Old Jun 20, 2015, 09:34 PM
rotccapt is offline
Find More Posts by rotccapt
that tree ate my plane
rotccapt's Avatar
oklahoma city oklahoma
Joined Apr 2004
using ez links for biplane wing attachemt
hi all i am building a 32 inch biplane and for storage sake i would like to make the wings removable. my original plan was to just attach the top wing with screws but after starting the build i decided this would be a futile effort. so i had a though of making some quick connectors out of music wire. i might still use them, but then i had the though of using the ez pushrod connectors that dubro makes and use them to connect the inter-plane struts. the center section would also be on a kind of quick pin.
here is my idea for the pins that i came up with. what are your thoughts on the over all idea
rotccapt is offline Find More Posts by rotccapt
Old Jun 20, 2015, 09:41 PM
Grup is offline
Find More Posts by Grup
Grup's Avatar
doha Qatar
Joined Jan 2004
Take a look at how the Parkzone Albatross wing is attached, in particular the outer struts.
The struts are hollow; a pin is attached to the wing which fits into that hollow tube. Then there is a hole drilled through both of these nested parts, horizontally aligned with the direction of the fuselage.
A metal wire runs through this and locks the wing into the strut. It works pretty good, and it's quick
Regards
Grup is offline Find More Posts by Grup
For Sale 22" high wing aerobat & 22" biplane, ARF (price reduced) JGAF Aircraft - Sailplanes (FS/W) 1 May 29, 2015 11:55 PM
Wanted I Need a Fly Zone Stagger Wing Biplane for Parts bayou_city_boy Aircraft - Electric - Airplanes (FS/W) 1 Sep 25, 2014 07:58 AM
Sold Using EZ OSD? Add Antenna Tracking for $160 shipped Milktruck Aircraft - Electric - Multirotor (FS/W) 1 Dec 19, 2013 11:19 AM
Idea using elevon control on standard scale flat winged biplane model dcwwcp Modeling Science 19 Nov 15, 2013 06:08 PM
Sold 3 Planes for $150...EZ Star, Biplane, Warbird 500Driver Aircraft - Electric - Airplanes (FS/W) 10 Aug 21, 2009 09:05 PM
