manchester
Joined Jun 2010
Build Log
Extreme Flight 91" Extra with Hacker Q80-6L, 7000+ watts
This is a build log of a Extreme Flight 91" Extra setup with a 85cc equivilant electric. This ARF is a bit on the bigger side of 60cc planes and has only really come into it's own now with the DA-70 and DA-85 setups. I set out to get a similar power level from a electric, or maybe even a little more. I will update the first page posts as I move along on the project.
Enterprise7 is offline Find More Posts by Enterprise7
Old Feb 25, 2015, 07:36 PM
USA, NH, Manchester
Joined Jun 2010
Components used. I am in no way sponsored by anyone and paid for every bit.
Extreme Flight 91" Extra 300 EXP
http://extremeflightrc.com/html/91Extra.html
Hacker Q80-6L
http://www.espritmodel.com/hacker-q8...ion-motor.aspx
Hacker Spin 170 (same as Jeti 200 as best as I can tell)
http://www.hacker-motor-shop.com/e-v...&c=5583&p=5583
Jeti 200A main switch (safety first with this much instant power)
http://www.espritmodel.com/jeti-powe...ss-switch.aspx
Jeti Central Box 200 with 2 R3s and magnetic switch (radio only seems to support 1 wireless switch)
http://www.espritmodel.com/jeti-cent...ceivers-2.aspx
2x Castle BEC pro set to 8.5V
http://www.castlecreations.com/products/ccbec.html
5x Hitec 9370TH brushless servos
http://hitecrcd.com/products/servos/...-servo/product
71mm custom standoffs. I should have gotten them drilled for M6 as that is what the hacker mount is. Found bushings for M5.
http://customstandoffs.com/
Truturn 3.5" turbo-cool spinner.
http://www.truturn.com/cgi-bin/store...exact_match=on
Scorpion X-Large straps
http://innov8tivedesigns.com/scorpio...ck-extra-large
Spot On 1.75" arms M3 for aileron and rudder
http://www.aztechaeromodels.com/inde...product_id=481
USA, NH, Manchester
Joined Jun 2010
This is reserved for build photos and comments.
Old Feb 25, 2015, 07:37 PM
USA, NH, Manchester
Joined Jun 2010
Videos
9370TH servo test I did to decide wether to put these into this plane.
Hitec 9370TH torque test (0 min 35 sec)
First run with 24x10TH and normal mode.
Q80-6L first run (1 min 34 sec)
Second run with 24x10TH and fast response mode.
Q80-6L second run (0 min 26 sec)
Third run with 26x10TH and fast response mode. Got out of timing a few times.
Copy of Q80-6L third run with 26x10TH (1 min 19 sec)
Maiden day hover pull out.
Matt's 91 electric (0 min 33 sec)
Maiden day tooling around.
Matt's 91 (1 min 1 sec)
USA, NH, Manchester
Joined Jun 2010
This is reserved for project comments and review
Old Feb 25, 2015, 07:59 PM
Eagle2Nitro is online now
Find More Posts by Eagle2Nitro
Unregistered User
Eagle2Nitro's Avatar
United States, LA, St Francisville
Joined Apr 2014
This is reserved for pictures of me drooling (91" electric? Awesome)
Eagle2Nitro is online now Find More Posts by Eagle2Nitro
Latest blog entry: My Youtube Channel
Old Feb 25, 2015, 08:01 PM
USA, NH, Manchester
Joined Jun 2010
Component weights, add as I get them.
Fuse with rudder, servo, linkage, extensions, and ESC 2466g
Canopy 455g
Cowl 290g
Wing panel with servo and linkage 810g x2
Elevator half with servo and linkage 266g x2
stab tube 24g
wing tube 186g
Landing gear with wheels and hardware 410g
Wheel pant 55g x2
Electronics
Hacker Q80-6L with bullets 1383g
Standoffs and bolts 167g
BEC pro 46g x2
Thud Pow 70C 6s 6000 with castle connector 929g
Mej 26x10TH 222g
PRELIMINARY weight of assembled fuse with no batteries (main or RX) and no prop or spinner is 13.15 pounds.
3.98 for wings and tube
.66 for prop and spinner
17.8 pounds before batteries.
4.1 pounds for main packs
.5 pounds for RX packs
22.4 pounds
Old Feb 25, 2015, 08:12 PM
Buzzed is offline
Find More Posts by Buzzed
3D Sunset Flier
Buzzed's Avatar
PHX
Joined Jun 2008
Oh man! 7000 watts of fun.
Can't wait to see her fly.
Buzzed is offline Find More Posts by Buzzed
Old Feb 25, 2015, 08:13 PM
bryansifsof44 is offline
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
Awesome look forward to you build... Oh and some vids too.
Subbed
bryansifsof44 is offline Find More Posts by bryansifsof44
Old Feb 25, 2015, 08:16 PM
Mr Kamikaze is offline
Find More Posts by Mr Kamikaze
I'm torquing to you!
Mr Kamikaze's Avatar
Wattle Grove NSW Australia
Joined Nov 2006
Lol...
Looking good!
Mr Kamikaze is offline Find More Posts by Mr Kamikaze
Old Feb 25, 2015, 08:30 PM
Joined Oct 2011
Matt could you elaborate on your duel BEC pro setup? Thanks
Old Feb 25, 2015, 08:54 PM
USA, NH, Manchester
Joined Jun 2010
I will get a photo when I install it. I intend to run a tap off of each 6s battery in the harness to a BEC. The CB200 works like a powersafe, where it picks the higher of the two. I did a brief test and it is pulling from both BECs, This way I have redunacy without having 2 more batteries and it will get a constant 8.5V. Also the BECs will be working off 25V instead of 50V.
Old Feb 25, 2015, 09:24 PM
alvinsmith75 is offline
Find More Posts by alvinsmith75
Joined Jan 2015
Subscribed
alvinsmith75 is offline Find More Posts by alvinsmith75
Old Feb 25, 2015, 09:33 PM
gmarsden is offline
Find More Posts by gmarsden
Joined Oct 2011
I have the same motor and plane but only prop it up to about 5000 Watts with a 24x10 TH or 24x12 Xoar.
What prop and batteries do you plan to use?
gmarsden is offline Find More Posts by gmarsden
Old Feb 25, 2015, 10:30 PM
Joined Oct 2011
Awesome idea, I run the BEC pro of 25V on my 12s systems too. Bullet proof plan, IMO. Only advice I have is to secure the wires where they exit the housing with hot glue or something comparible and the secure the slack in the wires. Only failures I have seen have been wires breaking in the housing, and you have two that are redundant.
For Sale Extreme Flight 91" Extra 300 W/ Extras WILL SHIP jlloyd1995 Aircraft - Fuel - Airplanes (FS/W) 0 Sep 25, 2014 01:34 AM
Sold Hacker Q80-6L akabek Aircraft - Electric - Power Systems (FS/W) 1 Oct 17, 2013 06:16 AM
Discussion Hacker Q80-6L with Spin 200 setup akabek Power Systems 3 Apr 12, 2013 07:57 PM
Discussion Hacker Q80 6L fu-corsair Power Systems 3 Jan 31, 2013 06:54 AM
Discussion Hacker Q80-6L/33 extra 260 tileflier Giant Electric Planes 13 Nov 14, 2012 10:30 AM
