Old Apr 14, 2015, 02:37 PM
ncflyer79 is offline
Find More Posts by ncflyer79
ncflyer79's Avatar
United States, NC, Marion
Joined Jun 2011
Originally Posted by Diamond Hobby View Post
Approx 10 mm
is that 90, 95, or 100 degrees
ncflyer79 is offline Find More Posts by ncflyer79
Old Apr 16, 2015, 11:07 PM
Neil_SC is offline
Find More Posts by Neil_SC
United States, MA, Lowell
Joined May 2004
Has anyone found metal servo arms that fit the stock FMS servos? I know that there are two sizes. I'm not sure if the spline is shared with one of the other major brand servos or not. They don't appear to have the same spline as Hitec.
Neil_SC is offline Find More Posts by Neil_SC
Old Apr 17, 2015, 10:05 AM
Diamond Hobby is offline
Find More Posts by Diamond Hobby
Diamond Hobby's Avatar
United States, FL, Tallahassee
Joined Mar 2013
90 degree
Diamond Hobby is offline Find More Posts by Diamond Hobby
Site Sponsor
Old Apr 17, 2015, 01:18 PM
jwellsy is online now
Find More Posts by jwellsy
United States, IL, Champaign
Joined Aug 2012
Another option is to use carbon fiber servo arm extensions that fasten to the OEM arms. You can either cut your own or buy a pre-made set. I have used this set with great results
http://www.redwingrc.com/index.php?m...products_id=84
I'm sure there's others out there, HK may be worth searching for something similar.
jwellsy is online now Find More Posts by jwellsy
Old Apr 17, 2015, 01:29 PM
Joined Mar 2013
I have looked at most major manufacturers, even looked at Weak Signals and found nothing that would work. I have asked our factory to look into and see if there is a Chinese manufacturer that could supply .
Site Sponsor
Old Apr 17, 2015, 01:58 PM
Joined Aug 2012
The ones in the link work for me just fine. I wouldn't use them in a 100cc Beast. I've never seen a foam plane strip out the servo arm teeth in decent sized metal gear servo. I think I saw it once on a little bitty plastic gear servo when the control surface got bumped.
Old Apr 17, 2015, 04:40 PM
Neil_SC is offline
Joined May 2004
I'm not interested in the metal arms to get a longer throw so the carbon fiber arms don't meet the requirements. I would just feel that it's more secure if the arm was metal and is less likely to break or for the teeth on the arm to strip. I hear people say it's just foam, it will be ok. But this is a 12-13 lb airplane regardless of what it's made off.
Old Apr 17, 2015, 10:18 PM
Joined Aug 2012
Do you have metal gear servo's? If they are not metal gear servo's, then metal servo arms have little advantage.
Old Yesterday, 06:01 PM
missle is online now
Find More Posts by missle
missle's Avatar
West Chester, Ohio
Joined Nov 2006
Big power setup! Yeeeeppppppyyyyy
So I've finally got back to getting my baby all setup with the big power. Here's the 2nd vid of her today. What ever you do, zone out the two idiots talking in the vid, and just blast the sound come from that prop
FMS Corsair 1700mm on STERIODS! (4 min 50 sec)
missle is online now Find More Posts by missle
Old Yesterday, 11:55 PM
YLFlyer is online now
Find More Posts by YLFlyer
YLFlyer's Avatar
United States, CA, Yorba Linda
Joined Mar 2013
Nice flight. I understand your logic on flying clean without flaps initially but she slows down so nice and smooth with flaps. It should helps your landings grease in better. Not sure if it's just your flight gitters or your elevator setting but you may want to throw some expo in or reduce the throws to reduce the porpoising. She looks and sounds great!
YLFlyer is online now Find More Posts by YLFlyer
Old Today, 03:01 AM
Neil_SC is offline
Joined May 2004
The stock FMS servos that come with the Corsair are metal gear servos.
Old Today, 08:21 AM
missle's Avatar
West Chester, Ohio
Joined Nov 2006
Thanks YL. Yea I've got prop 20-30 flights on her and I loved using full flaps, but that was before the massive power upgrade and I still need to get the CG back a little more. Just before that flight I had just put 1 oz of lead in the tail which made it a little better, but still not right and obviously with the gear down it's even more pronounced. I think I'm going to make some motor lead extensions and move the Talon 100 further back into the center bay area. I refuse to use dead weight to balance the CG when I can move other components around and I'm only talking 6-8" motor leads using castle 10g motor wire.
Old Today, 10:06 AM
YLFlyer's Avatar
Joined Mar 2013
I see. I forgot your ESC and there for CG was changed. That explains the flight changes. Looks great though. I can't tell from watching. How much speed do you think you gained? I can only guess it may be 10 mph from watching the video.
New Product FMS North American P-51 D Mustang 1700mm (67 inches!!!) Beltpilot Electric Warbirds 9947 Apr 13, 2015 04:10 AM
New Product FMS P-47 1700mm wingspan!!! HLC SHOP Electric Warbirds 2566 Mar 18, 2015 12:20 PM
Wanted Needed Airfield/FMS F4U Corsair Spare Parts godofthunder77 Aircraft - Electric - Airplanes (FS/W) 2 Jun 29, 2011 03:17 PM
Discussion FMS/Airfield 800mm F4U Corsair norco kid Electric Warbirds 3 Apr 30, 2011 06:22 PM
Help! airfield/FMS F4U Corsair help kayla95 Electric Warbirds 2 Mar 24, 2011 06:12 PM
