Old Feb 17, 2014, 05:34 PM
Joined Nov 2013
Idea
One Way Retracts, hand launch land on gear.
I would like to make some one way (for lack of a better term) retracts. I want to be able to hand launch and deploy the landing gear from the radio before coming down to land. Maybe with use of rubber bands or spring loaded with a small servo to trigger them. Has anyone done something like this or have any idea on it?
Gerald Sharp is offline Find More Posts by Gerald Sharp
Old Feb 17, 2014, 05:40 PM
Marty Petri Sr.
mbpetri's Avatar
Thailand, Uttaradit, Bo Thong
Joined Jun 2007
It could be done, but there are some serious mechanics involved. Probably easier and cheaper just to use standard retracts.
What size and weight model are you talking about?
Marty
mbpetri is offline Find More Posts by mbpetri
Old Feb 17, 2014, 05:47 PM
Joined Nov 2013
T-50
Marty
I want to put them on a Fancy Foam Cessna T-50 Bobcat. it;s a 30in wing span and in standard configuration should com in at about 7oz.
Old Feb 17, 2014, 07:52 PM
Don't look at me like that....
62pilot's Avatar
United States, AR, McDougal
Joined Aug 2005
Hardwood blocks with brass bushings and carriers, two springs a couple of servoes. weigh more than the plane, just buy a set of micro retracts and be done with it.
62pilot is offline Find More Posts by 62pilot
Old Feb 17, 2014, 10:58 PM
Marty Petri Sr.
mbpetri's Avatar
Joined Jun 2007
Check if the GWS retracts will support that weight, cheap and simple.
Marty
Discussion One way retracts for hand launch but gear landings. Gerald Sharp Indoor Pattern/F3P 0 Feb 17, 2014 05:10 PM
Discussion A hand-launched glider designed for aerobatics on flat land? wolfv Hand Launch 12 Dec 14, 2013 11:30 PM
Discussion Advice on best way to find CG on f550 with landing gear? Troiano27 Multirotor Electronics 0 Oct 05, 2013 08:53 PM
Discussion Take-off & land or hand-launch/belly-land?? Gort@69 Electric Warbirds 23 Apr 28, 2012 12:34 PM
Question Parkzone T-28 Trojan: Can it land on grass? Hand launch? ColoradoDale Parkflyers 3 Sep 24, 2008 07:18 AM
