Old Mar 30, 2015, 07:40 PM
AleksUAV is offline
Find More Posts by AleksUAV
Joined Mar 2015
First time build need help
Hello everyone i currently own a 3dr Iris+ and have decided that i wanna build my first quad because my iris can only fly for about 12mins with gimbal. I want my new quad to be able to flight for atleast 30mins with video equipment but would like to fly longer of course. I will be using electronics from my IRIS and have bought a new frame which are the PIXHAWK +gps and telemetry. I have purchased a new frame which is the H4 680mm Alien.
So what i need is help with picking the motor(s), speed controller(s), and battery
with the H4 frame i think the max prop size is 16
I am estimating that weight will be around 1900-2100grams depending on motor and battery setup. the current weight with just the frame +controller+ video equipment is around 1100grams
Anyway your help would be appreciated
AleksUAV is offline Find More Posts by AleksUAV
Old Mar 30, 2015, 07:55 PM
Oldgazer is online now
Find More Posts by Oldgazer
Oldgazer's Avatar
United States, VA, Richmond
Joined Dec 2013
You might want to build a hexacopter instead.
And read this:
For any platform of any size and weight, the flight time is the result of:
time = whkg / (1000*R / eff_gw) * 60, where
whkg = battery energy density, in Watt hour / kg, ranging from about 150 for the high C packs to 270 for LiIons. 10C Multistars are 185.
R = ratio between AUW and battery weight
eff_gw = motor/prop efficiency, grams per Watt, taken from mfr data.
Be aware to get from table the efficiency for the intended thrust, and for 50% throttle !
Efficiency greatly depends on load, so don't use efficiency stated for 1kg, to compute flight time of 2-3 lg platform !
Also, don't use values for more than 60% throttle, the platform will be unstable, no more room for motors to do their control job....
As I wrote, this formula works for ANY size platform and energy source, lets do the math for some particular cases:
Case I Ph2
battery wh/kg = 5.2(Ah)*11.1V/0.37(kg) = 156wh/kg
R ratio between AUW and battery = 1250/370 = 3.4
propulsion efficiency = 11g/W
time = 156 / (1000*3.4 / 11) * 60 = 30 min
Case 2 the 129 min record
battery wh/kg = 266Wh/kg - typical LiIon energy density
R ratio between AUW and battery = 3.4/2 = 1.7
propulsion efficiency = 14.1g/W
time = 266 / (1000*1.7 / 14.1) * 60 = 132 min
And finally, my 30 min case
battery wh/kg = 165, I use a Zippy Compact, having a bit more energy than the average LiPo
R ratio between AUW and battery = 0.75/0.195 = 3.8
propulsion efficiency = 11g/W - using Phantom 2 clone
time = 165 / (1000*3.8 / 11) * 60 = 28 min
As you can see from the above, reasonable precision of all estimations, proving this formula is valid for any configuration, so now you have a tool that should tell you what is wrong in your setup, and where to work to improve flight time.
The biggest unknown for most users is the propulsion efficiency, for this reason I think is mandatory to not buy stuff without manufacturer precise specification of this parameter.
renatoa is offline Send a private message to renatoa Find More Posts by renatoa
Oldgazer is online now Find More Posts by Oldgazer
Old Mar 30, 2015, 08:15 PM
AleksUAV is offline
Joined Mar 2015
thanks for the post need afew minutes to understand the math
well i ordered the frame yesterday so im gonna build around that
Old Mar 30, 2015, 08:44 PM
AleksUAV is offline
Joined Mar 2015
Im stuck on how to get the propulsion efficiency im on hobbyking looking at every motor between 300-400kv but i dont see it anywhere
Discussion DJI Flame Wheel F450 - First Build - Help Needed! GoProDavidLe UAV - Unmanned Aerial Vehicles 2 Jan 28, 2015 09:31 AM
Help! Looking for help with a first time quad build Teodor_p Scratchbuilt Multirotors 0 Jan 23, 2015 01:57 AM
Discussion First time building a quad! need help! new_to_rc Multirotor Talk 4 Jan 12, 2015 02:33 AM
Discussion DJI Flame Wheel F450 - First - Build - Help Needed! GoProDavidLe Multirotor Talk 14 Dec 30, 2014 07:19 AM
Discussion first time building need help with CC3D garysnooker Scratchbuilt Multirotors 5 Dec 14, 2014 04:02 PM
