Old Mar 16, 2014, 08:34 PM
United States, PA, Catawissa
Joined Jul 2011
VA-Models Extra 330SC EPP full fuselage
Hello,
I would like to share with you all, some info and pictures of my new plane that i received recently, the new Va-Models EXTRA 330SC !!!
Upon opening up the box you will soon realize that it is a high quality kit! Some features that stand out are sharp and vibrant graphic scheme, clear canopy and detailed cockpit, sweet fairings and sexy wheel pants
The Va-Models Extra 330SC is available in Green, Yellow and Red from Epphobby. A detailed step by step printed manual is included and building process was pretty simple and straight forward. A sharp hobby knife is a must to make clean and straight cut/ slice through the foam!
As usual, take your time to test fit the parts before gluing them together and i always soak all plywood parts with thin CA and add some expoxy on the motor box joints.
I am using an Emax BL2220/08, Emax 35A Esc with switching mode, Apc 10x4.7sf, 4 emax digital mg servos and the AUW comes at 712 grams (25oz) with a 3S 1500mAh.
Features:
  • True full fuselage design made out of durable and lightweight EPP foam that is easy to fix.
  • SFGs (Side Force Generator) made out plywood for stable high alpha maneuvers.
  • Durable motor-box made out of thick and rigid plywood.
  • Plastic molded cowl and clear canopy.
  • Epp Wheel pants and fairings.
  • Steerable tail-wheel.
Technical spec:
  • Wingspan : 1050mm / 41in.
  • Length : 1080mm / 43in
  • Flight weight : 590-660g / 21-23oz
If you have any question, please let me know and i will do my best to help! In the mean time, my VA Extra 330SC is ready for it's maiden flight
rc4u is offline Find More Posts by rc4u
Old Mar 16, 2014, 10:12 PM
CAP 232-aholic
DiabloKid's Avatar
Centreville, VA
Joined Jan 2003
Nice, how does it fly?
DiabloKid is offline Find More Posts by DiabloKid
Old Mar 16, 2014, 10:34 PM
Joined Jul 2011
I will be back with a flight report soon, stay tuned!
I know it looks very nice
Old Mar 17, 2014, 02:18 PM
hot wings's Avatar
Joined Jul 2010
..please test it asap and show us how it hovers and how it torque rolls...........................................th is is a important proof!!!!
hot wings is offline Find More Posts by hot wings
Old Mar 17, 2014, 10:57 PM
Joined Jul 2011
Had a chance to take the 330SC out for the maiden flight this afternoon! It flew great, went into a hover for a few seconds then it fell out of the sky! It turned out that my battery can't hold the charge any longer. But no worries, i have a couple new Lipos on the way and i'm hoping to be able to test fly this weekend....
Uh oh...i am not sure if i am up to the task, but i will give it a shot
I travel a lot for work and consider myself lucky if i get to fly once a week!
Old Mar 22, 2014, 01:31 AM
Joined Jul 2011
I finally got a video to show, though there is not much to see
It has been months since the last time i went out to fly! Thanks to my rusted fingers and gusty wind, i managed to crash twice. Other than a missing piece of foam out of the wheel pant, nothing else needed to be fixed!
As a beginner 3d pilot, i found the 330SC pretty stable and easy to hover. KE was smooth and locked in, no coupling and no mixing required.
Hovering starts at 1:48min
I would say the VA 330SC is a great, durable 3D trainer and a very capable 3D Epp airframe, that's if you got the skill!
You be the judge! .....
VA-Models EXTRA 330SC (2 min 53 sec)
Old Mar 23, 2014, 11:13 AM
CAP 232-aholic
DiabloKid's Avatar
Centreville, VA
Joined Jan 2003
looks good. I would like to use a cheaper Turnigy motor. Any suggestions?
Old Mar 23, 2014, 12:04 PM
Joined Jul 2011
Thanks! I will have to take a look for a suitable Turnigy motor as i have no experience with one.
The last time i spoke with Epphobby's owner, he told me that he will soon have PNP versions at affordable prices. I know for sure that their PNPs will come with a BL motor, switching mode ESC and Emax digital metal gear servos.
Old Mar 23, 2014, 12:15 PM
Joined Jul 2011
The closest one to the one i use and based on the numbers posted is the Turnigy D2836/8 1100KV. But please note that posted numbers can be missleading and performance vary from one brand to another.
Perhaps others with experience could please help, thanks!
Old Mar 23, 2014, 02:01 PM
CAP 232-aholic
DiabloKid's Avatar
Centreville, VA
Joined Jan 2003
good info pal. I am in no hurry and can wait for a PNP version. Just need something to kick around the local park thats fun and easy on the wallet.
Old Mar 23, 2014, 02:23 PM
Joined Mar 2014
I was very happy with the turnigy D motor until i compared it to other motors via testing. The results are below. Note the results do not give any accurate thrust data as my digi scales were pulling backwards. It does however gave an insight into the different options. Note the differing ESC's make a huge difference to both the total thrust AND throttle-ability.
http://www.rcgroups.com/forums/showt...4#post27726712
Park Fly is offline Find More Posts by Park Fly
Reply With Quote  (Disabled)
Old Mar 23, 2014, 04:28 PM
Joined Jul 2011
Interesting! Never thought of those things that you tested.
So, which motor and esc that you would recommend for the 330SC with such specs listed above? Thanks!
Old Mar 23, 2014, 05:03 PM
Joined Mar 2014
I am thinking on buying a yellow one of these, and i will go with a sunnysky X2216-9 1100kv a 3 cell zippy compact 850mah and a Yep 30 (HK) or a JP EnerGpro 25 gws 10X4.7 prop, but will also try an APC 10X3.8 slow fly and even a APC 9X3.8 Slowfly.
The Sunnysky's are available from 'BangGood' for stupid money and free postage.
They have a 4mm shaft also which is much better than the 3mm shafts on some which are easily snapped.
Old Mar 23, 2014, 06:29 PM
Joined Jul 2011
Thanks Park Fly! Please post what you think about the 330SC once you bought and built one.
For my next plane, which is VA330, I will get that sunnysky motor and esc that you recommend.
Old Mar 23, 2014, 09:15 PM
CAP 232-aholic
DiabloKid's Avatar
Centreville, VA
Joined Jan 2003
Did not see the X2216-9 on BangGoods website. What did I do wrong?
Discussion Ultimate X3- Va-models full fuselage EPP Aerobatic Bi-plane. rc4u 3D Foamies 60 Aug 17, 2014 02:00 PM
Discussion 3DHS 48" EPP Extra 330sc ANDYjuice11 3D Flying 5 Dec 03, 2013 04:04 PM
Cool Epp foamy full fuselage Va-Models Loop. rc4u Parkflyers 2 Jul 05, 2013 10:46 AM
Article Hacker Models Extra 330SC Full-Fuselage EPP Plane Review Spackles94 Sport Planes 86 Mar 29, 2013 09:13 AM
Discussion EXTRA VA-330 - 40" EPP from VA-Models Honza C 3D Foamies 9 Oct 20, 2011 03:55 PM
