Old Aug 27, 2014, 07:33 PM
Joined May 2008
Help!
Recomend me a 3d profile plane for 17g motor,10 amp ESC
I have searched for at least 3 days and still have not come up with anything. I figure I need to be around 4oz AUW and will be using 350mah 2cell lipos . Will be using this motor. 2211-17 17g
http://http://www.lazertoyz.com/2211-17-17g_p_14.html
BigTruckDriver is offline Find More Posts by BigTruckDriver
Old Yesterday, 01:33 PM
CaptBojangles's Avatar
Joined Feb 2009
Try something like the ones in this thread perhaps? You could tweak the control surface sizes to make it 3d:
http://www.rcgroups.com/forums/showthread.php?t=1771408
Also, what prop will you be using? If you want a 3d plane, I'd pick the 7035, which means according to the specs on the page you linked, your 10A ESC is a bit overkill.
CaptBojangles is offline Find More Posts by CaptBojangles
Old Yesterday, 05:34 PM
Joined May 2008
thanks , I have not seen that . I will look into it. I was hoping to use the 8043 prop since my other planes use the same. Also will have to look into the ESC. The ESC is one that came in a combo package they recommend for the motor. http://www.lazertoyz.com/2211-17-17g_p_14.html
I did come across this one also.
http://www.rcgroups.com/forums/showthread.php?t=796111
Help! ESC programming manual for A-10 with 80 amp ESCs. The Don Banana Hobby 6 May 03, 2014 06:00 PM
Discussion 14% OFF New Dynam Peaks 42" RC 4 Channel 3D Bi-Plane ARF w/ Brushless Motor + ESC ARF nitroplanes Hot Online Deals 3 Nov 16, 2013 12:05 PM
Wanted Motor and ESC For Great Planes Sukhoi 3D ARF Profile RD Gator Aircraft - Electric - Power Systems (FS/W) 8 Apr 29, 2010 11:37 AM
For Sale $69. MP Jet motor + Jeti esc for 10 oz 3D planes. 2Sunny Aircraft - Electric - Power Systems (FS/W) 0 May 22, 2008 05:04 PM
For Sale $69. MP Jet motor + Jeti esc for 10 oz 3D planes. 2Sunny Aircraft - Electric - Power Systems (FS/W) 2 May 03, 2008 06:51 AM
